I barely ever get into boost on my Roe GTS. 99% of the time I'm running under vacume pressure. If you drive normaly, the motor has more than enough torque to pull you. I've had my Roe at 10 lbs for about 2.5 years so far. I've refilled the methanol bottle about 3 times and it sprays when I boost.
#17 | |
My temp gauge (170F) this last track day -- 75F -typical -- only goes about a needle and a half past the 3rd bar. One cool down lap and I'm back on the 1st/2nd bar after getting to the parking place. Based on speedo readings on the straights, I evidenced no heat soak over the 20 minute sessions. I also used only a 1/4 qt of oil over the 1100 mile run down to the event (100 track miles). These things and the longevity so far (knock on wood) make me quite satisfied with this set up. The low down street grunt is what I like the best. I don't drag race at all so that's not a factor for me. Steve |
Traction is hard enough w/ my cream puff 528 rwhp. Having 600 to 700 rwhp at 1800 rpm is just craaaaaazy to me. Torque is already monstrous in Vipers, which I think is one reason for the 3.07 rear end. From what the Paxton guys tell me, of the two Paxton is the way to go. Now, if TT enters the picture, that is a totally different story.
blk 04 SRT bullet-proof NA motor by Tator, ported heads, comp cam, Belanger exhaust, VEC 3, comp oil pan, roll bar, nav, 08 Lemke hood, 528 rwhp/557 rwtq Support Tators Dodge !!!!!!!!!!
Sean mention that the Roe puts less wear and tear on the engine because it makes such huge power down low (2krpm) that the engine doesn't have to turn high rpms just to make power and therefore causing wear and tear.
I was/am a little tore by this as higher rpms puts more stress on engine/drivetrain but does huge power actually put more stress on the engine at low rpms? Hard to tell. I've only heard good things about reliability on the Roe and mixed about the paxton. The paxton, since it makes more power the higher the rpms would be prone to breaking tires loose unexpectedly then the Roe as the Roe is an instant hit apposed to the build up of the paxton. I do like the fax that the paxton does have a intercooler as apposed to the water/meth for the Roe. Just my thoughts. |
#20 |
ive seen first hand what a ton of torque (nitrous) can do to the cylinder walls
#21 | |
Ted
#22 | |
Ted
#23 |
The Roe Looks Nicer...Al...
#24 | |
It also has the advantage of chemical intercooling supposedly worth an extra 50rwhp at 10psi boost. I spoke to Larry Macedo about the stress of the extra hp on my bottom end and he assured me that his engine will have no problems with it. Ted
#25 | |
Venom Member Things go better with boost. "Viper" is the gearhead word for fun.
#26 |
I agree.
Larry Macedo put 9-1 Ross pistons in my engine back in 2003. I recommend all cream puffs get a piston change for sc and Nitrous just for longevity and reliability. Ted
#27 | |
Also you are wrong the Autorotor need oil changes every 5-6000 miles. The Paxton uses oil from the crankcase. |
#28 | |
#29 | |
What kind of maintenance does the Supercharger add? Next to none. The oil in the unit does not come from the engine oiling system, which gets contaminated from blowby and the combustion process. Therefore, the compressor oil stays cleaner and in better condition longer. We suggest the case oil level be checked at each engine oil change. The oil color will be the first indication that a change is due, which should be at approximately 50,000 miles. Ted
#30 | |
Horsepower used to spin rotors while not making boost is insignificant and doesn't even affect mileage. Ted
| Paxton keeps getting better and better.... | MikeR | SRT10 and SRT10 Coupe Discussions | 25 | 04-09-2008 07:31 AM |
| 900 hp Paxton or TT? | black mamba1 | SRT10 and SRT10 Coupe Discussions | 74 | 07-07-2007 05:09 PM |
| Paxton VS. Roe for a Gen I I car | Greg B | RT/10 and GTS Discussions | 29 | 02-26-2007 11:39 AM |
| SRT RAM WITH PAXTON | Mike Adams | Performance Modifications | 6 | 12-26-2004 08:19 PM |
| Roe or Paxton ? | twinvipers | Viper Racing/Dyno Results/Time Slips | 2 | 10-07-2003 04:29 PM |
