Old 07-23-2007, 01:12 PM   #1
Catwood
Default Installed the Roe front fascia kit and Poly Motor mounts
this last weekend.
The fascia kit was fairly easy but took time with all the double checking I did on the measurements. I won't know the effectiveness of it for a month or so when I get back at the track.
The motor mounts on the other hand were a bit more of a challenge. I bought the poly ones from woodhouse. It's only 3 bolts/nuts per side but it was a fair amount of wrenching. The motor came up just high enough to slip the old ones out. The passenger one was a bit more of a puzzle than the driver side. My old rubber mounts didn't look as bad as I expected. I had seen V10 ACRs and his were bad. I did have a hell of a time getting the alum bracket off of them once out of the car. In fact one of the lugs broke off the old bolt before it loosened. Once that was done it was another puzzle getting them in place. I mounted them to the engine side first and lowered the motor which was now off center....dang. it was off towards the driver side about 1/2".
I raised the motor up some and put the nut on the passenger side mount and tightened it up drawing the motor back onto center. When we lowered it that time it fell right into place.
I have a bit more NVH from the mounts but it feels tighter if that makes sense. I'm looking forward to getting back to the track soon and trying out the goodies.
Carl
Catwood is offline   Reply With Quote
Old 07-23-2007, 01:33 PM   #2
wastntim
Illinois VCA Member
wastntim's Avatar
Default Re: Installed the Roe front fascia kit and Poly Motor mounts
Robert
Old 07-23-2007, 01:36 PM   #3
Catwood
Pics of what?
Old 07-23-2007, 01:40 PM   #4
wastntim
Illinois VCA Member
wastntim's Avatar
Pics of the facia kit. I've been thinking about it.
Robert
Old 07-23-2007, 01:49 PM   #5
Catwood
I don't want all the waxer folks to rag on me how scratched up & dirty the underside is
Old 07-23-2007, 03:29 PM   #6
mad0953
Oregon VCA Member
mad0953's Avatar
I don't wax that area....you can't see it so I don't wax it!!! Mine probably looks worse than yours. I want to see the Roe kit too. Pretty please?????
Old 07-23-2007, 05:15 PM   #7
ViperTony
ViperTony's Avatar
Forget the posers! Please post pics. BTW, did you install the transmission poly mount too? I don't know if it was the woodhouse engine mounts or transmission mount (or both) but my shifter now stays put. Doesn't move, rattle or shake. I used to miss shifts but no longer. I love the Woodhouse mounts...you can feel the car lurch forward now when accelerating. It feels like the car regained lost energy. A bit rough at idle but who cares.
- Tony
WE SAVED TATOR'S DODGE
Old 07-23-2007, 06:15 PM   #8
Catwood
Talking Re: Installed the Roe front fascia kit and Poly Motor mounts
- Tony
OK...I'll post some pics soon.
The acceleration does feel more crisp. I had installed the tranny mount and Dave's crossmember a few months ago. I actually like the slight buzz at idle. Feels more racecar like. I had solid mounts in a drag car some time ago and I liked that also.
Old 07-23-2007, 06:43 PM   #9
EllowViper
Central Florida VCA Member
EllowViper's Avatar
Same same. Woodhouse mounts and Daves trans/crossmember. I thought the engine was running rough at first but then realized..the poly mounts...duh. I broke the stock bolt off the bracket too when I tried to remove the nut..plus the OEM mount twisted/broke as well. There is A LOT of flex in the stock mount. I could not believe how CHEEAAAPPP the trans mount was.
2001 Race Yellow/Custom White GTS; 6.5 lb ROE, Custom W/M, Bellager, Hi Flow-Cats/Corsa, Eibach
Old 07-26-2007, 05:42 PM   #10
FE 065
Interesting info on firming things up underneath.
Me being just a poor retiree and all...I'm going to try this part at Summit Racing - for almost $30 less. Looks the same doesn't it?
Energy Suspension (who makes both poly mounts) twice confirmed to a friend that it is the same poly trans mount. I have to order some stuff from Summit anyway, so I'll give it a try.
It's important not to alter the driveshaft/ujoint angle up front when doing something like this. On a Corvette forum I've read they stress using the extra plate shown on the Summit page to maintain the Corvette driveline angles. Whether it is on the Viper or not I'll have to see.
I can always send the poly trans mount back to Summit if it isn't the same thing.
- If it works out, I can spend the nearly $30 savings on myself.
2001 ACR/1999 GTS
Chrome ACR Wheels for sale
(24lbs lighter than OE 18")
Old 07-27-2007, 08:32 AM   #11
Catwood
I understand the "poor" aspect. That's why I went with a proven part from a supplier I can not only trust but also races. YMMV but I don't want to have issues at the track.
Best of luck either way.
Carl
Old 07-27-2007, 08:50 AM   #12
Dave's Big Brakes
VCA Member / Supporting Vendor
Dave's Big Brakes's Avatar
front fasica this is a great product even if it isn't mine
It does take some big one's to cut the hole but it helps cooling about 25-30'
Big Brake Dave
Dave Cawthorne
2002 RaceYellow GTS
Home of Dave's Big Brakes (RaceYellow Stops Better)
www.davesbigbrakes.com
Dave's Big Brakes is online now   Reply With Quote
Old 07-27-2007, 09:57 AM   #13
Catwood
Big Brake Dave
spot posting and get to work on a full set of delrin suspension bushings for under $250.
I need them in a week! Season starts soon.
Old 07-27-2007, 10:05 AM   #14
Dave's Big Brakes
Hey Carl
Bring me a set of front upper & lower control arms & rear upper & lower control arms and I'll start the building process It just takes money Plus I need my nap
Balls in your court
Big Brake Dave
Dave Cawthorne
2002 RaceYellow GTS
Old 07-27-2007, 10:09 AM   #15
Catwood
Use yours, they are the same
Hey Carl
Balls in your court
Big Brake Dave
Poly motor/trans mounts rblong SRT10 and SRT10 Coupe Discussions 4 07-17-2007 10:13 AM
Upgraded Motor Mounts? Oldwilsonian RT/10 and GTS Discussions 4 01-24-2007 07:41 PM
Any one change their own motor mounts? V10 ACR RT/10 and GTS Discussions 10 11-28-2006 08:51 PM
new motor and trans mounts installed finally!!! v10kingsnake RT/10 and GTS Discussions 5 09-09-2005 07:16 AM
Motor Mounts mntngts99 RT/10 and GTS Discussions 5 01-25-2005 12:22 AM
