NE VCA Member
What is the easiest way to add a wide ban sensor for A/f reader? (for a 97GTS )Can you use any of the present o2 senser locations? Can you remove any of the rear o2 sensors and use those bung holes. Does the car need the 4 o2 sensors? Looking to install a A/F reader to help tune the Roe S/c without going to a dyno. I'm am trying to keep it as simple as possible!
Unfortunately there is no easy way to do it - I tried
You cannot replace any of the stock sensors because the PCM doesn't understand the wideband signal. You'll have to mount a bung in your exh syst for the additional sensor. Check out Damn Yankee's writeup in the How-to section.
97GTS B&W: Roe S/C 5#, VEC3, Borla headers and catless exhaust, smooth tubes and K&Ns, 1.7 rockers, 3.55 gears, Fidanza, short-shift kit, 577rwhp/577rwtq all on cast pistons |
2001 RT/10. Belanger Headers/Catback, RT Cats, T&D Rockers, Trend Pushrods, Vec3, Smooth Tubes/Filters WE SAVED TATOR'S DODGE
Not entirely true. You can just pull your rear 02s out, but leave them plugged in, and the PCM will not care. Only on 97s though. I beleive on 98 and up, you would need an 02 sim to do that. Also, the reading would only be accurate if you dont have cats, other wise you would need to put the WB senson before the cats. In which case you would need to add a bung.
'97 GTS B&B Headers/Cat Back, Roe Cat Delete, Roe Modded Airbox, 70mm TBs, Smooth Tubes, EBC Pads/Rotors, Hurst STS, SSRs |
My AEM sideband instructions said, "more than 36" away from engine to prevent premature failure due to heat from extended rpms or turbochargers(supercharger). It also required that the Bosche sensor be mounted 10 degrees above vertical to prevent failure due to water vapor during warm up cycle. I mounted mine in the elbow behind the side sill, like the Illustrated guide shows.
Ted
Just have Lance Armstrong jog beside you with a sniffer up your pipe. He can carry the logger in a fanny pack.
If he starts to drop behind have Chuck Norris roundhouse him in the ass a few times. |
You're going to have to get a bung welded into the downpipe before the cat converter. You do not want the WB sensor as far downstream as the secondary 02s and you need your primary 02s for proper function.
98 Red GTS - Mods 98 Red GTS - SOLD |
Crom +1, adding them properly in the side sills is easy.
2000 GTS, Roe 5lbs, VEC3, JMB Performance intakes, Tator Titanium CMC Cannister Coils and Injection Tap Caps, Yeti Plate, Corsa Cat Back, Innovate LC-1 WB |
#9 | |
why would he be jogging? ![]()
The General has it right also.
In place of a downstream sensor is fine. Just use a simm (full time or part time) on the newer cars. When you go to a dyno, a LOT of them put a hose in the tailpipe, which then goes through another hose to a sensor. That's really delayed, but still works well. You just have to have a handle on the lag time. It's about 250-300 RPM at low RPM's and about 150 up top. Reading post cat reads about .2 to .3 leaner than before it. Just know these simple facts and you can save yourself the time of adding a bung if your sensor will be temporary. Regards, Sean |
I had Lou Belanger add a "bung" on one side for my Innovate Wideband Sensor, on the "turn" of the exhaust that he built for my car, along with the headers......works great.
#13 | |
#14 | |
funny question to ask and vs cluttering the board with another post. What size are the OEM bungs or is it a standard that any exhuast shop should have.
| Easy as (Gen) 1, 2, 3 | V10SpeedLuvr | General Viper Discussion | 6 | 04-23-2008 04:48 PM |
| 0158 Code (O2 Sensor Circuit High Voltage) Bank 2 Sensor 2 | onerareviper | RT/10 and GTS Discussions | 1 | 07-02-2006 09:37 PM |
| Want an Easy 720HP? | MADDMAXS57 | RT/10 and GTS Discussions | 22 | 08-24-2004 06:49 PM |
| should be an easy question.....????????? | Rossssi | RT/10 and GTS Discussions | 6 | 06-30-2003 01:00 PM |
| This should be an easy one......... | FUSCUCLA1 | Interior and Exterior | 2 | 10-22-2000 10:31 PM |
