Old 04-14-2008, 09:23 PM   #1
VIPER GTSR 91
VIPER GTSR 91's Avatar
Default 10w30 or 0w40 synthetic oil for Gen 2?
The factory specifies 10w30 for Gen 2 but when these cars were built I dont believe 0w40 was even out. The factory fill for newer Vipers and Vettes is 0w40 which I think is great. My question is: Dont you think 0w40 gives a better viscosity and heat range for the Gen 2 also? I would like to ask this question to the Conner plant guys but may take too long for their answer. Your thoughts...
HOUSTON VCA MEMBER
VIPER GTSR 91 is offline   Reply With Quote
Old 04-14-2008, 09:27 PM   #2
belair1957
OK VCA Member
Default Re: 10w30 or 0w40 synthetic oil for Gen 2?
Try e-mailing Royal Purple. I sent them a question on diff and trans fluids. They responded within a couple of hours.
belair1957 is offline   Reply With Quote
Old 04-14-2008, 09:40 PM   #3
VIPER GTSR 91
Good idea and will do so, but how familiar are they with the Gen 2 Viper engine specifically?
HOUSTON VCA MEMBER
Old 04-14-2008, 10:01 PM   #4
VIPER GTSR 91
Wizard, Jon B., Woodhouse, Archer, chime in here!!!
HOUSTON VCA MEMBER
Old 04-14-2008, 10:25 PM   #5
chimazo
Virginia Maryland VCA Member
chimazo's Avatar
I've read that auto manufacturers redesigned their engines for tighter clearances and instituted precision machining techniques that take advantage of thinner oil to deliver improved fuel economy through reduced friction. One of the car magazines tested various oils and found that lighter weight oil made more HP, and lighter synthetic oil made even more on top of that, but both lighter weight-ranges made less oil pressure. The synthetic manufacturers argue that the lower pressure is irrelevant due to their products' higher shear strength.
Personally, I wouldn't use "0w" anything on a higher mileage car.
Additionally, since the forged piston GEN2 motors would have higher bore clearances to account for expansion vs the '00-'02's cast pistons who's reduced thermal expansion rate allows the piston to be run with reduced clearance and produce a better ring seal, I wouldn't use "0w" in these (forged) either. Just my thoughts...
'96 Caprice 9C1
'08 Hummer H3
Old 04-15-2008, 05:39 AM   #6
Tom, F&L GoR
Tom, F&L GoR's Avatar
An SAE 0W-40 would be better.
The "0W" label only means something at very low temperatures; in this case that the oil allows good engine cranking speeds down to -35C and good oil flow through the oil pickup tube at -40C. It means nothing as far as warmed up temperature operation.
The "40" means it is thicker than a "30" when at the warmed up oil sump temperature. However, there is "fluid friction" and so an SAE 40 will have slightly more drag in the bearings than an SAE 30. What the OEMs have done with better precision manufacturing equipment is to make surfaces more uniform, which lets them make clearances overall tighter, and then allows the use of oils with less fluid friction, like the oil designated for the 5.7L HEMI engine - an SAE 0W-20.
Pressure is not relevant other than indicating the energy needed to place the oil where it is needed. The general "10 psi for every 1000 RPM" comes from having to push the oil against the centrifugal force inside the crank so that it reaches the next crank throw. Once the oil is positioned ahead of a spinning journal, it will get pulled in anyway. The 60 psi out of the pump is not going to make much difference to the 10,000 psi pressure under the journal.
An SAE 0W-40 will therefore allow better starting, better fuel economy when warming up, and slightly poorer fuel economy when fully warmed, but with a thicker oil film - meaning directionally better engine protection.
OEMs did have the choice of an SAE 5W-40 in the past, a viscosity grade favored by the Europeans. Now that SAE 0W-40 is available, it will also be formulated for Euro applications, meaning it will have more additive than typical SAE 10W-30 oils. That alone is worth the switch.
