Old 07-30-2007, 12:29 AM   #1
onerareviper
Default Clutch Inspection Cover -- Is it needed?
Viperholics,
1.) I recently had a new clutch/pressure plate/TO bearing installed, and the mechanic told me the clutch inspection cover was damaged. It was only being held on by one bolt (should be four). Apparantly, this is pretty common via a previous post I read from Chuck Tator. Anywho, what purpose does this part serve? In other words, can I drive my car without it? It's a cheap part (+/- $50), but I'm just curious... There's a picture at the bottom.
2.) Is it possible this part could have been rubbing against the flywheel making the noise I referred to in this post (click on link)? I tend to think not, since the sound changed when pushing the clutch in/out. Not to mention the noise was present for a good while, and the metal on the clutch inspection cover is pretty thin. Seems if it was hitting the flywheel it would wear away fairly quick. Yes, I'm trying to convince myself I did not have a clutch kit installed for no good reason
PLEASE help diagnose this problem - Video attached
PROUD VCA MEMBER
Old 07-30-2007, 06:28 AM   #2
Default Re: Clutch Inspection Cover -- Is it needed?
Keeps dirt, rocks, drink cups, water etc from getting in and on your clutch. Get a new one.
Old 07-30-2007, 01:29 PM   #3
onerareviper
That's what I figured... Thanks.
PROUD VCA MEMBER
Old 07-30-2007, 02:29 PM   #4
Viper Wizard
Viper Wizard's Avatar
Cool Re: Clutch Inspection Cover -- Is it needed?
Cover #5245010 fits 92-02 MSRP $64.75 [less 20% VCA].
Yes a lot of them break from vibration.
CHUCK TATOR
1975-USAF/SAC/KC-135/FB-111
NRA Life Member
Viper Tech Since 1993
Viper Owner 94/RT#902
TATOR'S DODGE SINCE 1914!
Cargo cover help needed agentf1 RT/10 and GTS Discussions 3 06-18-2007 02:48 PM
Clutch Inspection Cover mntngts99 RT/10 and GTS Discussions 4 08-21-2006 05:15 PM
Oil Filter cover Needed JoeB General Viper Competition Coupe Discussion 4 01-31-2005 10:40 AM
Technical Bulletin - Fire Suppression System - Immediate Inspection Needed Viper_Race_HQ Service Manual/Technical Updates 0 11-10-2004 03:13 PM
Clutch safety switch advice needed 94 RT/10 Black MAMBA RT/10 and GTS Discussions 4 02-06-2003 05:24 PM
