#31 | |
Sorry boys and girls, but, I'm not the politically correct type so I can say openly that I have confessed to God and taken Jesus into my heart and I know that I will not perish into silence. You can do it too. I plan on plenty of noise in heaven and seeing my VCA friends there. Maybe the Vipers will even be better there! ![]()
'94 RT/10 Bone Stock (Poser mobile)
#32 |
#33 |
Your going to get small carbon deposits imbedding themselves into the clear coat with or without the cats. If your aftermarket exhaust is sticking way out like a set of buck teeth (like I've seen on some bad installs) you'll probably minimize the pitting. I'd say put a nice coat of wax on the rear fascia then clean off the exhaust residue regularly. Wash, wax, repeat.......cause if you drive your car you'll notice the rear fascia collects dust and debris within a block.
By the way the first time you go to remove these specs, gently soak them with WD-40, it will eventually dissolve the carbon. DON'T scrub them! or your paint will get scratched. Wash the WD-40 off then wax. Eventually you'll cave in and stop this non stop process or if you have OCD you'll just stop driving the car. Last edited by Camfab; 07-02-2008 at 12:15 AM. |
#34 | |
'00 Black RT/10- Mod'd
#35 |
Well, on the way in this morning, I put the window down to absorb some of that fresh 85 degree morning air. At WOT it made my ears ring. WITH cats remember.
I can't imagine using a cat-less vehicle for anything other than recreational sport driving. |
#36 |
I am in Indiana and enjoy the luxury of not having a smog check to answer to. My 2000GTS exhaust system has OEM manifolds, then 2.5" straight pipe under the sills. So yes the ressinator and cat were removed. The rear muffler is stock. Sound was verry good at high way speeds, under hard acceleration between gears I would get popping and lots of rumbling. Sounds like and older can-am car. I have since installed the new x pipe muffler from dynomax in the place of the factory muffler. Much inproved sound. I would recommend this setup to anyone looking for great sound on a budget. Side sills are low temp, temps in car are cool, sound is good considering I only spent $135 for the muffler and $25 for the 2.5" pipng.
#37 |
Here is my exhaust sound if anyone wants to hear it.
<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/YW_Bqw2-YAg...</param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/v/YW_Bqw2-YAg&hl=en&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
99 GTS ACR 2700 actual miles 10/07 - present99 GTS ACR 44000 miles (RIP) 8/02 - 9/07
#38 |
Sounds good! My offer still stands about trading the headers for my stock manifolds. I'll be in Dalton next weekend, so if you are interested in doing the swap, just show up in Dalton with your Viper. I'll even have access to a lift.
1997 Viper GTS |
#39 |
Sounds like Dale Jarett in the UPS truck. I have heard better sounding farts. GTS Bruce(CDI headers,Jon B high flows,Corsa)
#40 |
how nice. thanks.
#41 | |
#42 |
Yep. I've got a coffee maker from Wal-Mart that makes more rumble than that.
Lake pipes man... |
| Just installed, Belanger headers, Random CAT, 3" Corsa exhaust | Bolt | RT/10 and GTS Discussions | 0 | 03-11-2007 07:03 PM |
| Headers and exhaust installed - pictures | wormdoggy | SRT10 and SRT10 Coupe Discussions | 17 | 03-29-2006 03:54 PM |
| Belanger Headers/Exhaust Installed | BYT U L8R | Performance Modifications | 2 | 03-14-2002 04:23 PM |
| Just installed Belanger headers and exhaust and ck engine light came on | THEMASH | RT/10 and GTS Discussions | 7 | 11-19-2001 07:13 PM |
| New Belanger Headers/Exhaust installed. | RECOIL | RT/10 and GTS Discussions | 26 | 11-08-2001 01:56 PM |
