Old 07-03-2008, 09:28 AM   #1
Nates GTS Viper
Virginia Maryland VCA member
Default 08 trans vs 96 trans
I've heard nothing but good things about the new trans in the 08s. So I just wanted to know with them being more sivalized if they will still be as bulletproof as the old hardcore 96 trans. I ask because I plan on upping the power with either turbo or blower and know that my trans will still be reliable but at the same time if the new trans is just as tough but is that much better I wouldn't mind swapping them. Oh I should of asked first if it is possible. The car is mostly street but is taking to the drag strip often. Thanks
Nates GTS Viper is offline   Reply With Quote
Old 07-05-2008, 12:41 PM   #2
RobZilla
Florida VCA Member
RobZilla's Avatar
Default Re: 08 trans vs 96 trans
Hmmm. I swapped for an '06 trans about a month ago and it works great. My old one had some problems with the syncros going out so it needed a rebuild/swap anyway. In your case, if you really feel the need to be extra careful and pull it out before introducing forced induction, my suggestion is to pull it, and take it to a well known (reputable) tranny shop. They usually inspect for free or very cheaply.
As for the 08 transmission going into a 96, I am not sure if that is possible. Mark at Woodhouse NE should be able to check, or double check. The problem you may have is that the bell housing doesn't match up. If that is the case, there will be no way you could use it. Problem number two will be the spedo. When I installed the 06 trans, I had to take the rear housing to have the spedo hold cut and threaded. The new cars spedo's run off the ABS. Since you do not have ABS, you will have the same issue to overcome.
Hope this helps.... JOIN the VCA and I'm sure you'll get a better response for further inquiries.
'00 Black RT/10- Mod'd
RobZilla is online now   Reply With Quote
Old 07-05-2008, 04:00 PM   #3
RTTTTed
Western Canada VCA Member
RTTTTed's Avatar
The new tranny is stronger (because the new engine has more power) with stronger gears and synchros. So's the new differential.
Ted
Old 07-05-2008, 05:34 PM   #4
Nates GTS Viper
I joined the vca at the begining of last week so I'm just waiting on my vca number to arrive. I joined venom also if that counts for extra responces. Thanks for the info on your swap that helps out a lot.
Old 07-05-2008, 08:43 PM   #5
RobZilla
Florida VCA Member
RobZilla's Avatar
Great... always extra perks for members especially VENOM.
If you need any more info, just ask.
I have a 03 that needs a new trans, will any year trans fit? Donuts4me9 SRT10 and SRT10 Coupe Discussions 8 04-01-2008 06:40 PM
My new trans carl B RT/10 and GTS Discussions 0 11-26-2007 03:14 PM
Gen. 3 trans. the same as gen. 1 & 2? SNKEBIT SRT10 and SRT10 Coupe Discussions 6 04-26-2006 01:55 PM
I want this 83 trans-am... Help... Epro Sneaky Pete's Place 39 10-09-2004 02:49 PM
? about 6 spd trans Guyver1 Archive Management 1 10-29-2000 07:07 PM
