I'm having a set of Gen2 18" rims refurbished. The place that is doing them is having trouble getting the clearcoat to be solid. The couple of times they have tried so far, you can easily scratch it with a finger nail. They are trying another type of clear coat, but said that they don't have trouble with other wheels and their standard clears. Anyone have experience in this area and suggestions on clear coat?
There are only a few automotive clearcoats that are actually designed apply directly to aluminum without a bonding clear. PPG used to make one, probably still does but its been years since I worked for them. I believe the part number was DX80 or something like that, square can with a purple label. Sounds like your paint is net being properly catalyzed. Urethane paints need the appropriate catalyst to create the chemical reaction that makes them dry. Either your painter didn't use the right catalyst, not enough, or old stuff that won't work. Make sure they are using a urethane paint with a catalyst that is designed to be applied directly to aluminum.
Chris...just chrome them and be done with it...that is going to be my solution
![]() See you on Friday?
Central Texas VCA President Simply content with keeping my 94 running...70k and climbing fast!
Thanks for the tips.
Ryan, I'll be there on Friday. Shoot me time and directions. |
leave the clear off... they look much better
leaving it off makes for a lot more work though. they should know what they're doing.......
You can find a good powdercoating company and have a very durable finish like the gen3 car wheels. The clear is the same as the factory and if you wanted could be tinted slightly for the smoked look or whatever you may want. Should run about $125 per wheel.
Woodhouse Viper Service Mgr. 800-889-1893 work 402-677-2935 cell |
TRGcoating.com ask for Russ. tell him i sent ya
Leave off the clear coat, and have them polished. They look much more cleaner than chrome, and it is not that big of a deal to keep clean. If you have the EBC Green brake pads, all I do is use a small duster, and some Z-6 Zaino spray. Takes about 5 minutes total time. Then about 3-4 times a year, I use Mother's Mag Polish, and spend about 1 hour total for all 4 wheels. I get so many compliments on my wheels, it is worth it. No more of that milky look, or adding the extra weight of chroming.
Dennis Kimball 01 RT/10 Saph Blue W/polished Roe Water/Meth S/C, T&D Rollers & Belanger hdrs, HF cats, Corsa 3 catback, B&M short shift, SOLID BILLET ALUMINUM VALVE COVERS. 303 SS LUG NUTS & CUSTOM CENTER CAPS in Custom milled OEM Gen II Wheels |
The wheel refinisher I have worked with says to leave the clear off. Even if you can get it on right, it sometimes cracks, blisters, and/or peels. He suggested using Wheel Wax and it works great. WheelWax.com
Bruce 2002 Graphite GTS |
Canada VCA Member
![]() Join Date: Feb 2007
My clear coat is cracking and pealing too. What is the best way to remove all the clear coat off?
Phil |
#12 | |
That is another great benefit of having your wheels polished without clear coating them. If you ever nick them or curb them, you can fix them , no problem. I did it once right after I had them polished. I thought i was going to kill my self, but it sanded and buffed right out.
Looks great but to darn hard to keep clean.
NY/CT VCA Membership Director NY/CT VCA Secretary Elect
There are products that strip it for you. When I had mine refinished that is what they used.
| Baffled by the clear coat | Newport Viper | SRT10 and SRT10 Coupe Discussions | 15 | 07-18-2006 10:07 AM |
| I take it the clear coat you buy in a can at Autozone is not the same | ab | RT/10 and GTS Discussions | 1 | 05-07-2004 11:36 PM |
| base coat clear coat what brand of paint did dodge use | Viper Fever | RT/10 and GTS Discussions | 11 | 03-07-2004 09:16 AM |
| Wheel clear coat pealing | 500hp | RT/10 and GTS Discussions | 4 | 01-09-2004 02:02 PM |
| compound took off my clear coat. help!! | Steve-Indy | RT/10 and GTS Discussions | 1 | 09-06-2001 11:45 PM |
