Old 06-25-2008, 03:23 AM   #1
1Need4Speed
Houston VCA Member
1Need4Speed's Avatar
Default Cpe Turbo Installed
It's been a while since I posted the CPE Turbo install on my 2001 Sapphire GTS with stock motor. I ran into some personal issues in my life and had to put the car on hold for a bit...
Anyway, here's the update:
I took some time off and drove up to Chicago to meet up with Paolo to pick up the car a couple of weeks ago. He had called and said he completed the install for the turbo side mount system for my car.
When I got to Paolo's shop the car was up on the lift so that he could show me the system from under the car for starters. I will have to say that I was nothing but IMPRESSED...The install was precise, clean and the attention to detail was perfect! From the upgraded fuel system with the larger lines, using braided lines for the meth install, upgraded half shafts, Spec 3 Plus clutch upgrade, Eibach springs, side mount intercoolers and the piping install for the turbo system...WOW!
We dropped the car down from the lift and inspected the intake tubes, custom fuel rails, crank case breather, turbo manifolds and turbo install. The welds were unbelievable on the turbo manifolds and intake piping that Paolo designed.
I decided to do the side exit exhaust system utilizing actual Gen 1 sill covers. Paolo hand built the 4 inch stainless exhaust and custom fabricated a 5 inch polished tip.
The install of the system definately exceeded my expectations!
We decided to go for a spin at that point (who wouldn't!)...
I started the car and must say was blown away from the tone of the exhaust and the spool of turbo's! We took the car out onto some back roads that he directed me. The Eibach springs were a perfect ride for the car and made the car handle in with a race car ride...The clutch was smooth and almost had a stock feel to it.
We started out with duing 4th gear pulls to see how the car reacted and to keep the clutch from over working since it needed a break-in period. This is like nothing I experienced! As the turbo's spooled the power was unbelievable! The tunnel vision and pressure from the pulls will need some time to get use to
The side exhaust was a thrill and sounded almost evil under throttle and boost. We made pull after pull for 3-4 hours and with the AEM plugged into the laptop to data log each pull. There were no issues with overheating. The boost was set at 10 pounds and the system was very rich to keep from detonating.
There is about another 100 plus horsepower wants we get the car tuned with the Meth when I bring it back to Houston. We can then get it on the dyno can do some more timing increases and back off of the fuel a bit since the Methanol will be turned on and see what kinda power this thing makes.
Now back in Houston, I've been driving around in this crazy heat for 1-2 hours at a time with no issues what so ever accept refilling at the gas station The spooling of the turbo's around town is SOMETHIN! The wine of the turbo's cruising around and then under boost..DAM!
I'll be meeting with Jimmy Voorhee's this weekend to tune the car. I'll post some dyno pulls and looking forward to some addtional power with the Meth and great numbers.
I will have to say this about my experience with CPE Turbo. Other than the delay on my end...the experience with Paolo and his enthusiasm for the project and passion for these Vipers has been wonderful...GREAT guy and this dude know's this car hands down! He has built a great kit for our cars and this is just the beginning power level for my project. It will be some time before I decide to take it to another power level with this system.
If you have some kind of mod you want to do to your car and have some extra cash...you gotta get one of these dam things! I can't stop sneaking into the garage to take glimpses of my new beast and know that my car has twins now and lots of joy rides to take
Bruce
Check out these pics at Paolo's place...beautiful...enjoy!
Bruce
2001 Sapphire GTS CPE Twin Turbo
1Need4Speed is offline   Reply With Quote
Old 06-25-2008, 05:14 AM   #2
Default Re: Cpe Turbo Installed
congrats. get it tuned and enjoy it
510 Stroker, Greg Good heads, DLM Paxton, Rebuilt and Tuned by DLM. Still need more boost......
Old 06-25-2008, 06:38 AM   #3
FATHERFORD
FATHERFORD's Avatar
Good to see more of these kits on the road. Pretty sure that's the setup I'm going with next year.
