nevermind.....I'm going with OEM bushings.
After I modded the kit a bit it is pretty slick (I reconfigured the aluminum toward the rear that holds down the post cut facia) - especially since I had the underside of the facia painted after I cut the hole so the edges of the cut are painted - but it did not change my temps on the street one iota. Saddest part of the whole deal is I bought a bunch of little washers that fit perfectly around the rivets and effectively enlarge the rivet head and spread the clamping pressure over more of the facia urethane - then after stepping back to look at my VERY clean work on the install, and after I had the facia reinstalled, I notice that one of the washers had fallen off the rivet so one is missing. I still wake up in a cold sweat about that once in awhile because it is not perfect and I refused to take the facia back off, drill the rivet out, and re-do it.
| Poly motor/trans mounts | rblong | SRT10 and SRT10 Coupe Discussions | 4 | 07-17-2007 11:13 AM |
| Upgraded Motor Mounts? | Oldwilsonian | RT/10 and GTS Discussions | 4 | 01-24-2007 08:41 PM |
| Any one change their own motor mounts? | V10 ACR | RT/10 and GTS Discussions | 10 | 11-28-2006 09:51 PM |
| new motor and trans mounts installed finally!!! | v10kingsnake | RT/10 and GTS Discussions | 5 | 09-09-2005 08:16 AM |
| Motor Mounts | mntngts99 | RT/10 and GTS Discussions | 5 | 01-25-2005 01:22 AM |
