Old 06-11-2008, 10:58 AM   #1
Rheeder218
Default Viper stalling
Our 94 stalls at the stop sign.
Here is how it goes. Start car up back out of garage cruise down street to main road. Get on main road and cruise between 35 and 40 then come up to the stop sign shift in to neutral and push in brake pedal get to sign then the car seems to struggle to stay running then it will either bounce back up in to idleing RPM range or just shut the car down. I have replaced the TPS sensor that didnt help out at all. I havent had a chance to hook it up to a OBD computer yet. Has anyone ever experienced this problem? It does have the 185 thermostat in it, KN filters, smooth tubes and that is it. Thanks for the help.
Rheeder218 is offline   Reply With Quote
Old 06-11-2008, 11:02 AM   #2
Default Re: Viper stalling
Idle Air Controller?
TPS ground?
Reset PCM?
Battery?
Old 06-11-2008, 11:32 AM   #3
99 R/T 10
99 R/T 10's Avatar
Dave hit all the best bets:
Idle Air Controller and TBs, clean them as best you can with some carb cleaner.
TPS ground? Sometimes its not as good as it should be, double check it and enhance.
Reset PCM? Sometimes by disconnecting the PCM for 15-20 will fix the problem. It resets back to original parameters and relearns.
If none if these fixes work, change out the battery even though it may still seem good. A low battery does funny things to the Viper's electronics.
Old 06-11-2008, 11:52 AM   #4
mangle
When mine did this, it was because the throttle bodies were badly out of sync.
Black 94 RT/10... stock for now
2002 Suzuki SV-650 race bike, more GSX-R than SV
mangle is offline   Reply With Quote
Old 06-11-2008, 01:33 PM   #5
Rheeder218
i reset PCM.
We were guessing the idle air controller. we'll check that out
Old 06-11-2008, 01:40 PM   #6
Jeff Torrey
Jeff Torrey's Avatar
My 92 was doing that and Chuck Tator told me to change out the Map Sensor. I did that and if fixed the problem.
I would call him 914-763-3136
Old and Red
NH Lic. Plate 92RT10
Past President- New England VCA 2006-07
Jeff Torrey is offline   Reply With Quote
Old 06-11-2008, 01:48 PM   #7
DaytonaViper
Unless you replaced the battery lately or a daily driver.......my bet is on the battery.
DaytonaViper is offline   Reply With Quote
Old 06-11-2008, 11:35 PM   #8
DC Performance
SO CA VCA Member Site Supporter
DC Performance's Avatar
This is a simple adjustment to the throttle cables and the use of a set screw to lock the cables to prevent the problem in the future. Call me. I have the parts and can tell you how to correct it.
Dan Cragin
President, DC Performance Inc
310-841-6996
www.dcperformance.com
Old 06-11-2008, 11:47 PM   #9
cyaford
My car was doing the same thing last year, and the year before. I could back out of the garage and drive down the road just fine. When I'd come to a stop at a light or a stop sign, the car would idle really low and sometimes die. I thought for sure it could NOT be the battery, even though numerous people on this forum said it was one of the most likely problems. I reluctantly installed a new battery and the problem was gone! My Viper unfortunately does not get driven much, and I never had it on a battery charger. After my second battery replacement(same symptoms) about a year later to the day, I got a new battery under warranty from Autozone, went home to install the battery, and immediately ordered a battery tender from PartsRack. I'm fairly certain my battery problems will now no longer be a yearly occurrence.
1997 Viper GTS
Old 06-12-2008, 11:13 AM   #10
Rheeder218
Well then ill try the battery whats a good battery to get?
Old 06-12-2008, 01:31 PM   #11
ViperJay
New England VCA Member
ViperJay's Avatar
i just installed a diehard last week. i have never had a diehard die on me. it made a very noticeable difference.
1995 Black RT/10
ViperJay is offline   Reply With Quote
Old 06-12-2008, 02:09 PM   #12
Interstate Batteries Megatron.
A Texas based company...
Old 06-13-2008, 08:38 PM   #13
Rollin4
Rollin4's Avatar
Remove the IAC (careful not to damage or loose the O ring gasket) use a cleaner and clean the carbon from IAC and throttle bodies. Adjust throttle bodies and Happy Motoring. Problem solved.
Rollin4 is offline   Reply With Quote
Old 06-13-2008, 09:10 PM   #14
-FROG-
I see alot of good things mentioned. I would also recommend IAC, MAP Sensor and sync Throttle Bodies.
-FROG- is offline   Reply With Quote
Old 07-02-2008, 06:49 AM   #15
Rheeder218
alright changed the battery, grounded the positive cable, new TPS, looked at the IAC and it looked clean. So im guessing that this could be a MAP sensor?
HELP My Viper is Stalling when down shifting?????? Da1cop RT/10 and GTS Discussions 17 01-10-2007 05:24 AM
Viper Was Stalling Today Dimitrios RT/10 and GTS Discussions 10 10-28-2004 08:58 PM
Viper is stalling, no idle! jp RT/10 and GTS Discussions 3 05-16-2002 12:19 AM
viper is stalling out 1 Bad Snake RT/10 and GTS Discussions 13 02-13-2002 12:46 PM
CAR STALLING mbviper Interior and Exterior 1 06-21-2001 01:06 PM
