Old 01-28-2008, 05:12 PM   #1
JohnnyLightning
JohnnyLightning's Avatar
Default 1996 & 97 GTS 1/4 Times
I was wandering with the forge internals & heavy cam what are people running stock on their GTS. Was the 96-99 faster in the quarter mile than 00-02. I have heard from the grapevine the 96-97 with that cam stock lowering pressure in the rear tires ran
12.3s & 00-02 ran 12.5s with a good driver. The .2s difference was because of cam & forged internals. Not talking ACRs because have seen where 99 ran a 12.1 stock. This same person also told me in 96 & 97s were the fastest of any of the GTSs.
JohnnyLightning is offline   Reply With Quote
Old 01-28-2008, 05:14 PM   #2
JohnnyLightning
Default Re: 1996 & 97 GTS 1/4 Times
Also anyone have time slips from a 96 or 97 GTS with only mods of belanger headers, random tech x-pipe with no cats and of course smooth tubes LOL.....
Old 01-28-2008, 06:49 PM   #3
99 R/T 10
99 R/T 10's Avatar
Times for all the cars thru 2002 are going to be close, will really depend on the driver. The fasted tested car was a 2000 RT/10 that went 11.7 at 119 I think. The biggest difference would be if you plan to add FI or NOS to your car. It would be better to go with a 1996-1999 due to the forged internals(assuming you don't want to have to open up the engine).
With your mods(belanger headers, random tech x-pipe with no cats ), I would say high 11's on a good pass as about 120.
97 B/W RT/10 -$39,900
99 Viper (Tubes&filters, TNT exhaust, T&D's ROE+ NOS=899hp/1300TRQ) safe tune
1997 GTS TT-Too much power
Old 01-28-2008, 07:11 PM   #4
JohnnyLightning
How is a RT faster than a GTS...I have seen stock RTs consistently run high 12s with gen II motor not gen I where GTS run mid 12s stock...The same driver ran a high 12 in a 01 RT consitently switched to a 99 ACR ran low 12s all stock....Same night...Just wander always thought GTS are faster...
Old 01-28-2008, 07:24 PM   #5
Burntrubber
AZ VCA Member
96 GTS w/ just K&N's
12.5 @ 118 mph / 2.2 60' / first time ever at a 1/4 strip.
First time launching the car.
Burntrubber is offline   Reply With Quote
Old 01-28-2008, 07:38 PM   #6
99 R/T 10
99 R/T 10's Avatar
Like I said, depends on the driver, mods etc. The 11.77 was achieved thru one of the magazines. If you do a search in the archives, there was a few threads on it. Asked the same question you did, but got to remember that at the end of the 1/4, areodynamics don't play as big of a role as they would past 150.
Old 01-28-2008, 07:57 PM   #7
JohnnyLightning
12.5 not bad where you running stock mich tires with 17inch rims? Those tires are like hockey pucks bet you could drop .2 of a second on the 60 foot with sticker tires...
Old 01-28-2008, 08:57 PM   #8
Burntrubber
AZ VCA Member
46k miles on the car, Stock 17" rims, michelin sports I believe. Oh...and a very abused clutch, it is amazing the abuse these things can take! On the same day I watched a granny-shifted 11.2second 96 GTS, head work, headers, full exhaust & 3.55's on slicks. He did 11.4 on street tires!
Old 01-30-2008, 07:12 AM   #9
radta7
Illinois VCA Member
radta7's Avatar
I thought Car and driver ran an 11.9 in a 97 GTS against a 911 turbo in one of there magazines. It was on the cover I believe.
Rob
Roselle, IL
1997 Viper GTS
radta7 is offline   Reply With Quote
Old 01-30-2008, 08:06 AM   #10
Compensating
97 GTS... smooth tubes... corsa.. pilot sports...
11.88 @ 119 with a 1.81 60ft
no BS.... late at night in Ark City Kansas..
