Old 03-26-2007, 09:24 PM   #1
wastntim
Illinois VCA Member
wastntim's Avatar
Default Lubing door hinges
Couple of quick of stupid questions. What is best to use to lube door hinges? Any good way to apply to get into the hinges?
Old 03-26-2007, 10:09 PM   #2
BoeingMan
Default Re: Lubing door hinges
Believe it or weep, my 2001 maintainace manual says to use engine oil.
BoeingMan is offline   Reply With Quote
Old 03-26-2007, 10:45 PM   #3
PhoenixGTS
Take off the little body panel in front of the door. Three little bolts I believe (maybe 4). Make sure to note location and save all shims. put little dab of grease where moving hinge part contacts spring (you will see when you open/close door. Done.
Old 03-27-2007, 08:18 AM   #4
wastntim
Illinois VCA Member
wastntim's Avatar
Wow! That is more complex than I thought it would be.
Old 03-27-2007, 09:02 AM   #5
Asp Man
Western Canada VCA Member
Asp Man's Avatar
The only problem with grease, or any lube, is that in that spot it is going to attract dirt as it is not that well shielded from the elements, sand, grit and hold it there to grind away at the hinge and hinge spring steel parts. No way around it, unless someone comes up with a boot of some sort. Until then, clean it often.
Asp Man is offline   Reply With Quote
Viper door hinges MoparMan RT/10 and GTS Discussions 11 06-27-2006 12:12 PM
Door Hinges? BACKNBLACK RT/10 and GTS Discussions 5 09-15-2003 02:30 AM
New door hinges at 5k miles? Kurt 97 GTS RT/10 and GTS Discussions 1 10-15-2002 08:49 AM
Door Hinges Supercharged Vipermad Archive Management 2 01-27-2001 01:04 PM
door hinges GTSnake Archive Management 3 10-28-2000 09:38 PM
