Old 07-10-2008, 12:31 AM   #1
gen2lover
gen2lover's Avatar
Default VEC3
will a gen 2 rt with a VEC3 pass an emissions test? Never had one before on any car I have owned.Here in Ontario,specifically ("Drive Clean Program")
thx in advance! Kevin.
Old 07-10-2008, 12:50 AM   #2
RTTTTed
Western Canada VCA Member
RTTTTed's Avatar
Default Re: VEC3
A "Viper Engine Controller" allows you to adjust the tune for better emissions. It also allows you to adjust your tune for bad emissions. It allows adjustments for optimizing the tune of your car.
Whether it passes emissions or not (snif test) depends on how it's adjusted.
Ted
Old 07-11-2008, 11:26 PM   #3
gen2lover
gen2lover's Avatar
Default Re: VEC3
Larry M. told me just dial it to zero...and I dont have to worry. Does the VEC3 give you more HP?
Old 07-12-2008, 12:39 AM   #4
RTTTTed
RTTTTed's Avatar
Default Re: VEC3
The Vec allows you to adjust for Forced Induction, different sized injectors, individual injector pulse widths, etc.
The Vec atually allows you to adjust the tune for the modifications to the engine's demands for timing and fuel which allows the engine to make optimum hp. The Vec allows adjustments not supported by the factory ECU. Forced Induction needs completely different programming for the boost pressures in the intake and the Vec has an internal MAP sensor that allows tuning according to Manifold pressures and loads.
Larry M (Macedo?) you can listen to what he says since he has vast experience in this field.
Ted
VEC3 or AEM PJJP SRT10 and SRT10 Coupe Discussions 3 06-23-2008 06:19 PM
Anybody want to sell a used VEC3? Boxer12 General Viper Discussion 13 12-04-2007 11:11 PM
Dyno #'s for SRT+VEC3 Joseph Dell SRT10 and SRT10 Coupe Discussions 16 07-24-2007 10:58 AM
VEC3 IAT Operation... ViperTony Gen II 0 07-12-2007 09:33 PM
Vec3---iat Steve 00RT/10 RT/10 and GTS Discussions 9 04-13-2007 03:08 PM
