Old 05-08-2008, 08:07 PM   #1
SoCal Rebell
SoCal Enthusiast
Default A little help please, 2000 RT/10....
I can't seem to get the speakers in the hood to work What am I missing here, I spent $50K and can't even get the full stereo sound. So what's the trick?
SoCal Rebell is offline   Reply With Quote
Old 05-08-2008, 08:12 PM   #2
IEATVETS
Illinois VCA Member
IEATVETS's Avatar
Default Re: A little help please, 2000 RT/10....
Make sure the ground wire is hooked up properly. If it is, then the speakers may be blown. I have an extra set if you need them.
2000 GTS Steel grey/Silver stripes
1 of 126
Old 05-08-2008, 08:12 PM   #3
MTGTS
FL VCA Member
MTGTS's Avatar
Check the grounds.
MTGTS is offline   Reply With Quote
Old 05-08-2008, 08:18 PM   #4
redlineviper
Are you sure they are still there? Most vipers I have seen only have the speaker grills. I would imagine people have taken yours.
redlineviper is offline   Reply With Quote
Old 05-08-2008, 08:32 PM   #5
SoCal Rebell
SoCal Enthusiast
Old 05-08-2008, 08:40 PM   #6
Viper Wizard
Viper Wizard's Avatar
Exclamation Re: A little help please, 2000 RT/10....
They only come on above 100mph!
CHUCK TATOR
1975-USAF/SAC/KC-135/FB-111
NRA Life Member
Viper Tech Since 1993
Viper Owner 94/RT#902
TATOR'S DODGE SINCE 1914!
Old 05-08-2008, 09:06 PM   #7
Denny Wagner
Ron, you BOZO!!
They aren't speakers...........THEY'RE SUBWOOFERS!!
Denny Wagner is offline   Reply With Quote
Old 05-08-2008, 09:06 PM   #8
radta7
Illinois VCA Member
radta7's Avatar
Dude, check your fuse box. It's in the back under the spare tire. Also, pull the one for the governor. More top end.
Your welcome.
Rob
Roselle, IL
1997 Viper GTS
radta7 is offline   Reply With Quote
Old 05-08-2008, 09:10 PM   #9
Red Snake
Gateway VCA Member
Red Snake's Avatar
You just need to upgrade to a higher quality set like I did. The OEM speakers suck.
97 GTS Red/Black Stripes - Roe S/C
Red Snake is offline   Reply With Quote
Old 05-08-2008, 09:54 PM   #10
bigmike32172
Ron I'm sure if the car has ever been washed the speakers are blown. Most everyone forgets to tape and plastic them prior to washing the car
And this place has wayyyyyyyy better smilies than the Alley. Somebody needs to get off their ass over there and implement some of these smilies from here!
bigmike32172 is offline   Reply With Quote
Old 05-08-2008, 10:20 PM   #11
GTSNRT10
GTSNRT10's Avatar
You guys have it all wrong
It's prob. a one off ACRRT/10
GTSNRT10 is offline   Reply With Quote
Old 05-08-2008, 10:49 PM   #12
C-Note
WA VCA Member
C-Note's Avatar
Check the fader in the stereo, make sure the front-front speakers are turned up, if that doesnt work make sure the speaker wire that comes up from the horn relay is pluged in
Also I heard that the only cars that came with the hood speakers are the black cars, they are so much faster than the other colors that they needed the front-front hood speakers.
Clint / Washington VCA Secretary
05 Copperhead #109 Supercharged 704 RWHP!,98 GTS, 03 Ram, 70 R/T Charger, 58 Chrysler,90 Ramcharger,97 Mark VIII, 04 Fatboy
C-Note is offline   Reply With Quote
Old 05-08-2008, 10:56 PM   #13
onguardjeff
Ron, do you K&N's? I had a friend that got his hood speakers sucked into his K&N's that were loose. It was a hose clamp I think.
onguardjeff is offline   Reply With Quote
Old 05-08-2008, 11:06 PM   #14
rocman
Ron, those are the AC controls, not the radio controls.
rocman is offline   Reply With Quote
Old 05-08-2008, 11:49 PM   #15
kowalski vanishing point
Be sure you roll down your windows if it is a hardtop. The sound insulation qualities in the hard top model are so good that you might not hear the sound with your windows up. BTW the hood speakers were designed for the RT folks to have a better audio experience back in the early days.
kowalski vanishing point is offline   Reply With Quote
Old 05-08-2008, 11:54 PM   #16
Oh I see it is an RT/10. You should be hearing those fine then.
