NE VCA Member
I am looking to replace my stock fuel pump. I am looking for a direct drop in pump that is better than the oem. Is the Walboro 255 bigger/better than stock? Is it a drop in replacement? Ido not want to add multiple pumps or returns lines etc. Is there one available that is better than stock. I may be maxed out with the current stock pump and the MSD boost a pump at 700rwhp with a 10lb Roe blower and water meth. Any info/suggestions would be great. thanks Tim
no its not bigger or better than the stock pump, The stock pump is good for 600-650 Hp. The 255 is good for about 500 hp.
Snkbyt....what is your reasoning for the larger capacity pump? Is your car S/C'd? If so, it would require an upgrade in the fuel system and the 255 would fall short by a mile, and would be unnecessary for a stock or relatively stock car even with upgrades ie: headers, intake smooth tubes and filters, 1.7 RR's, etc.
The stock Gen II pump is actually closer to 200 lph, the 255 is an upgrade. I am running a single 255 with BAP at over 850 hp on nitrous. I log fuel pressure and the pumps holds up fairly well.,
Jack B 10.2 @140 (1.7 sec 60') 1.45 (best 60') |
#5 | |
NE VCA Member
I am sure there are people running S/C cars with one pump and making over 700 hp. I was hoping to hear from the people who are running this set-up. Roe says there are most definately S/C cars that are making over 700 rwhp with one fuel pump, a boost a pump and water meth. This is what I like to do. I had previously made over 700 hp with the stock pump, MSD boosta pump and water meth, before i experienced a lean condition over 5000rpm. I was going to replace the stock pump and replace it with one pump that was better than stock. |
i imagine there ARE guys doing it but how close to that edge do YOU wanna run ? i think you're right on it at that point. one little hickup and you are in trouble.
#7 | |
99 Viper (Tubes&filters, Full TNT exhaust, T&D's and other goodies) Macedo Tuned!!!! See y'all at VOI 10!!!!!!!!!!!!!!!! |
#8 | |
NE VCA Member
How much rwhp are you making without the nitrous? Just curious how much the walboro 255 with the boost a pump will support. |
#9 | |
#10 | |
NE VCA Member
Who sells the Walboro 255 pump? Is it a drop in unit that replaces the stock pump?
#12 | |
probably correct, I have a gen 1 and from what I have read they Gen 1's flow slightly more than gen2's. I have read alot that the 255's are great pumps but they are not as robust as the oem pumps. Just look at the construction... the oem pumps run alot cooler an and are overengineered. the 255's are perfect for supplemental or in parallel with other 255's From what I have read on turbomustangs forums they are not reliable for over 500-550hp full time applications. Maybe with the BAP it would be ok. |
S. Fla. VCA Member
Please note: if you utilize the Walbro 255 lph internal pump, make certain it has the "HP" efficiency. That would mean High Pressure for boosted or BAP applications. Standard 255's drop off efficiency under higher pressure loads.
If you need the 255 lph "HP" internal pumps we have them in stock. Best of Luck! Doug
************************ Doug Levin Motorsports Inc.: www.douglevinmotorsports.com 305 249-RACE (7223) N.M.B., Florida |
525 NA - but, that shouldn't matter, the pump is also supplying the the enrichment for the nitrous. SC and TC engines are a little different since they have to overcome the pressure in the chamber, in other words, my set-up would have to be derated for SC cars.
| Is the stock fuel pump... | J DAWG | RT/10 and GTS Discussions | 5 | 11-16-2004 06:44 AM |
| Stock fuel pump | SpinMonster | Performance Modifications | 15 | 07-24-2004 12:57 PM |
| stock viper fuel pump question? | Fast Freddy | RT/10 and GTS Discussions | 2 | 12-21-2003 04:12 PM |
| Max RWHP stock fuel pump will support? | BLOWNGTS | Performance Modifications | 14 | 10-22-2003 02:45 PM |
| Flow of Stock Fuel Pump? | Lee Dove | RT/10 and GTS Discussions | 2 | 12-22-2002 12:03 AM |