Compensating is offline   Reply With Quote
Old 01-31-2008, 10:21 AM   #11
XLR8
AZ VCA Member
96 GTS with exhaust, head work and Ross pistons. It was the first time at the tack wth this car so I was doing a check it out run. I ran an 11.206 at 123.409 mph and got told to slow down or go home. So I lowed down and ran a 11.564 at 123.167. So I quit before I got kicked out.
XLR8 is offline   Reply With Quote
Old 01-31-2008, 11:41 AM   #12
Disturbed
Suspended
Back when my 01 ACR was stock I ran a 12.2@118 with a 1.9 60ft, 35psi in the rear tires. I think the record for a GenII is 11.8@120mph bone stock. I have the vid some place. It was a Bumble Bee GTS.
When it comes to drag racing, the ACR should be a bit slower off the line (due to 1100ft-lb springs in the rear) but a little better on the top end (due to tubes and filters). It really evens out.
Currently I've run a 11.1@131mph with a 1.9 60ft time. I afraid I'm going to bust a half-shaft at the rate I'm going. Heads, exhaust and a crower stg 1 street cam (same as a 708).
You can hit mid 10's in a heads cam STREET viper if it's set up right. Just a set of BFG's (or Kumho's) a Good cam and Good Heads A mph of 135 can be reached.
Disturbed is offline   Reply With Quote
Old 01-31-2008, 02:17 PM   #13
BigCarrot
I ran 11.46 in my '99 ACR at the first Viper Nationals in San Antonio. The only mods were deleted cats and BFG drag radials.
Old 01-31-2008, 06:09 PM   #14
JohnnyLightning
That is awesome guys thanks so much for your replys...I also remember some article discussing a stock GenII running 11.9s.....
Old 01-31-2008, 06:55 PM   #15
djacob372
RT's are lighter then GTS with the same power = faster in a straight line. Keep in mind that the viper was designed as a convertible so the GTS isn't much if any stiffer then the RT. The advantage of the GTS is mostly aerodynamics which don't come into play much in the 1/4 mile.
djacob372 is offline   Reply With Quote
Old 01-31-2008, 07:21 PM   #16
agentf1
WV/PA VCA Member
agentf1's Avatar
I have actually heard from reliable sources that the creampuff cam cars was actually quicker than the lumpy cam cars. This is a very heated topic on these forums and is almost as bad as the Gen II vs Gen III debate. My opinion is there really isn't much difference between any of them and it mostly depends on the driver. And I obviously prefer the Gen II.
Old 02-04-2008, 07:51 AM   #17
FikseGTS
FikseGTS's Avatar
I ran 11.6 @ 120 with edelbrock headers and borla exhaust...
1996 Dodge Viper GTS: 11.6 @ 120
FikseGTS is offline   Reply With Quote
Old 02-09-2008, 08:04 PM   #18
pdmracing
Georgia VCA Member
pdmracing's Avatar
12.2 118 bone stock 100 degree day,97 gts
same track gts with khumo , k & n & cat back 11.7
GA VCA
Past GA President
Past DAL
pdmracing is offline   Reply With Quote
Old 02-09-2008, 08:29 PM   #19
Landman
I've actually heard the GTS was lighter. Whats the difference?
Landman is offline   Reply With Quote
Old 02-09-2008, 08:30 PM   #20
Landman
I've heard the creampuff was quicker stock, but the forged was better to mod.
Old 02-10-2008, 07:26 AM   #21
the fastest was paul, ran 11.71 in a stock RT at Atco with the top off
BONE STOCK and a creampuff i think.
Old 02-10-2008, 07:31 AM   #22
here is the video..
11.71@119 in a totally Stock Viper - Video
drag racing times / magazine vs. real times riwracer SRT10 and SRT10 Coupe Discussions 8 10-06-2005 01:13 PM
1996 GTS mrviper RT/10 and GTS Discussions 21 07-10-2004 10:06 AM
1996 GTS sparty116 RT/10 and GTS Discussions 5 02-18-2004 09:12 AM
1996 GTS schorvitz Performance Modifications 4 12-05-2003 01:45 PM
deciding between a 1996 rt10 or a 1996 GTS Car Lover RT/10 and GTS Discussions 52 04-08-2003 11:58 AM
