Old 06-29-2008, 05:31 PM   #1
sirhc76
TX VCA Member
sirhc76's Avatar
Default Thermostat clicking question
Lately my GTS has been running hotter and hotter. Naturally the outside temps have been at or above 100° and this hasn't helped. I decided to pull the radiator so that I could it and the surrounding area. It was obviously very dirty and full of crap including enough leaves to make any nest building bird proud.
Now to the question. During the purge session I noticed that when I hand pumped the upper hose I could hear a clicking noise coming from the thermo housing area. I can’t pinpoint the noise and its either the top of the water pump or the thermostat itself. What on the thermostat could be clicking or is this normal?
Now if I can get the bottom hose to seal I would almost consider this task complete. I really don’t like removing radiator hoses as it seems they never seal correctly.
Thanks,
sirhc76 is offline   Reply With Quote
Old 06-29-2008, 08:12 PM   #2
got one
Texas VCA Member
got one's Avatar
Default Re: Thermostat clicking question
from the water splashing around inside maybe? Some folks do refer to it as a clicking...just fyi Chris.
Central Texas VCA President
Simply content with keeping my 94 running...70k and climbing fast!
Old 06-29-2008, 09:13 PM   #3
Sounds strange for sure. I would based on what you've said, and remembering another post by you with cooling issues, change that thermostat. I can't remember exactly who, but someone recently posted a detailed failure of a stat. Put on the Roe hoses too. No more clicking, I mean, no more squeezing the upper hose.
Why are you having issues sealing the hoses?
Do you have friends with tools? Or beer?
Old 06-29-2008, 10:11 PM   #4
sirhc76
TX VCA Member
sirhc76's Avatar
I know our water is hard but it’s not that hard
This sounds like the T-stat moving or at least a piece of it. I have another T-stat that came out of my SRT10 ram. I'm sure it’s not the same design although they are interchangeable. I thought it would be simple to find a 3/16 pipe plug socket locally. It appears I was wrong and have ordered one from snap on.
I have plenty of tools and a few who live around me as well. The issue with the lower hose is that someone mangled the lower return pipe. Instead of being rounds its well almost square. I think I finally got it on and all the air out of the system. Now I'm sure I'll be replacing that T-stat.
Thanks,
Old 06-30-2008, 04:31 AM   #5
Bolt
Bolt's Avatar
Read this, especialy at the end. I just replaced a bad thermostat I installed last year. I had the same problem and chased it to the thermostat.
Strange engine heating problem (new)
Bolt
Bolt is offline   Reply With Quote
extended warranty question; Is the thermostat covered? Bigot Bledsoe RT/10 and GTS Discussions 8 06-07-2005 07:55 AM
Thermostat question. Jim Sullivan RT/10 and GTS Discussions 10 01-26-2005 05:36 PM
Question about changing to a 180 thermostat ab RT/10 and GTS Discussions 13 02-02-2004 08:54 PM
Thermostat Install Question SapphireGTS RT/10 and GTS Discussions 3 09-30-2003 03:15 PM
Question on replacing thermostat and hoses '94 FUSCUCLA1 Archive Management 0 03-28-2001 04:31 PM
