A quick review of my '01 GTS project...
BEFORE -> Factory headers, heat shields, cats. -> Corsa cat-back with rear mufflers deleted. -> Factory sills with factory insulation. AFTER -> Belanger headers, Dave's custom heat shields, Parts Rack R/T HF ceramic cats. -> Dynomax mufflers from Belanger, 3" side exhaust from Belanger. -> Autoform FRP sills, Dave's custom bottom venting, stock insulation trimmed to clear custom vents. -> Parts Rack louvered vents in wheel wells. Temperature measurement points were based on the maximum temperature in the area I was looking for, and is different before and after because the parts are different. The measurements were taken after a 20 minute afternoon drive home. Exit car, shoot pics. Not even twisting the cap of a long neck postponed the data gathering. ![]() So here's the data: ![]() The before measurements: ![]() ![]() ![]() ![]() The after measurements. Like I said above, I moved the measurement point to suit the new parts. The shorter cats are right below the door hinge area, and not in the bulge of the sill like the OE cats. ![]() ![]() ![]() ![]() ![]() An interesting note, as I guess my AC puked whatever freon it had in it while modding (AC always sucked, guess I know why now...), is that driving home yesterday with the windows up and the AC blowing warm air, it was really not that hot in the car. Before, with the OE cats and at least some freon (blowing a little cold), you would bake in the car. So while I wait for the R134A gauges I ordered from Amazon yesterday to arrive to charge the AC, I'm meanwhile going to call the project a complete success when it came to reducing temperatures both inside and outside of the car. |
Nice writeup Dave - very scientific
97GTS B&W: Roe S/C 5#, VEC3, Borla headers and catless exhaust, smooth tubes and K&Ns, 1.7 rockers, 3.55 gears, Fidanza, short-shift kit, 577rwhp/577rwtq all on cast pistons |
Dave, great job. How are the new heat shields working out in the header area?
2001 RT/10. Belanger Headers/Catback, RT Cats, T&D Rockers, Trend Pushrods, Vec3, Smooth Tubes/Filters WE SAVED TATOR'S DODGE
#4 | |
So maybe tonight I'll play around and take some measurements of not the shields, but maybe what they're supposed to be protecting. None of those parts are shiny or reflective. Should I get a 12-pack or would an 18-pack be in order for that project? ![]() Meanwhile, I'm gonna have to get those button head screws, and get rid of the easy to use hex head screws on my shields. I hate button heads... |
#5 | |
#6 | |
7 minutes??? I'd only need about 90 seconds... |
Dave,
I also enjoyed the details of your write up. Could you do a complete parts list and where you purchased the materials. If you do not mind I may copy what you have done.
Bolt |
very nice work Dave. nice welds.. my high-fow cats on the GTS I had, had bogers all over it. Thanks to the local midas shop morons..wish i had the time and facility to do stuff like that
#9 | |
Stay tuned... We're working on it. |
About 35 amps with the TIG torch and 1/16 SS wire. You are right, no weld boogers!
Dave,
That is a great write up and an impressive set of results! and from a Texan...I guess that shouldn't be astonishmental from a non-terroristolizer.
2000 GTS, Roe 5lbs, VEC3, JMB Performance intakes, Tator Titanium CMC Cannister Coils and Injection Tap Caps, Yeti Plate, Corsa Cat Back, Innovate LC-1 WB Last edited by DAMN YANKEE; 07-02-2008 at 03:08 PM. |
| "Ice Cube" side sills, custom Belanger heat shields - update - a few pics | dave6666 | RT/10 and GTS Discussions | 49 | 07-05-2008 08:41 PM |
| I need a passanger side "hood Striker" for my Gen I | -FROG- | RT/10 and GTS Discussions | 1 | 04-21-2008 08:39 PM |
| AlansPerformance.com ""Cool Triple Pass Radiator"" | BLWNV10 | New Products, Supplier Specials, and Group Buys | 1 | 08-23-2007 12:26 PM |
