Old 07-02-2008, 09:41 PM   #31
Alternative
CA VCA Member
Alternative's Avatar
Default Re: Roe vs. Paxton
With a Roe or Paxton, what's your air intake temp readings during a quarter mile pass, or at least a 2nd or 3rd gear pull? It would be nice to compare... Most are probably using a VEC2/3, some using an AEM EMS, and the base Paxton using Split Sec. Not sure if the Split Sec can log, but the VEC and AEM can. Post a screen shot of your datalog showing AIT, and list factors/conditions like ambient outside temp, are you using nitrous or water/meth, if so, where is the AIT sensor located (before or after the nitrous or water/meth nozzles).
Alternative is offline   Reply With Quote
Old 07-02-2008, 09:46 PM   #32
1TONY1
1TONY1's Avatar
Originally Posted by black mamba1 View Post
Traction is hard enough w/ my cream puff 528 rwhp. Having 600 to 700 rwhp at 1800 rpm is just craaaaaazy to me. Torque is already monstrous in Vipers, which I think is one reason for the 3.07 rear end. From what the Paxton guys tell me, of the two Paxton is the way to go. Now, if TT enters the picture, that is a totally different story.
I see the humor in that....what do the Roe guys tell you
Anyhow, I won't get into the debate, but will say both set-ups need tires to use the power properly. My Roe with Kumhos and the 3.07 or the 3.55 was very controllable in 1st and 2nd gear on the street.
CPE Twin Turbo !!!! My old set-up: 1996 Roe supercharged GTS: 9.28 @ 151mph with nitrous / 9.68 @ 144mph no nitrous
Dealer-installer for CPE turbos and Roe s/c's
Old 07-02-2008, 09:50 PM   #33
1TONY1
1TONY1's Avatar
The problem is....you would need the IAT sensor after the s/c on the Roe. I had an Autometer on mine in the intake. It would drop about 50 degrees in a third gear pull with the w/m. The longer you were on the throttle the more it would drop.
Old 07-03-2008, 07:15 AM   #34
2MANYTOYS
Carolinas VCA Member
I have owned all 3 systems, Roe, Paxton, and Twin Turbo. All are good systems and fit different needs and pocket books. Personally I like the Paxton better than the Roe for it's higher hp possibilities. Both the Roe and Paxton when installed correctly are very reliable and neither require a lot of maintence.
2002 Underground Racing Twin Turbo
2MANYTOYS is offline   Reply With Quote
Old 07-03-2008, 07:22 AM   #35
black mamba1
NY / CT VCA Member
black mamba1's Avatar
Point taken. My suggestion was that it seems to be a slight preference to Paxton for guys that have had both systems.
Old 07-03-2008, 07:40 AM   #36
Steve 00RT/10
Steve 00RT/10's Avatar
Originally Posted by RTTTTed View Post
You're thinking of a Roots blower. The Roe PD does spin according to the crankshaft, same as the Paxton, but the Power Valve releases the extra air back into the non-pressurized side of the intake making the blower "idle" and allowing vacuum to the intake runners. The screws spin, but don't actually make any boost or use any hp to turn until boost is built.
Ted
Yup. the old by pass valve. Should have remembered that...but If the pulley is turning the screws, it would seem to be using HP? ...just like any of the other pulleys driving things on the engine. They all take some HP.
Originally Posted by Bobpantax View Post
500 ft lbs of torque at 1800 RPM means a bigger explosion in the cylinders at 1800 RPM. A bigger explosion means more stress on the components. If you look at the boost curves above, you will see that there is, therefore, far less stress on a Paxtonized engine. With that said, the Vipers before 2000 had forged pistons and were/ are very strong engines. 2000 to 2002 things got weaker with cast pistons. The Gen III and Gen IV engines are not as strong as the pre 2000 Gen II engines. If someone disagrees, please jump in.
I guess the real proof is in how long things last. I'll let my cast piston miles and experience speak for me. There are very few reading here that have a driven a Viper as many miles as we have. About 83,000 to date. Lots of hard miles on the 00 car.
I agree.
Larry Macedo put 9-1 Ross pistons in my engine back in 2003. I recommend all cream puffs get a piston change for sc and Nitrous just for longevity and reliability.
Ted
5 Pound Roes absolutely do not need forged pistons to run just fine. Again, my miles speak for themselves. I am completely satisified with my 'little' set up. I have no desire to go further as drivability is the deciding factor for anything we do to the cars. I could jump in our 80,000 mile car today and drive across the country. We'll be in the 100,000 driven Viper mile club next year. Few can say that.
Really? Here's a copy/paste from Roe Racing Performance Parts
What kind of maintenance does the Supercharger add?
Next to none. The oil in the unit does not come from the engine oiling system, which gets contaminated from blowby and the combustion process. Therefore, the compressor oil stays cleaner and in better condition longer. We suggest the case oil level be checked at each engine oil change. The oil color will be the first indication that a change is due, which should be at approximately 50,000 miles.
Ted
I changed the oil this spring for the first time at 2 years/21,000 miles. It was still very clean, but a little low. I would have had to add an ounce or so. It was between the marks. I never had to add oil over the 2 year period.
Exactly right about the IAT location. Engineers have told me that the actual intake charge temp is not linear to the pre SC temp. That being said, I have dialed in the VEC IAT function to where I have one card which is good from 30F to 100F. Like the stock pcm, I let the mixture go rich for cooling after 126F IAT (I set that number). I have yet to see that temp on my Vipair 2000 car -- no matter the outside temp. The non - Vipair car has seen 140F on similar days. I have made over 200 log runs since 5/06. Upgrading to VEC 3 capabilities (IAT function) last year was kind of like starting over. There was a definite learning curve getting the parameters in line with each other.
Although not linear, I consider the post sc air charge temp to be a relative number to the airbox IAT when using the WB readings as the end result to set the IAT function parameters. It's not perfect, but my AFR tuning has shown it to work quite well enough for me.
Steve
Steve 00RT/10 is online now   Reply With Quote
Paxton keeps getting better and better.... MikeR SRT10 and SRT10 Coupe Discussions 25 04-09-2008 07:31 AM
900 hp Paxton or TT? black mamba1 SRT10 and SRT10 Coupe Discussions 74 07-07-2007 05:09 PM
Paxton VS. Roe for a Gen I I car Greg B RT/10 and GTS Discussions 29 02-26-2007 11:39 AM
SRT RAM WITH PAXTON Mike Adams Performance Modifications 6 12-26-2004 08:19 PM
Roe or Paxton ? twinvipers Viper Racing/Dyno Results/Time Slips 2 10-07-2003 04:29 PM