Old 06-25-2008, 08:26 AM   #4
Simms
Simms's Avatar
Beautiful! Congrats.
96 GTS - Roe S/C: 753rwhp, 794 rwtq
Built and tuned by Macedo Motorsports
Simms is offline   Reply With Quote
Old 06-25-2008, 12:01 PM   #5
JGK95
Congrats Bruce!!
JGK95 is offline   Reply With Quote
Old 06-25-2008, 12:41 PM   #6
IEATVETS
Illinois VCA Member
IEATVETS's Avatar
Paolo is a great guy and will treat you right everytime.
Did you happen to change the pistons or do you still have the casties in there?
Post dyno #'s when you can.
2000 GTS Steel grey/Silver stripes
1 of 126
Old 06-25-2008, 02:42 PM   #7
hou99gts
Houston VCA Member
hou99gts's Avatar
Looks great Bruce - you will have to take me for a spin sometime.....
hou99gts is offline   Reply With Quote
Old 06-25-2008, 04:00 PM   #8
1Need4Speed
Houston VCA Member
Stock bottom end...that's why I went with the Meth system.
I want to enjoy the power first then go from there. It will take soNext years project which will be to pull the motor and go through it.
I should have some dyno numbers in the next couple of weeks to post for you guys.
Bruce
Bruce
Old 06-25-2008, 04:02 PM   #9
1Need4Speed
Houston VCA Member
What part of Houston are you in? It says NW Houston. I'm close to the Champions area so let me know and we can meet up.
There is a car show by Gleannloch Farms every Saturday around 6:30-9ish. I should be there this weekend if you want to meet there.
Bruce
Old 06-25-2008, 04:09 PM   #10
hou99gts
Houston VCA Member
hou99gts's Avatar
I met you at the last RSI meet before they closed. My name is Eric and I had the 99 Silver GTS with Black iForged wheels. I live 2 minutes from RSI in LOEN.
Unfortunately I am busy this Saturday night, so I'm gonna have to take a rain check.
Old 06-25-2008, 05:12 PM   #11
1Need4Speed
Houston VCA Member
Hey Eric how's it going? I remember the silver GTS and the wheels...nice setup and attention getter.
I'll keep you posted when me and the other Viper boys hit the town. Should be soon
Take care
Bruce
Bruce
Old 06-25-2008, 05:55 PM   #12
Paolo Castellano
Bruce, does this look and sound familiar? LOL!
YouTube - Castellano Twin Turbo With 4" Side Exhaust
YouTube - Castellano Twin Turbo Viper Idling on Grass
It has been a pleasure doing business with you!
I hope to get back to Houston soon!
Paolo Castellano is offline   Reply With Quote
Old 06-25-2008, 11:24 PM   #13
TOOOFST
TOOOFST is offline   Reply With Quote
Old 06-26-2008, 09:38 PM   #14
1Need4Speed
Houston VCA Member
That's the sound I hear every night now
Bruce
Old 06-26-2008, 10:03 PM   #15
Kenneth Krieger
Arizona VCA President
Nice car! Be careful.....point her where you want to go, and hang on.......!!!
HorsepowerFreaks Turbo M3 vs Single Turbo Supra Videos Chris B Sneaky Pete's Place 5 01-17-2007 05:07 PM
***** TWIN TURBO VIPER VS TURBO HAYABUSA VIDEO ***** GARY J RT/10 and GTS Discussions 19 05-07-2005 02:24 AM
Any Interest in a TWIN TURBO VIPER PACKAGE for under $ 20 Grand INSTALLED??? Tom Welch Performance Modifications 48 04-19-2002 04:12 PM
Any Interest in a TWIN TURBO VIPER PACKAGE for under $ 20 Grand INSTALLED??? Tom Welch RT/10 and GTS Discussions 10 04-08-2002 08:47 AM
Viper vs. Porsche 944 Turbo (or Turbo S) Performin Norman Archive Management 3 03-29-2001 09:43 AM
