Old 07-01-2008, 02:27 PM   #1
Vipuronr
Vipuronr's Avatar
Default Do I Need Heat Resistant Paint for Metal Parts in Engine Compartment?
Will be painting the black metal parts behind the brake vaccum booster and on pass side near air box. These have become rusty as the car sat in Boca Raton for 10 years with little driving.
Question is, can I use spray black acrylic lacquer to repaint these parts, or do I have to use black heat resistant paint...seems that is reserved for headers and such?
Thanks.
Peter
________________________
1998 RT/10, Viper Red (5k miles) "Tatorized"
FIREFIGHTERS SAVE LIVES AND PROPERTY:usa:
SUPPORT TATORS DODGE!!!!!!!!!!!!!!!!
Vipuronr is offline   Reply With Quote
Old 07-01-2008, 02:31 PM   #2
Vipuronr
Vipuronr's Avatar
Default Re: Do I Need Heat Resistant Paint for Metal Parts in Engine Compartment?
Here are two pictures to clarify what parts I mean:
Thanks.
Peter
Old 07-01-2008, 02:46 PM   #3
You should be fine with regular paint. You have to remember, the source of heat, AKA that big V10, is closer to to the plastic master cylinder reservoir than it is the brake booster. Which by the way has a rubber diaphragm in it of sorts. Which all of those would melt way before reg paint would peel.
Old 07-01-2008, 05:39 PM   #4
Vipuronr
Vipuronr's Avatar
Now, that may have been obvious, but I surely didn't think of that!
Thanks for pointing that out for my dull mind to absorb!
Peter
Resistant Check Engine Light Parisianviper RT/10 and GTS Discussions 18 09-29-2007 08:25 AM
red fluid in engine compartment Muzz B Yellow SRT10 and SRT10 Coupe Discussions 6 08-11-2005 03:20 PM
por15 heat resistant application info? NCVCA Performance Modifications 9 05-16-2003 04:40 PM
Rubber shift boot is old and cracked. Heat coming into passenger compartment. HELP! MJBComp RT/10 and GTS Discussions 1 12-05-2001 06:18 AM
Engine Compartment Black Paint Code? JimDavis MT 97GTS 650R Performance Modifications 2 11-16-2001 02:58 PM
