#16 | |
Reality check: Engine temprature after 10 minutes of running. 220 degrees top radiator hose 195 degrees lower radiator hose 165 degrees I'm tearing the watter pump out tonight. Even if I don't find anything wrong I'm going to try to go to a smaller watter pump pully. Of course change the Serpentine belt too. Anyone out there know where I can get a smaller watter pump pully or what application would fit? I want to reduce the diameter by 1/2 inch.
Bolt |
Should not. The O2 sensors adjust mixture ratio and the ethanol has a higher latent heat, so it should actually run cooler.
Tom, Fuels & Lubes Geek of the Realm |
Please clarify this - one hose should be hotter than engine, the other cooler than engine (assuming the engine temp is measured by a guage? )
I don't know much about this but could the O2 sensors be reading the information incorrectly and either making the car run rich or lean and creading the motor to run differently? Is this why we all see the gas milage decrease with the gas which has ethanol in it? Do we need to have our computers reprogramed to compensate for this as more ethanol is added?
Bolt |
#20 | |
The 220 came from the guage (Engine temp) the other two temps came from my hand held laser thermometer at the upper hose and lower hose on the radiator.
Bolt |
#21 |
Reset PCM time, for new fuel?
#22 |
Than that is something simple to try. Thank you.
Bolt |
#23 | |
A high delta T across the engine can be caused by low coolant flow rates. So either a pump issue, a restriction (like a stuck thermostat or kinked hose) or something of that nature may be occuring. It can also be caused by excessive heat rejection to the coolant. If your engine is running ok I am doubtful as to that. However, compression leakage to the coolant is a low probability cause (head gasket, erosion of head water jacket, etc). My guess is on the flow side if the heater performance is poor. Have you checked the aftermarket thermostat operation? That would be my first guess. |
#24 | |
Bolt |
#25 | |
#26 |
You mentioned it heats at idle, the radiator is clean, coolant is good etc.
This is not an ethanol issue, otherwise the entire nation would be overheating since most 91 octane is around 10% which is what I assume you mean by ethanol. The blend yes? Air in the system is a high possibility and you said you have burped but I would re-do that, the system has been completely apart and you may have trapped air that did not rise the first try. Remove the water pump if nothing else makes sense, impellers can come loose, altho not common. Yes there was a small rash of them a few years ago. Air flow, you have no changes in air passing over the radiator, like, the fan is coming on in your garage, you have not opened up an areas around the radiator to allow air to flow around it etc. Hope you get it fixed, Bob Woodhouse. |
#27 |
turn your heater on and see if that lowers the temp any. If so then you are just no getting enough airflow thru the rad.
#28 | |
The only other idea is a collapsed hose - the inner lining has separated from the stringy core and is flopped into the coolant path.
#29 |
Good suggestions keep flowing in. Water pump is 1/2 way out. Working around all the SC stuff is a PITA. But I love what the SC does for me. I'll keep checking things out and report back.
Side note: I heard all gas over 91 octain contains the full 10 percent ethanol. I don't know if this is true but I'll be running high octain in my other cars to test his out for awhile.
Bolt |
#30 |
Water pump looks like it's in great shape.
Now I'm looking for a water pump gasket on a Friday evening. No luck so far.
Bolt |
| Help: Strange restart problem | ByteMe | RT/10 and GTS Discussions | 3 | 04-16-2007 02:25 PM |
| Help w/ heating & A/C problem | snampro | RT/10 and GTS Discussions | 11 | 08-19-2006 07:25 PM |
| strange stereo problem... help! | Andy 98 RT/10 | RT/10 and GTS Discussions | 1 | 04-07-2005 08:05 AM |
| Strange Problem | RavenFan_94 | RT/10 and GTS Discussions | 9 | 09-15-2003 02:34 PM |
| Strange problem,easy fix | Frank 03SRT | Archive Management | 0 | 12-17-2000 03:38 PM |
