#31 |
With a Roe or Paxton, what's your air intake temp readings during a quarter mile pass, or at least a 2nd or 3rd gear pull? It would be nice to compare... Most are probably using a VEC2/3, some using an AEM EMS, and the base Paxton using Split Sec. Not sure if the Split Sec can log, but the VEC and AEM can. Post a screen shot of your datalog showing AIT, and list factors/conditions like ambient outside temp, are you using nitrous or water/meth, if so, where is the AIT sensor located (before or after the nitrous or water/meth nozzles).
#32 | |
![]() Anyhow, I won't get into the debate, but will say both set-ups need tires to use the power properly. My Roe with Kumhos and the 3.07 or the 3.55 was very controllable in 1st and 2nd gear on the street.
CPE Twin Turbo !!!! My old set-up: 1996 Roe supercharged GTS: 9.28 @ 151mph with nitrous / 9.68 @ 144mph no nitrous Dealer-installer for CPE turbos and Roe s/c's |
#33 | |
#34 |
Carolinas VCA Member
I have owned all 3 systems, Roe, Paxton, and Twin Turbo. All are good systems and fit different needs and pocket books. Personally I like the Paxton better than the Roe for it's higher hp possibilities. Both the Roe and Paxton when installed correctly are very reliable and neither require a lot of maintence.
2002 Underground Racing Twin Turbo |
#35 |
Point taken. My suggestion was that it seems to be a slight preference to Paxton for guys that have had both systems.
blk 04 SRT bullet-proof NA motor by Tator, ported heads, comp cam, Belanger exhaust, VEC 3, comp oil pan, roll bar, nav, 08 Lemke hood, 528 rwhp/557 rwtq Support Tators Dodge !!!!!!!!!!
#36 | |||||
Although not linear, I consider the post sc air charge temp to be a relative number to the airbox IAT when using the WB readings as the end result to set the IAT function parameters. It's not perfect, but my AFR tuning has shown it to work quite well enough for me. Steve |
| Paxton keeps getting better and better.... | MikeR | SRT10 and SRT10 Coupe Discussions | 25 | 04-09-2008 06:31 AM |
| 900 hp Paxton or TT? | black mamba1 | SRT10 and SRT10 Coupe Discussions | 74 | 07-07-2007 04:09 PM |
| Paxton VS. Roe for a Gen I I car | Greg B | RT/10 and GTS Discussions | 29 | 02-26-2007 10:39 AM |
| SRT RAM WITH PAXTON | Mike Adams | Performance Modifications | 6 | 12-26-2004 07:19 PM |
| Roe or Paxton ? | twinvipers | Viper Racing/Dyno Results/Time Slips | 2 | 10-07-2003 03:29 PM |