Tom,
Old 04-15-2008, 07:37 AM   #7
VIPER GTSR 91
WOW Tom, that was some explanation and very detailed. Thanks.
HOUSTON VCA MEMBER
Old 04-15-2008, 10:05 AM   #8
Steve 00RT/10
Steve 00RT/10's Avatar
Tom,
According to my 'sources,' the 0W-30 I use has a very similar additive package to the 5W-40 European oil they offer. One exception being a little more calcium in the 0W-30 for detergent. Both these oils would work well for me -- with a little higher film strength in the 40 weight product.
Steve
Old 04-15-2008, 11:57 AM   #9
98viperGTS
98viperGTS's Avatar
Hey Tom, How can you tell if a oil has the additives like the European oils?
TATORS DODGE IS SAVED!!!!!!!!!!!!!!!!!!!!!!!!!!!!
98viperGTS is offline   Reply With Quote
Old 04-15-2008, 02:18 PM   #10
VIPER GTSR 91
Hey Tom and others, I got a reply back from RP and the rep. says he recommends RP xpr 5w30 for the Viper. (sales 101 of course). He thought the oil cooler on the new Vipers might be smaller than the Gen 2 and requires the 0w40???? After looking up the info on RP xpr 5w30, it states its for high performance engines, bracket racing, etc. but good for a daily driver also. Its very expensive at $13.00 a quart. Any thoughts on RP over Mobil 1 and does anyone use this brand and weight?
HOUSTON VCA MEMBER
Old 04-15-2008, 02:46 PM   #11
VCA Member/Site Sponsor
Viper Specialty's Avatar
We always recomend the 0W-40 for all the previous cars, its a more stabil oil all around.
If only it wasnt so hard to find in decent quantity!
Dan Lesser, Owner
www.ViperSpecialty.com
(716) 912-5336
WNY Tech / VCA Activities
Old 04-15-2008, 02:46 PM   #12
belair1957
OK VCA Member
Cheaper at Autozone $7.29/qt and probably other parts stores.
Old 04-15-2008, 03:55 PM   #13
chimazo
chimazo's Avatar
Thanks for the informative post (as usual), Tom!
With regard to RP, you can typically find it at Pep Boys, or order it online. I used it in my blown Z06 and just put it in my Viper, though I used old school 10w40.
'96 Caprice 9C1
'08 Hummer H3
Old 04-15-2008, 04:03 PM   #14
Tom, F&L GoR
Originally Posted by Steve 00RT/10 View Post
Tom,
Steve
Steve, yes, the selection of the additive package is independent of the viscosity (as I know you know.) Either oil will work fine, I was trying to point out the differences.
"Film strength" is an interesting concept and I see many references to it. However, I don't believe it is part of any standard SAE category or that there is an ASTM test for lubricants to measure it. There is high temperature/high shear viscosity measurement (ASTM D4683, CEC L-36-A-90 (ASTM D4741) or D5481) in which an SAE 30 could possibly have a higher value than an SAE 40...
Tom,
Old 04-15-2008, 04:05 PM   #15
Tom, F&L GoR
At a minimum, the back of the bottle will make claims for ACEA performance in addition to the API category. They may also claim BMW, Daimler, Opel, Porsche, VW approvals.
Tom,
Mobil 1 10w30 at Walmart 5 quarts for $17.78 viperdude118 RT/10 and GTS Discussions 16 07-17-2007 07:28 PM
Motor Oil: 10W30 or 20W50 Schulmann RT/10 and GTS Discussions 4 01-16-2006 07:29 PM
0W40 Mobil 1 oil change. Brian E SRT10 and SRT10 Coupe Discussions 3 11-17-2004 09:35 AM
Does anyone use Mobil 1 0W40 synthetic? ERDOC RT/10 and GTS Discussions 15 07-22-2004 07:48 PM
Moble One 10w30 or 5w30 or ????? Ulysses RT/10 and GTS Discussions 3 11-08-2001 07:41 AM
