Old 04-19-2007, 02:16 PM   #1
94yellow
Default 94 door speaker grills
Can you remove the door speaker grills without removing door panel, Mine our in need of painting. If so let me know how , Thanks.
94yellow is offline   Reply With Quote
Old 04-19-2007, 07:11 PM   #2
Tom, F&L GoR
Tom, F&L GoR's Avatar
Default Re: 94 door speaker grills
I have a door panel in the garage. It looks like you pry the grill out of the ring around it. After you do, the ring that the grill sits in will still be on the door.
Look through the grill with a flashlight - you will see the heads of the four screws that hold the ring on the door. The pointy ends of the screws poke through on the inside; you can't even get the ring off the door without removing the grill first.
Tom,
Old 04-21-2007, 06:36 PM   #3
Jeff Torrey
Jeff Torrey's Avatar
What Tom said.
Old and Red
NH Lic. Plate 92RT10
Past President- New England VCA 2006-07
Jeff Torrey is offline   Reply With Quote
Are the Hood Speaker Grills different on the Gen I and II? Tom and Vipers RT/10 and GTS Discussions 5 09-25-2006 11:31 AM
Painting the "speaker" grills 94RT10Ohio RT/10 and GTS Discussions 3 01-22-2006 05:37 PM
reconditioning hood "speaker grills" snampro RT/10 and GTS Discussions 19 01-03-2006 10:27 PM
Sorry, I should have said hood 'speaker' grills in previous post SHADOW RT/10 and GTS Discussions 10 06-04-2005 07:44 PM
Hood speaker grills....... Matt M, PA Archive Management 5 12-26-2000 11:11 PM
