Old 06-30-2008, 11:24 PM   #1
Tim
Alberta Canada VCA Member
Default Help on masking and painting Sneaky Peter in Black on Yellow Valve Covers?
I just powder coated the valve covers and intake manifold in Yellow to match my 2002 RT and looks great. I read the post on sanding and polishing and that will work great to roughen up the powder coat and prep it to paint.
But what I’m wondering is, to try and mask the Viper logos on the valve covers so that I can paint the logos and Sneaky Pete in black is not going to be easy. Should I try and find someone with a steady hand and brush the black on or?????????????????????
Any suggestions? I see most everyone are just doing the polishing thing but the Black High Lighting will look good.
Tim
Tim is offline   Reply With Quote
Old 07-01-2008, 07:53 AM   #2
big-n-italian
IL VCA Member
big-n-italian's Avatar
Default Re: Help on masking and painting Sneaky Peter in Black on Yellow Valve Covers?
Tim
i taped mine off and it looks great. you will need and x-acto knife, tape, time, and alot of patience, but you can do it.
1997 GTS, Vortech SC, Intercooled, 726 RWHP
1974 Dodge Charger 542 Hemi / 1963 Ford Falcon Fire Chief
big-n-italian is offline   Reply With Quote
Old 07-01-2008, 09:05 AM   #3
Tim
How about laying in some vasoline, putty or there is this stuff called Liquid Mask? Anybody tried this stuff?
Old 07-01-2008, 10:00 AM   #4
TexasPettey
Texas VCA Member
TexasPettey's Avatar
I used painters blue tape and an exacto knife. I used a model paint brush to apply the paint. Remember to use very high temp paint. I did mine in gloss silver (POR is the brand). A powder coating shop will usually have a good selection of very high temp paints.
TexasPettey is online now   Reply With Quote
Old 07-01-2008, 12:03 PM   #5
big-n-italian
IL VCA Member
you could, but you will still need an x-acto knife and would still need to cut it all out wouldnt you? not sure how clean you lines are going to be with vasoline.
Old 07-01-2008, 09:14 PM   #6
Tim
How about fill in with silicone, paint it, once the paint is dry pull the silicone out?
I may want to put some Pam or somthing on first to allow the silicone to clean out easy.
Old 07-01-2008, 10:17 PM   #7
Vaseline is for date night.
Silicone is for bathroom tubs and windows.
MASKING TAPE is for painting...
Old 07-01-2008, 10:19 PM   #8
twinturbo3150
vaseline is for lonely nights
twinturbo3150 is offline   Reply With Quote
Old 07-02-2008, 10:03 AM   #9
GTSnake
GTSnake's Avatar
It's not easy after it's powder coated. The edges get a little rounded from the thickness of the powder coat. You have to make sure your masking tape edges are stuck down or you'll get bleeding under the tape. If I was to do it over again I think I may just paint it over the stock powder coat.
'97 GTS
1304 RWHP CPE TT system
updated life insurance...
Old 07-02-2008, 01:13 PM   #10
STL RT/10
Am I the only one that caught the subject of "Sneaky Peter "? Lol. Sorry I couldn't resist.
STL RT/10 is offline   Reply With Quote
Old 07-02-2008, 01:41 PM   #11
Tim
Yes, I see the tape is lifting. Will make sure it is stuck before spraying. Thanks
Old 07-02-2008, 03:09 PM   #12
DAMN YANKEE
New York/Conn VCA Member
DAMN YANKEE's Avatar
Tape is usually a problem, but the new "frog" masking tape is the answer...try Home Depote...seriously, its called frog tape.
Re-Painting Valve Covers - how to ? Longnecker RT/10 and GTS Discussions 18 11-05-2008 11:12 AM
black valve covers mods/pics Nadine UK GTS RT/10 and GTS Discussions 11 07-20-2008 05:52 PM
Yellow "Sneaky Pete" Logos Chris1 RT/10 and GTS Discussions 7 08-19-2006 01:51 PM
Had a busy weekend.....Yellow intake/valve covers (pics) VIPER BAZ UK RT/10 and GTS Discussions 23 07-23-2005 06:06 PM
Painting Valve covers .. . SapphireGTS RT/10 and GTS Discussions 9 09-28-2003 08:10 PM
