Old 05-08-2008, 06:41 AM   #1
mach4444
mach4444's Avatar
Default dumbest question ever asked
an over exuberant and frisky girlfriend leaned on my center console (2000 rt/10) and cracked it. she weighs all of about 110 pounds so I guess it was just bound to happen from everything I've read about them being poorly supported.
it's not a big crack but I want to get it fixed before it gets larger. I searched and found a wealth of info on how to repair it. last night I was going to attempt to repair it and ran into a snag.
how do I get the stock shift handle off ?
I know this sounds ridiculous but I couldn't budge this thing. it looks like there is an area for a wrench about halfway down so i assume that you throw a wrench on there and rotate the shift knob area while securing the wrench. I am i missing something ?
even in the service manual it just Say's remove shifter handle.
thanks for any help and please go easy on me.
mach4444 is offline   Reply With Quote
Old 05-08-2008, 06:55 AM   #2
davem
Default Re: dumbest question ever asked
Unscrew it.
96 GTS Twin Turbo
davem is offline   Reply With Quote
Old 05-08-2008, 07:05 AM   #3
It is on VERY tight. Like was said above, just unscrew it. Use good wrenches and grunt as needed. Set beer to the side and get the GF off your lap too.
How about some pics of the frisky GF holding the shift knob after it's off?
I'm sorry. Make me stop...
Good luck with the repair. Big Brakes has a repair for that and there's a write up in the Illustrated Upgrade section too if you're a VCA member.
Old 05-08-2008, 07:07 AM   #4
dinobuster
Push the shifter boot down and you will see the end of the shifter and also a nut you will need to put a wrench on the nut as a hold back and another wrench on the flats of the shifter. Hold the wrench on the nut firmly and the put pressure on the shifter wrench to loosen it.
Stew
dinobuster is offline   Reply With Quote
Old 05-08-2008, 07:08 AM   #5
V10SpeedLuvr
GA VCA President
V10SpeedLuvr's Avatar
Your posts sound more and more like mine every single day. You even have Hooters girls in your avatar, thank God your Viper is black or I'd be reading your posts thinking "I do not remember making this post, I've officially lost my mind" As for the shifter, sounds like you have the right idea. On the McViper, there is a nut underneath the shift handle. Put the wrench on this nut and turn it counterclockwise to break it loose. This will then let you unscrew the handle.
Chad
Old 05-08-2008, 07:56 AM   #6
triblk6spd
On my 99 the shifter handle and knob are one piece. I made the mistake of trying to get the shift KNOB off. Not a great idea.
triblk6spd is offline   Reply With Quote
Old 05-08-2008, 02:58 PM   #7
there is only ONE reason a girl should ever be leaning on a console and im not allowed to say why here. if not, please toss her to the side and find a new one
Old 05-08-2008, 03:01 PM   #8
Warfang
Please! No more talk of taking wrenches to nuts!
97 GTS red/white
Warfang is offline   Reply With Quote
Old 05-08-2008, 03:06 PM   #9
Affatica
CO/UT VCA Member
Affatica's Avatar
Seconded. I too wish to see said frisky g/f.
Affatica is offline   Reply With Quote
Old 05-08-2008, 03:37 PM   #10
BOTTLEFED
ID VCA Member
BOTTLEFED's Avatar
sorry, just had to do it
97GTS B&W: Roe S/C 5#, VEC3, Borla headers, catless exhaust, smooth tubes, T&D rockers, 3.55 gears, RPS flywheel & 6-puck clutch, short-shift kit, untuned
coming soon: N2O
Old 05-08-2008, 05:01 PM   #11
mach4444
mach4444's Avatar
OK so I will attempt to get pics of my gf with the my shifter in hand (sorry I digress).
she is a little camera shy because everything nowadays ends up on the INTERNET for every freak in the world to see.
her theory is the less info out there the better and most of the time I tend to agree.
but my question is this: where does it unscrew from ? it looks like half way down the stock shift handle (the vertical section) the upper section screws into the lower section of the vertical shaft. I held the lower section with a wrench and tried to turn the upper section (that contains the shift knob) and it wouldn't budge.
A previous post mentioned something about moving boot all the way down. down past the halfway of the vertical shaft or do i need to access the very bottom where it mates to the shift mechanism.
the shift knob and upper section of the vertical shift handle seem to be one piece.
thanks
Old 05-08-2008, 07:34 PM   #12
AZTVR
AZTVR's Avatar
Hope this helps answer your question:
Jim
2002 GTS ACR Graphite Gray w/silver stripes
Old 05-08-2008, 07:35 PM   #13
dinobuster
I have attached a picture of my shifter and the nut
Old 05-08-2008, 08:11 PM   #14
SoCal Rebell
SoCal Enthusiast
Originally Posted by davem View Post
Unscrew it.
The girlfriend? I don't think that's possible
SoCal Rebell is offline   Reply With Quote
Old 05-08-2008, 10:30 PM   #15
mach4444
mach4444's Avatar
A picture is worth a thousand words.
Thanks everyone.
Vette guy asked me question about vipers. Twister SRT10 and SRT10 Coupe Discussions 20 01-04-2008 09:37 PM
Never been asked that before! VenomAddict SRT10 and SRT10 Coupe Discussions 26 03-13-2007 05:40 PM
Possibly the dumbest comment Ive ever heard about my car... V10SpeedLuvr RT/10 and GTS Discussions 36 04-07-2006 02:00 PM
Whats the most common question asked? V10SpeedLuvr RT/10 and GTS Discussions 50 05-30-2005 08:33 AM
Top ten Dumbest inventions of the auto industry...Add yours YellowSnake Sneaky Pete's Place 11 08-07-2002 06:13 AM
