Ever since I have got it back I haven't had the time, or the weather was not cooperating to be able to test the system out.
Also, sorry people if the car is a little dirty. I haven't had the time to do a complete detail on a car I like to drive a lot.. First a small photoshoot... ![]() ![]() ![]() ![]() ![]() Two 15lb bottles with temporary bottle heaters. Nitrogen assist system, bottle openers, and some air brush work will come soon. ![]() ![]() The bottle setup was designed so that I can just unhook the main feed line and one connector and the entire back half of system will come out in one piece. Leaving me an empty trunk for long trips. ![]() Trick Performance P and V gauges. These monitor several key components of the engine, including the FJO wide band. The gauge is a progressive controller as well. ![]() Prototype switch panel. The anodized black and laser etched panels finally got shipped out yesterday. ![]() The connection to the wide-band is in easy access reach curled up into the fuse panel area. ![]() Dedicated fuel cell. 116 octane will be going in here. ![]() The money shot. Nitro Dave's Nitrous Outlet plate kit for Gen 1 and 2. In this shot is also the "Big show" purge solenoid along with the fuel pressure gauge for the dedicated. ![]() You can see now how the purge is setup through the NACA duct. When the front of the hood is pushed down, the tubes slide right into the naca duct. It has just mm of clearance. ![]() During the install, I found out I have an aluminium fly wheel, B&M shifter, speed control box(for gears), high flow cats with magnaflow mufflers(I know I had edelbrock longtubes). I seem to find out more and more stuff done to this car every time I work on it. Here is the complete nitrous install list... V gauge P gauge 2-sensors Pigtail FJO wide band 4001 Harness to adapt Wideband to gauge Sensor Bung Graves Muffler Automatic Bottle Heater Heater Element Relay and Harness 2 pin weather pack connector Plate system with 15lb bottle Extra 15lb Bottle Bottle nut Bottle nipple 2-4an 1 ft hoses -4x-4x-4 NX Y Bottle brackets Nitrous Filter 2 NHRA Fittings Dedicated Fuel system NX Fuel Pressure gauge for dedicated -6 manifold 1/8x-6 fitting Big Show purge 1/8x-3 90 1/8 female x -3 strait 3 ¼ washers 3ft -3 hose 2ft 3/16 hard-line 4x -3 b-nuts and sleeves -3x-3x-3 NX T Relay and harness Sheet of plywood 2 cans of glue Sheet of carpet 2 -8 strait hose ends 2 -8 hose ends black 2 -8 180 hose ends black 2 -8 bulkhead black 2 -8 bulk head nut 1 ft -8 hose Battery Bolt Grommet set Grommet set Electrical tape Ring terminals Disconnect 8 fuses Wire loom Heat Shrink Terminals Zip ties Wire Bolts, nuts, washers 2x 4 way fuse block 1x 6 way fuse block 3 x 4 way weather connector 2 x 3 way weather pack connectors 1 x 2 way weather pack connectors Custom switch panel When I have time, I will post up the complete install. Lot's of pictures was taken and there should be a very detailed discription of what all was done.
1992 Mustang Notch - Turbo drag car 1997 Viper GTS - Weekend Cruiser 2004 F-150 XLT - Vortech'd daily beater Last edited by FATHERFORD; 06-27-2008 at 07:30 AM. |
Looks great! Nice and clean. Looking forward to the right up. Thanks!!
That looks wicked-clean, man! I especially like the attention to detail in the cabin; the ashtray switchplate, hidden wideband connection and A-pillar gauges are trick. Note to self; if I see a red GTS with black powdercoated wheels rolling around my neck of the woods, do NOT honk the horn 3 times.
Looks great!
Early 1993 Viper RT/10 w/Antennae ("RC/10") VEC3, Magnaflow Mufflers, Cat Delete, Roe Racing Smooth Tubes, K&N Filters, 2002 Wheels, Thermostat, Upgraded Plugs/Wires, Flux Capacitor |
nice setup. do a write up, it should be in the how to section looking that clean.
nice job. and ditch the nitrous filter
Very nice!
I really like those gauges I'm surprised at how similar our setups are - and we have never even seen each others' ![]() Let us know how those outlet plates work out. I'm very interested in them to finish up my setup. Also, you need to start selling those switch panels. I have been trying to fit mine into the ash tray but haven't found a clean look yet.
97GTS B&W: Roe S/C 5#, VEC3, Borla headers, catless exhaust, smooth tubes, T&D rockers, 3.55 gears, RPS flywheel & 6-puck clutch, short-shift kit, untuned coming soon: N2O
#6 | |
Nitro Daves Nitrous Outlet should be getting 5 of the anodized switch panels in stock any day now.. One is mine. Should look something like this BTW there is over 80 hours into this install between two people. I hope enough pictures were taken to full explain all the details went through to do this. Here is some info on the P and V gauges P gauge Progressive controller (time or rpm based). RPM window switch. Wide-Open-Throttle detection when used with factory TPS or WOT switch. Supports Fly-by-Wire TPS rising or falling. 5 Point variable Progressive ramping (time or rpm based). Shift Light. Rich l Lean Cutoff (when used with a wideband). Air/Fuel inputs Digital or Analog. Multiple wideband capabilities. Heater controller. First gear lockout / delay. 8 different Main Viewing screens. Programmable Power UP screen and Arm screen. Multiple pressure choices. Pressure display ( Boost, Nitrous, Oil or Fuel). V Gauge The V Guage replaces the following: 1 Nitrous Pressure Gauge (with optional sensor). 1 Nitrous Pressure Shut Down Switch. 1 Fuel Pressure Gauge (with optional sensor). 1 Air/Fuel Gauge (Instead of Fuel Pressure Gauge/ FPSS). 1 Air/Fuel Shut Down Switch (turns nitrous system off if running lean or rich). 1 Fuel Pressure Safety Switch or FPSS. 1 Nitrous Heater Toggle Switch. 1 Heater Control Pressure Switch(with optional sensor). 1 Digital Bottle Weighing Scale. Here is a short video of them turning on. I'm trying to get myself real familer with them and I'll do a how-to video. YouTube - Trick Performance Nitrous Gauges on a 1997 Viper GTS
1992 Mustang Notch - Turbo drag car 1997 Viper GTS - Weekend Cruiser 2004 F-150 XLT - Vortech'd daily beater Last edited by FATHERFORD; 06-27-2008 at 09:43 AM. |
I swear I saw a spec of lint on your trunk carpet. I'd tear out the whole install and redo it with some pride.
| Need help with Nitrous install - wiring | klamathpro | RT/10 and GTS Discussions | 2 | 04-16-2008 09:16 PM |
| Nitrous Install | 01 RT SNAKE | RT/10 and GTS Discussions | 18 | 11-24-2007 09:16 PM |
| Nitrous install | ohiodoc | RT/10 and GTS Discussions | 11 | 11-05-2005 08:27 PM |
| Has anyone done a nitrous install on one of the SRT-10 Vipers? | Snakester | SRT10 and SRT10 Coupe Discussions | 14 | 07-21-2004 08:48 AM |
| Pics of Nitrous Express Install | ACELLR8 | RT/10 and GTS Discussions | 24 | 05-06-2003 03:40 AM |
