Old 04-15-2008, 05:52 PM   #1
klamathpro
klamathpro's Avatar
Default Need help with Nitrous install - wiring
I'm installing an FJO progressive controller on my 94' and it says to tap the TPS and RPM line. For anyone that has used a nitrous controller, how did you tap these two lines and where? I found the TPS and tach signal going to the PCM. Should I splice into the wires near the PCM box and if so, do I simply 'Tee' off from these two wires? Should I tap the TPS near the TPS or at the PCM side? (Is it the same wire anyways??) I only have an input wire to the controller and no output so am I correct to assume that I don't actually cut the wire inline, but rather, just expose and solder a connection parallel to the line?
Thanks.
P.S. Anyone with FJO software settings on hand would be a plus also.
RED 94' RT/10
BLACK 05' CROSSFIRE
TATOR'S Dodge has been saved!
klamathpro is offline   Reply With Quote
Old 04-15-2008, 08:50 PM   #2
viperrt96
Default Re: Need help with Nitrous install - wiring
Thanks.
As you probably already know always splice in and never cut. Peel back about an inch and open the middle of the wire up. Insert your new wire, twist and solder. About as good as it gets. I would tap in close to the PCM. The motor creates alot of interference (Sensors and Coils) and you're reading things in low voltage. Make sure you tap the tach signal and not a coil driver. The FJO is one of the few things that can read a Viper tach signal (>5 volts) unlike the Raptor or other things I've seen not work.
I don't have my settings on me right now but I've posted some info here before
Click on below
Dyno Nitrous Results...very disappointed
Autotap not working & Nitrous problems...Getting Frustrated
viperrt96 is online now   Reply With Quote
Old 04-16-2008, 10:16 PM   #3
Jack B
Jack B's Avatar
Thanks.
Take a look in the media galley in my photos, I have a diagram that should help you.
As far as the driver pack versus the tach signal. The answer is to use the signal for the driver pack, not the driver pack output. In either case you have to know which your device is asking for.. Both tach signal and driver pack signal can be taken off of the PCM, my schematic shows the pin numbers and locations. I have a new set of schematics which I will post for you this weekend.
96GTS:
I have installed two Raptor's (different cars) and they both worked immediately.
Jack B
10.2 @140 (1.7 sec 60')
1.45 (best 60')
Nitrous Install 01 RT SNAKE RT/10 and GTS Discussions 18 11-24-2007 10:16 PM
Wiring from stereo head unit to amp for AVIC-N1 install? santo RT/10 and GTS Discussions 12 03-23-2006 01:15 PM
Nitrous install ohiodoc RT/10 and GTS Discussions 11 11-05-2005 09:27 PM
Has anyone done a nitrous install on one of the SRT-10 Vipers? Snakester SRT10 and SRT10 Coupe Discussions 14 07-21-2004 09:48 AM
Nitrous experts, please help on wiring schematic... Alternative Performance Modifications 17 06-23-2003 08:37 AM
