I received and had my Rotary lift installed today. So far, I have chosen not to bolt it down. I am not sure that was the best decision so I will probably end up bolting it down. I put my Viper on it for the first time tonight and a scary thing happened. I raised the car all the way up. The next thing you are suppose to do is lower it onto a lock. When I tried to do this, the runway at the left rear column did not lower causing the whole thing to start to twist with my car on it. I stopped immediately when I noticed this, raised it back up until it was even, then lowered it all the way down to the ground according to the instructions. The lowering to the ground when as I would have expected. Has anyone had a similar experience? The installer is coming back tomorrow to check it out. I have lost come confidence at this point.
I also have a rotary.
Did you try raising it first to the maximum possible height and then lower it onto the lock? I had an issue with that after my install and all it required was the installer to come out and adjust one of the cables at the top of the post. I have not had an issue with it since and it has been a great product. If this issue persists, however, I would contact Donnie at Rotary. I have found his customer service to be excellent. /Rich
Anyone got pictures of this lift?
'94 Black RT/10 |
I have had my Rotary 4 Post lift for 5 years now and I love it!
Do not be discouraged. It is,IMHO,one of the best 4 Post lifts you can buy. I had mine adjusted on two occassions within the first 6 months after I had it installed. It was only a matter of the cables having to be slightly adjusted and some minor adjustments on the lock plate inside one of the columns. In your case, it sounds like the left rear lock did not fully disengage. Make sure you have the handle facing in the full vertical position before you begin to lower it after you lift it slightly off of the locks. I always check to see if all the locks are fully engaged when I put any of my cars on the lift.BTW, I also chose not to bolt my lift to the floor. I have the bolts,from the installer, to bolt it down if I choose to but I dont think I will. Many of the 4 Post lift companies products are made to be free standing due to the large 12"x12" foot plates on the bottom of each column or can be bolted down. Let us know what happens after the installer comes back.
BIBLE=Basic Instructions Before Leaving Earth VIPER Verses: Acts 28:3 and Isaiah30:6 TATORS DODGE SAVED!!!! |
I did raise it all the way up, but when I tried to lower it onto the lock position, the runway didn't come down at the left rear corner causing the car to start tilting with the lift. I am hoping it is something simple like yours. It seems like a great product. Did you fasten yours to the concrete?
#6 | |
I wasn't holding the lock disengage handle in the vertical position. I pulled the car on it for the first time and raised it all the way up. From there I tried to lower it down on a lock to store it up there. That is how I understand I was suppose to do it when you raise the car. The problem occurs when I try to lower it onto a lock afer I initially raise the car. It seems to lower fine when I follow the instructions on lowering it to the ground. When the installer demonstrated it without a car on it, everything seemed fine.
Not to hijack, but what's a Rotary 4-post with installation set you back?
Pix'd be great as well. ![]() |
#9 | |
No, I have never bolted mine down and have found that the lift has moved hardly at all (maybe a cm or 2) over a three year period. Also, I ordered the caster kit that allows you to roll the lift around in your garage which is fairly handy. Someone asked for some pictures of the Rotary. Mine is the XLT model which is the larger size but as you can see I do not have any problems with front end garage clearance: ![]() ![]() ![]() ![]() ![]()
#10 | |
#11 | |
I paid $3520 for the standard model, plus $550 to install. If you have the room for the XLT that is the one I would recommend. You can stand up straight under your car with the XLT from what I understand. The standard model gives you about 5'3" of headroom under the lift.
It happened to me once with my rev. lift and it was because I forgot to hold the lock release latch. no biggie just raised and lowered it again. hasnt happened again. bolt it down though.
#14 | |
Wat cool. Thanks for the pix and info.
| Rotary Lift Group Buy? | Larry | RT/10 and GTS Discussions | 36 | 03-29-2006 01:17 PM |
| Rotary Lift Group Buy? | Larry | SRT10 and SRT10 Coupe Discussions | 16 | 03-28-2006 08:18 PM |
| Rotary (evolution lift) question | Matt Houston | RT/10 and GTS Discussions | 0 | 08-25-2005 07:39 PM |
| Rotary lift installed | snakebitdave | General Viper Discussion | 24 | 10-17-2004 07:56 AM |
| 4 Post Lift Discount - Rotary Revolution Lift | Jerry Dobson | RT/10 and GTS Discussions | 32 | 07-30-2004 12:46 PM |
