Old 07-02-2008, 07:07 AM   #16
Default Re: Viper stalling
Originally Posted by Rheeder218 View Post
alright changed the battery, grounded the positive cable, new TPS, looked at the IAC and it looked clean. So im guessing that this could be a MAP sensor?
Although a clean IAC is a good sign, it could still be sticking.
Theory that could be wrong... If the IAC closes as you move past idle and the TB's take over, and then then the IAC does not re-open at idle, then the car would die being starved for air. Don't know if that's how it all works though, just an idea. But hey, the part is 14 years old. Put a new one on just because?
Also, did you set WOT after the PCM reset? If that is needed on your Gen 1.
Old 07-02-2008, 12:08 PM   #17
mangle
If you haven't resynched the TBs yet (I may be blind, but I haven't seen that you've done this), I'd try that before spending any more money. Just push the grey buttons, pull the cable back, then get in the car and push the pedal to the floor.
Black 94 RT/10... stock for now
2002 Suzuki SV-650 race bike, more GSX-R than SV
mangle is offline   Reply With Quote
HELP My Viper is Stalling when down shifting?????? Da1cop RT/10 and GTS Discussions 17 01-10-2007 05:24 AM
Viper Was Stalling Today Dimitrios RT/10 and GTS Discussions 10 10-28-2004 08:58 PM
Viper is stalling, no idle! jp RT/10 and GTS Discussions 3 05-16-2002 12:19 AM
viper is stalling out 1 Bad Snake RT/10 and GTS Discussions 13 02-13-2002 12:46 PM
CAR STALLING mbviper Interior and Exterior 1 06-21-2001 01:06 PM
