Old 05-13-2008, 10:59 AM   #1
jay01m
Default Windshield Leak
Anyone have this issue, and if so how did you resolve it? I'm considering having it resealed, but am hearing that there is no guarantee that they can pull the windshield without breaking it, in which case I'm looking at well over $500 to fix the issue. What do you think my best options are. Thanks.
Jason
Hampton Roads, VA
jay01m is offline   Reply With Quote
Old 05-13-2008, 01:15 PM   #2
AHudson777
AL VCA member
AHudson777's Avatar
Default Re: Windshield Leak
Wow, had the same problem. Mine being about 3" left of centerline (driver's side). Got the same quote about pulling the glass. What I did - -
1. Hot day outside, let car sit.
2. Used nylon 'spatula' or body-filler spreader with rounded corners to 'wedge' between body and windshield gasket.
3. With spatula making room, laid in a bead of Windshield Sealant (I think Mr. Gasket; doubt if it makes much difference) all the way across. I moved spatula and Sealant at the same rate attempting to be smooth. (Note the word "attempting".)
4. Wiped excess Sealant with "Pre" but considered letting it dry and cutting, but I don't trust my razor skills that much.
No more leaks. Others with actual windshield experience may offer better, more-detailed advice. (We hope!)
AHudson777 is offline   Reply With Quote
Old 05-13-2008, 05:32 PM   #3
jay01m
Mmmm, that might be worth trying. It's not terribly difficult to get under that rubber molding. With this car, I want to make sure things are done right, but if I can get a small bead of silicone in there, that might do the trick.
Need to save my pennies, got to get some boost soon!
OBDII code P0456 - Evaporative emission leak detected (very small leak). AviP Driven 1 10-14-2005 05:08 PM
where can i get a windshield? BIGBADCJ RT/10 and GTS Discussions 16 12-12-2003 02:54 PM
Decal for SRT windshield? Viperfreak2 SRT10 and SRT10 Coupe Discussions 14 08-08-2003 02:32 PM
How much is a RT windshield? MadMaxx RT/10 and GTS Discussions 4 08-02-2002 05:01 AM
97 OEM WINDSHIELD RockyTop RT/10 and GTS Discussions 2 02-12-2002 05:14 PM
