Here is my setup. I used a larger catch can from Summit Racing and put it where my windshield washer bottle was and routed the stock Y-plumbing from the two valve covers over to it. The benefit of putting the can on the drivers side is that there is less tendancy to pull in blowby gases through the cabin air intake if you vent the blowby into the engine compartment instead of routing back to the engine air intake.
Having said that, I would not recommend routing the output of the catch can back to the intake. The reason is that there will still be oil vapor passing though the catch can and that tends to lower the effective octane of your A/F mix and increases the air intake temperature and therefore increases the risk of detonation. Given your recent experience, I'd error on the safe side. --- Ken
There you go again Ken, showing off that engine!!
Current Stable: '02 FE Viper (#270) Daytona 24 (#7); '07 Denali XL, '06 HD FLSTNI, '05 Ram SRT10 YF (#54), '05 Jeep TJ Rubicon, '04 Saleen Cobra S-281 Mystichrome Speedster (#104), '03 Honda V-6 EX Coupe, '03 Jaguar X Type, |
i totally agree with ken, putting those vapors BACK INTO the engine thru the intake is NOT good. its gonna LOWER your octane and INCREASE your likelihood of detonation.
#20 |
I have to, I don't have all that exterior bling like you do.
Heck, I am thinking about just taking my hood off this year or cutting a hole in it and putting a big sheet of plexi in there like the ZR1. ![]()
#21 | |
Your engine compartment does look sweet. FLX109
96 Blue/White GTS 96 Blue/White Indy Ram Ride Fast Or Be Last |
#22 |
I could stare at that engine bay for hours
![]() thanks for the advice
97GTS B&W: Roe S/C 5#, VEC3, Borla headers, catless exhaust, smooth tubes, T&D rockers, 3.55 gears, RPS flywheel & 6-puck clutch, short-shift kit, untuned coming soon: N2O
#23 |
#24 |
Actually Dave that was my plan all along. What better way to make your engine to pop than to photograph it in front of a very drab background that doesn't fight for attention with the foreground?
#25 | |
Too bad everyone can't see your engine when you're out and about!
#26 |
I've spent a lot of time experimenting on both blower and turbo cars, and agree with Dan, these setups are the best as they do a great job of pulling the oil out of the air before they vent (they are full of screens and plastic mesh), and they drain the oil back into the crankcase. No emptying puke cans.....
96 GTS Twin Turbo |
#27 | |
Bill
#28 | |
Also, where did you get them? Thanks!
'98 Viper RT/10 JMB intake, B&M, hi-flow cats, Borla, SCT tune, 18/19 IForged/PS2's '96 Caprice 9C1 '08 Hummer H3 |
#29 | |
Gateway VCA Member
I almost wish I wouldn't have seen that. |
#30 | |
The first emmissions issue is removing the Pollution Control Vavle, that's illegal and doesn't recycle the oil vapors back into the engine. The second emmissions failure is that you're removing unburned oil fumes and molecules from the inside of the engine and depositing them into the thousands of degrees exhaust where it is burned, causing pollution and unburned hydrocarbons. Chysler originally published this particular modification the old Hustle Stuff performance book back in '71 I think. It was also published in the Direct Connection books after that. Listed as a "race only" modifications for the reasons I listed above. Nearly all Race cars come with that modification. Not legal in any state, although it's also illegal for the crankcase to be open to the atmosphere. My car did burn blue often when I used that mod on my cars. It also sucked enough oil out of the engine that I had to add oil because of it. If there's no baffle plates under the valve cover opening the rocker arms will throw oil droplets right into the tube. Also illegal, I have an electric vacuum pump to a catch can and I notice that I do use a little oil. Of course there's No emmissions testing way out in the bush here. Ted
| Any experience with Mr. Gasket crankcase Evacuation System | vegasviper | RT/10 and GTS Discussions | 9 | 08-14-2006 11:51 AM |
| crankcase ventilation | chex | RT/10 and GTS Discussions | 7 | 11-29-2005 07:53 PM |
| What method of positive crankcase ventilation do you use? | SapphireGTS | RT/10 and GTS Discussions | 0 | 10-07-2003 01:08 PM |
| Crankcase Breather System | New Products, Supplier Specials, and Group Buys | 124 | 12-31-1969 06:00 PM | |
