I have a question about bringing the Viper out of Winter Storage. I changed the oil before I put my 99 RT/10 away for the winter. This past weekend I got her out and took her for a 20 mile spin. Car ran great. My question is: Do I really need to change the oil again after bringing her out of storage? It seems kind of point less since I just changed the oil in November. I spoke with a mechanic that I trust and he said that changing it once before you put it away for the winter is good enough. He said there is no reason to change it again when you bring it out of storage because the synthetic oils do not break down like conventional oil. Anyone have any advice?
There is absolutely no good reason to change brand new oil which is 5 months old. ...especially if the car was shut down last fall and not idled periodically.
Steve |
Steve,
I think the same thing, but on here some people claim that you must change the oil before going into winter storage and also coming out. Just seemed a little too much for me. Glad someone agrees with me! |
I've never changed my oil bringing it out of storage. It would be a waste of perfectly good oil.
Actually guys, yes, it's not a bad idea to change the oil "after" storage. The reason why is because water condensates in the oil over time. Even in a sealed crankcase, moisture can build up in 5 or 6 months. I was surprised how much water condensation there was just on the frame when I went under.
What I don't understand is what difference does it make changing the oil "before" storage? It's not getting any dirtier or rubbing against parts just sitting there, so why change it? I wait till after storage to change mine. |
Ontario VCA Member
Wouldn't any water condensation etc be immediatly burned off once the car gets up to temp???
Also I heard in regards to changing your oil before storage because there are contimanents in the used oil and it starts to chemically react to the internal parts of your engine. I'm not buying it,, at least not anything that gonna harm the engine. |
How can you build condensation in a cold stored engine in ambient temperature? Water is a byproduct of combustion so you build condensation when the engine is running.
Secondly, water is burned off once the engine reaches operating temp but to completely burn off all the water it has to be for a prolonged period. That's why they say short drives are worse for your engine. |
I think I am with GTSnake and Steve on this one. If you change your oil prior to putting it away for the winter there is no reason to change perfectly good oil again when coming out of storage. It is just a waste.
#9 | |
As for changing the oil, truth be told, our car has never been put away with 'brand new' oil. I've always managed to find another 1000 miles between snowflakes before having to pry the keys from my hands. I've used oil analysis since day one, and the oil has come back perfect every time. Heck, for an experiment one year, I put the car away with 5,000 miles on the oil, ran another 5,000 miles the next spring, and changed it (2 track events/several xcrosses on it). ..Sent a sample to Blackstone -- they wrote back and told me to extend the drain interval. The oil was perfectly fine. I typically change every 5 or 6 thousand miles. 64,000 miles to date ...and not putting around miles. This business of changing the oil before storage, and after, seems ridiculous to me. Steve |
I'll add to the pot on this one...
The various positions are somewhat complicated by standards set for the proper storage of diesel engines in the winter or about to experience large down time.. Alot of wht I hear about the proper storage of engines is based on diesel practices. Simple fact is that MOBIL 1 has its own characteristics that aid considerably to the long term storage of engines. But folks, that means LONG TERM storage as in NOT starting the engine every now and then. Those advantages have to do with coating capabilities and their ability to better protect against corrossion. Running the car every couple of weeks and moving it back and forth 8 - 10 feet keeps everything right and lubbed. I do change the oil at the end of every season for three reasons. One, in the old days oiled "soured" became acidic (especially in diesel) and we wanted to store the blocks aways with fresh "sweet" oil. Secondly, by chaning the oil in the Fall, I was sure to start the next season with fresh oil. With MOBIL 1, well it would be a HUGE waste IMO to change in Fall and then again in the Spring! Thirdly, the water issue, if one CAN'T turn the rig over every couple of weeks or months than water can collect. This is especially true in a stone cold (frozen) garage! In a warm garage in the winter it is DRY in the winter. Just running the engine gets most of the water out if you let the engine come up to where the fan turns on. Rolling the car those ten feet is a BIG help for the rest of the drive train. Most important of all? Lower your tire pressure so the tires don't become flat! just be sure to refill in the Spring! |
I think if you want to avoid flat spots on the tire you need to increase the pressure during storage not lower.
YIKES!!!!
What in GOd's name was I writing!!!! Your are CORRECT up pressure... |
What I don't understand is WHY totally store the car in the winter? I do NOT drive my car if there is snow on the ground, but I run my car as often as possible in the winter to keep everything fresh and from sitting. Even if the roads are sandy, if you have a lot of wax on the car it can be cleaned off easily without washing. Even just a 10 minute right around the neighborhood is better than it sittin. I have never believed in totally storing a car.
It's not the sand...its the SALT. Even when the roads are "dry" the salt just blows throughout everything..and waits for rain.
I agree. The roads are just aweful in the winter and would not take the viper out on them. All kinds of grit, salt, and grim will find ways of getting stuck in places that you do not think of. Better to let it sit and wait until a good rain washes all that trash away.
| Winter Storage | DrumrBoy | RT/10 and GTS Discussions | 2 | 11-01-2003 03:02 PM |
| Winter Storage | HawkeyeViper | RT/10 and GTS Discussions | 1 | 09-30-2002 07:14 AM |
| Winter storage | vinman | RT/10 and GTS Discussions | 4 | 12-03-2001 08:22 PM |
| Winter Storage | GTS Bruce | RT/10 and GTS Discussions | 1 | 11-20-2001 11:59 PM |
| Winter Storage | Archive Management | 0 | 12-31-1969 06:00 PM | |
