I have a Roe supercharger with 10lb pulley on a mostly stock engine (1.7 rockers, headers, exhaust, W/M). I tried logging a third gear pull yesterday and was surprised to find that the internal MAP reading on the VEC3 showed a max of only 6lbs of boost. This has me concerned that there is an issue with the supercharger system.
I was wondering if anyone out there with a similar setup could share their VEC boost measurements for comparison. Thanks. |
im sorry, you're not a member here, i cant help you or give you any pointers.....
![]() J/K of course
NOT affiliated with any tuner...
Seems low. You might want to check the sensor settings in the log settings area. My boost signal is set at MPX_US_3.
My 5 pounder with the same set up -- no W/M -- sees 7+ with the boost creep......just looking quick at a couple logs. The roller rockers make it breathe a little better, reducing a liitle pressure (and heat) My 5 pounder with no 1.7s has seen a little over 9 pounds with boost creep. Steve |
It is low...even for a non member.....Don't mind Plum, he is good for a dose in an hour and we can take the jacket back off.
Here is my 5lb unit, without W/M (just like Steve's) in fact Steve and my car are the same year. Tops out at 9.26 lbs and got to your 6 lbs by 3.5k RPM.... Used Unit? From where? Been rebuilt? Who installed? ![]()
2000 GTS, Roe 5lbs, RR, VEC3, JMB Performance intakes, Dual .50 cals, Corsa Cat Back, Innovate LC-1 WB Last edited by DAMN YANKEE; 05-11-2008 at 11:10 AM. |
Hello...earth to mnviper....come in please....are you still out there.....
2000 GTS, Roe 5lbs, RR, VEC3, JMB Performance intakes, Dual .50 cals, Corsa Cat Back, Innovate LC-1 WB |
DY, Thanks for the response. This is a new Roe unit installed last fall. I wanted to confirm that this is an abnormally low number for an on-road pull with a 10lb pulley before I pursued it further. I discussed with my tuner today, he gave me some some things to check on before we point the finger at the blower (belt tension, etc). BTW, your posts on logging and the tutorial have been quite helpful in getting the VEC software setup.
ID VCA Member
my readings are low (8# max) on my Roe10# and Sean says it is because I'm running rich
he sent me a new prog. I'll try it out tomorrow
97GTS B&W: Roe S/C 10#, VEC2, Borla headers, catless exhaust, smooth tubes, 3.55 gears, Fidanza flywheel, short-shift kit, untuned coming soon: N2O
Your in good hands, if you have widebands and can log, send up some logs.
#9 | |
You know, or should know that even with a slight tweak from Sean that the tune still isnt going to be as precise as taking the car to a dyno under the eyes of someone like Sean to tweak the tune to fit your car based on what the dyno is showing. Why spend all that money for horsepower you know your not optimizing. Just my .02 |
#10 | |
Steve |
ID VCA Member
I was running 7-8 AFRs so that is why Sean had to change the tune I got from him originally
I just needed something a little closer to work with for my own tuning
I'm curious as to how the rich A/F can drop the boost readings. Is this due to the cooling effect of the extra fuel?
ID VCA Member
ask Sean
thats just what he told me |
| Paxton Supercharger 10lb pulley | PJJP | SRT10 and SRT10 Coupe Discussions | 74 | 05-13-2008 12:49 AM |
| Wanted...10lb Roe s/c pulley | 1TONY1 | RT/10 and GTS Discussions | 2 | 09-09-2007 03:47 PM |
| +10LB + 70MM TB + PBJ = 624/698 | grnsnake | RT/10 and GTS Discussions | 18 | 02-22-2007 11:34 PM |
| Drag times, fuel questions with 8lb/10lb Pulley on Roe blower | Schulmann | RT/10 and GTS Discussions | 14 | 07-28-2006 08:16 AM |
| Help Vec 1 low reading | ViperDave | RT/10 and GTS Discussions | 5 | 06-15-2004 11:23 AM |
