Old 06-29-2008, 09:51 PM   #1
TexasPettey
Texas VCA Member
TexasPettey's Avatar
Default Gen1 Motor Mount Torque SPEC
Anyone know what the torque specs are for the motor mount bracket to engine block bolts/nuts are? My service manual has them listed as 65ft-lbs in the back of section 9. However, in the text description of the removal/install of the motor mounts, it calls out 30ft-lbs.
TexasPettey is offline   Reply With Quote
Old 06-29-2008, 11:42 PM   #2
-FROG-
Default Re: Gen1 Motor Mount Torque SPEC
It's 65ft. lbs
-FROG- is offline   Reply With Quote
Old 06-30-2008, 08:49 AM   #3
Tom, F&L GoR
Tom, F&L GoR's Avatar
For further info, the introduction section lists bolt sizes, grade, and max torque.
Tom,
Old 07-01-2008, 08:25 AM   #4
I think those are 3/8-24 threads. 65 ft-lbs is way high for that size screw. Most generic charts like the one Tom refers to in your shop manual would say 30 ft-lbs on on 3/8-24 screw. Even grade 8 is only 45 ft-lbs.
Old 07-01-2008, 08:54 AM   #5
TexasPettey
Texas VCA Member
Well, I tried 65ft-lbs last night. SNAP the bolt broke. The bolts are 3/8"-16 thread. I'm guessing that 65 ft-lbs is too much. I bought some grade 8 bolts to replace them, but I don't think I'll be trying 65 ft-lbs on those.
Old 07-01-2008, 12:02 PM   #6
got one
Texas VCA Member
got one's Avatar
Wow...why are you replacing bolts Chris? did you change out your motor mounts agian...snap the ones you have?
Central Texas VCA President
Simply content with keeping my 94 running...68k and climbing fast!
Help with Torque Spec FlyBy RT/10 and GTS Discussions 3 05-14-2008 08:54 PM
Help with torque spec FlyBy RT/10 and GTS Discussions 0 05-14-2008 05:48 PM
Need Torque Spec GTS-R 001 RT/10 and GTS Discussions 4 03-30-2008 08:32 PM
torque spec? twinturbo3150 SRT10 and SRT10 Coupe Discussions 3 11-08-2006 03:51 PM
correct torque spec for oil pan ViperRay RT/10 and GTS Discussions 1 12-25-2003 03:30 PM