Old 05-09-2008, 01:02 AM   #17
-FROG-
....alot of people don't know....
..............but you can put your weed in there.
-FROG- is offline   Reply With Quote
Old 05-09-2008, 06:03 AM   #18
Denny Wagner
You'd better check "behind the licence plate"..........may be a wire off hidden by the accumulated dirt!!
Better still......have Cutter take care of it!! He's a better mechanic (and road racer) than you are!!
Old 05-09-2008, 06:10 AM   #19
dave6666's Avatar
You are out of speaker fluid.
Old 05-09-2008, 07:07 AM   #20
viperjim
Check the:
Buckle on the Fan Belt
and the Piston Return Springs
They might some how be affecting your speakers.
Best of luck in your endeavor
Jim
2003 SRT10 Stock 11.52 @ 121mph with Runflats
1969 Corvette 427 L89
viperjim is offline   Reply With Quote
Old 05-09-2008, 08:39 AM   #21
prevnine11ownr
Mine worked fine...You have to beat on em.
prevnine11ownr is offline   Reply With Quote
Old 05-09-2008, 08:41 AM   #22
tucker
I think your Vipair is sucking in so much air you just can't hear them.
tucker is offline   Reply With Quote
Old 05-09-2008, 08:48 AM   #23
VENOMIS
NO, NO, NO, you guys have it all wrong. You have to push the PA button (personal Address) on the stereo. This way when your in the parking lot at Hooters everybody can hear the stereo just fine. You tilt the hood and now the sound is directional.
VENOMIS is offline   Reply With Quote
Old 05-09-2008, 11:49 AM   #24
rocman
Turn up your hearing aid!
Old 05-09-2008, 11:52 AM   #25
randall
Ron,
I couldn't hear mine that well either so I re-wired them into the cabin and filled the holes with bondo for a smooth hood for better areodynamics.
randall is offline   Reply With Quote
Old 05-09-2008, 12:08 PM   #26
ACELLR8
WV/PA VCA Member
ACELLR8's Avatar
I am gonna go home and make sure mine work. Never listened closely enough to see if they work, I just assumed they were on.
Ed
1995 Yellow RT-10 (629 RWHP / 824 RWTQ Heads / Cam / Nitrous)
2001 Red GTS (Fitzgerald Motorsports Snake 530)
ACELLR8 is offline   Reply With Quote
Old 05-09-2008, 02:40 PM   #27
vegas guy
vegas guy's Avatar
Back the car into the garage next to the water heater and drain the fuel tank, the extra
light should help you find the problem.
vegas guy is offline   Reply With Quote
Old 05-09-2008, 03:05 PM   #28
viper spray
Post some pics..........
viper spray is offline   Reply With Quote
Old 05-09-2008, 03:06 PM   #29
mad0953
Oregon VCA Member
mad0953's Avatar
You guys are way, way off. Look at your car from the front, maybe from a ladder placed about 10 feet in front of the car..........it's Sneaky Pete's eyes. Face the front of your car, turn 180 degrees around, pull your pants and whitey tighties down, bend over and if your are lucky ol'e Sneaky Pete will give you a snake bite for calling his eyes "speakers".
Two of the people that shaped my life: Kurt Vonnegut Jr. and George A. Romero....thanks guys.
Old 05-09-2008, 05:26 PM   #30
Viperless
MN VCA Member
Viperless's Avatar
No, no, they're passive radiators!
Keith - '09 Graphite Coupe
M&M Headers, Home Built Exhaust - 585 rwhp/565 rwtq
Eurotech Rotors, Motons
Viperless is offline   Reply With Quote
2000 OEM WHEELS/TIRES FOR SALE.........$2000 VIPERCANE RT/10 and GTS Discussions 1 07-07-2004 04:14 PM
2000 GTS, born 8-2000, good date? kgrif RT/10 and GTS Discussions 12 01-07-2004 03:33 PM
ACR Shock Upgrade Pre-2000 or post-2000??? 99 Sidewinder Performance Modifications 1 03-06-2002 01:30 PM
2000 RT/10 Interior and Exterior 0 12-31-1969 06:00 PM
