Hi All!
I purchased this 1996 Viper GTS Venom 550 Hennessey a couple years ago and am now in the process of "tweaking" the car...for both power and looks. This Viper only has 1800 miles and hasn't even reached it's first oil change!! I can not own a vehicle and not "tweak" it regardless of its age and/or value. So let the wrenchin' begin!!! Here are the stats before the "tweaking" began. Engine
GTSjbud 1996 Viper GTS Venom 550 Hennessey "Too fast?? It's never too fast!"
Here is a list of modifications that I am planning to do. I am also working with one of the best Viper tuners, Joe Donovan - Performance By Joe - PBJ (www.performancebyjoe.com) to see how much more juice I can squeeze out of the engine.
Engine PBJ Air Intake System PBJ camshaft (to increase HP) - to be determined 9.0 L racing oil pan with windage tray & ACR adapter - to be determined VEC 3 controller (to enable more precise engine control) CNC machined power steering bracket (OEM unit has the tendency to break) Gen. III Viper valve covers Powdercoat valve covers and intake (darker Red) Transmission skip shift module B&M Ripper Shifter Exhaust ceramic coat headers and tubes Borla XR-1 Racing mufflers Random Technology catalytic convertors Cooling Ron Davis aluminum racing radiator Wheels Forgeline SP3P wheels (gunmetal centers) 19" x 10" - front 19" x 13" - rear Tires Pirelli PZERRO ROSSO 285/30 19 - front 355/25 19 - rear Exterior upgraded Viper GTS emblems upgraded Venom 550 Hennessey emblems MGW Viper emblem pop open gas cap U.S. Exotics Diamondback hood Interior Venom 550 Hennessey floor mats Venom 550 Hennessey seat emblems Venom 550 Hennessey dash plaque MGW first strike race shifter knob Viper GTS side sill covers Viper GTS door pull surrounds Aluminum control knobs - all Aluminum dash console Aluminum racing pedals Push button start Dynamat sound deadener Stereo system - to be determined I will be posting pics as I work through the modifications. Cheers Jason
Here are some pics of the Viper in my shop just before I started the modifications.
Here are some pics of disassembling the interior. I removed the carpet and original sound deadener so that new Dynamat could be installed.
Here are some pics with the intake manifold and valve covers removed. I removed them so I can have them powdercoated with a much more vibrant Red. I am removing the original wiring harness tape and convulted tubing because it is old and dried out. I will be rewrapping the wiring with new tape and installing high-temp convulted tubing.
When I removed the intake manifold I used a Dremmel to grind off the casting ridges where the two halves were fused together during the manufacturing process. I wanted the manifold to look smooth without the rides. Next step is to remove the original paint.
Here is a picture of the stainless steel exhaust headers before they were ceramic coated.
Here are the brakes before I detailed them. Will be polishing the center of the front rotors and painting the center of the rear rotors. Front rotors are two piece and the rears are one piece.
This is the differential before and after. The diff. had many leaks as it was not properly sealed after the gear ratios were changed by the previous owner. I disassembled the diff and cleaned the housing surfaces to provide a better seal. I also installed a drain valve in the bottom of the case. Added some paint to the u-joints to give them some spice. Bolted the case up with stainless steel allen wrench fasteners...bling bling.
Nice looking B/W you have there!
99 Viper (Tubes&filters, Full TNT exhaust, T&D's and other goodies) Macedo Tuned!!!! SAVE TATORS DODGE!!!!!!!!!!!!!!!!!!!!!!!!!!!! |
I am speechless. That's a lot of stuff to piece back together. If I was independently wealthy, single, and basically had nothing else to do, I'd be coming over to put mine on blocks beside yours and take it all apart.
Do you drink? I hope so, you're going to need one before you finish all that. Maybe a cigar too. |
Thanks for the pix. Will be interesting to see it evolve......
What's your HP target?
Ron - '96 GTS |
#13 | |
Guess what, I'm not wealthy, I'm not single and I have many others things to do. So having said that, you can do it too! Put er' up on blocks and just giver'!! I would be open to assisting you wrench on your Viper if you want. Let me know and I'll guide you through it. Cheers Jason
#14 | |
I remember an article written in one of the Viper quarterly's where Team Viper had squeezed 700 HP (at flywheel) out of their Gen. II race engine. That would be nice ![]()
DC Performance Stage 6 18/19 HRE 547R,K&N's, Smooth Tubes,Alum.Flywheel,Stryker Heads & Cam package,S.V.S. Shifter with 1 5/8 L.Tube Stepped Headers,Borla Catback,R.T. Metal Cats,MGW Goodies,5Pts,3:55 Gears,Wilwood Big Brake Kit,Thermal Insulation Kit,Eibachs |
| Who’s MAKING more HP than the 08 Viper now? | Andrew/USPWR | SRT10 and SRT10 Coupe Discussions | 46 | 10-09-2007 08:45 PM |
| Murci R-GT making 745hp/ Gallardo to get "track" mods to spar with F430 | SnakeBitten | Sneaky Pete's Place | 8 | 12-06-2004 12:20 PM |
| My Venom 650R Pics...finally finished all external mods...I think? | DEVILDOG | RT/10 and GTS Discussions | 24 | 04-27-2003 02:39 PM |
| HELP....a 2003 Z06 with 0% is making me think other than Viper... | Toby | Sneaky Pete's Place | 26 | 09-21-2002 07:37 AM |
| Viper making me fat and smart... | USAF BAD ASP | Sneaky Pete's Place | 5 | 02-19-2002 03:39 PM |
