Old 07-24-2008, 12:53 AM   #1
gen2lover
gen2lover's Avatar
Default short throw shifter questions
I am getting a gen 2 rt Monday and 1 of the 1st things I want to do is replace the stock shifter with the MGW short shifter.How long does this take? Tools needed,etc..?
Rather just pay a dealership to do it. thanks! I just have the knob.Not any assembly though..How many pieces are there? I heard MGW makes the entire assembly?
Old 07-24-2008, 06:26 AM   #2
Default Re: short throw shifter questions
Here is a link to SVS's instructions. Which BTW, their server appears to be down or malfunctioning. It is a good article with pics if they get up and running again.
http://www.svspower.com/article_detail.aspx?id=11
Old 07-24-2008, 12:16 PM   #3
RobZilla
Florida VCA Member
RobZilla's Avatar
I'm pretty darn sure that you have to drop the tranny out to do this... if you have a full set of tools, two jacks, and jack stands... you can do it with two guys in a day easy.
'00 Black RT/10- Mod'd
Old 07-24-2008, 04:08 PM   #4
chimazo
Virginia Maryland VCA Member
chimazo's Avatar
If you're installing a STS, not just a handle/knob, then it's best done from under the car, rather than drilling out rivits, etc., if done from the top.
No need to drop the trans, just the x-member to lower it a few inches to have more room. Might as well install a poly trans mount since you'll be unbolting the old one anyway.
'96 Caprice 9C1
'08 Hummer H3
Old 07-24-2008, 08:19 PM   #5
jcaspar1
jcaspar1's Avatar
I don't think MGW makes a short shifter, only a short knob. The knob is great and really shortens the throw. It is as easy as using a wrench to remove the stock knob and replace it with the new one. If I remember there is a lock nut that hold them in place. If you can change your oil you can do this.
A short throw shifter is a lot more work. I installed my SVS from the top and it was a bit of work but not too bad. Hurst, B&M and SVS make shifters for the Viper.
The MGW know alone is a great improvement:
Jeff
My 97 GTS
jcaspar1 is offline   Reply With Quote
Old 07-24-2008, 10:39 PM   #6
gen2lover
gen2lover's Avatar
yep.thats the 1 i ordered. about $500 enough for the entire assembly and labour costs? Getting a B&M installed by a viper tech. HALF A DAY?
Old 07-25-2008, 06:47 AM   #7
mike & juli
mike & juli's Avatar
Thumbs up Re: short throw shifter questions
SO VERY CORRECT~! We only go with the MGW short-throw shifter/KNOB is what it really is...and it's PERFECT...for what? $70? EASY install, and MUCH better improvement in shifting!~! ~juli
CONGRATS gen2lover on your GENII purchase!!! Looking forward to your impressions and PICS of course!!!!!
GTS Blue 08
w/ Silver Stripes Vert
RED '08 436hp Corvette
Orange 08 Busa
mike & juli is online now   Reply With Quote
Old 07-26-2008, 11:03 PM   #8
Jack B
Jack B's Avatar
It is not that hard to drill out the rivets. The next step is to install the threaded insert-rivets. This way you always have easy access to the shifter bolts.
Jack B
10.2 @140 (1.7 sec 60')
1.45 (best 60')
Old 07-26-2008, 11:46 PM   #9
mjorgensen
I may be too tired to do this right but there is some good info some wrong info and some more info to finish this post.
First there IS a MGW short throw shifter for all years of the Viper and in MY opinion it is the ONLY one to get. The MGW knobs are also awesome products that really improve feel and comfort. you can get the entire MGW setup with your choice of knob for LESS than $400! The shifter was designed with a dual bias spring system that makes the 2-3 shift more precise along with a light spring that helps make it easy to get the thing into reverse with a shortened shifter height (you all know how that can be if you just lowered the knob!). I have sold the first ones and about 40 of them since they were released. No brainier upgrade even on a new Viper in my mind.
You should be able to do the install from under the car as long as you drop the trans member as stated. I do disagree (of course I do right?) that the trans mount should be changed to a harder one without changing the engine mounts also. Think of this, if the transmission is held tighter than the motor with all it's torque what will happen? What will flex and stress sooner? The weakest link will and that will be the new mount and or the bell housing area of the tranny right? Not good of course.
Do it once and do it right, you will enjoy it much more in the end. Good night!
Woodhouse Viper Service Mgr.
800-889-1893 work
402-677-2935 cell
Old 07-26-2008, 11:48 PM   #10
mjorgensen
2 hours TOPS!
800-889-1893 work
402-677-2935 cell
Old 07-27-2008, 08:17 AM   #11
ViperTony
ViperTony's Avatar
Mark has a great point on changing the trans x-member. I highly recommend changing out the engine mounts and trans mounts in favor of Woodhouse mounts. It made a huge difference on my GenII. I don't miss shifts anymore and there's no vibration along the driveline. Shifter doesn't rattle and It feels as if power has been transfered to rear wheels. Definitely worth the upgrade at some point.
WE SAVED TATOR'S DODGE
Old 07-27-2008, 11:06 AM   #12
CROM
CROM's Avatar
I just did this whole procedure myself last weekend. I did it both ways pretty much. My shift boot was torn up from the previous owners attempt to install his MGW shift knob.
I first did the "underneath" approach by removing the tranny cross mount and slightly lowering the tranny with my tranny jack. Once I got it all out I said f'it and drilled out the rivets and pulled the boot off. With the boot off this procedure is cake. The two passenger side bolts are a pain in the ass, but not impossible. If I did it again, I could pull the whole procedure off in a couple hours easily. PM me if you want any detailed help.
98 Red GTS - Mods
98 Red GTS - SOLD
Old 07-28-2008, 06:27 AM   #13
Purdue_Boiler_Viper
Originally Posted by mjorgensen View Post
The shifter was designed with a dual bias spring system that makes the 2-3 shift more precise ...
I've got the Hurst shifter, and it is an improvement over stock. But, I still have trouble with 3rd to 4th at times, instead hitting 2nd. Does the MGW design help with that?
Old 07-28-2008, 08:33 AM   #14
mjorgensen
It will some but the only thing that will "eliminate" it is the Woodhouse engine and trans mounts!
800-889-1893 work
402-677-2935 cell
Old 07-28-2008, 09:10 AM   #15
Purdue_Boiler_Viper
Too late! I already did those. They too helped, but I still miss the 3rd to 4th when I'm in a hurry.
Short Throw Shifter Nate04SRT SRT10 and SRT10 Coupe Discussions 4 08-31-2005 02:10 PM
short throw shifter?? 4207henri RT/10 and GTS Discussions 10 02-22-2005 09:35 PM
Best Short throw shifter?? Moundir RT/10 and GTS Discussions 30 07-25-2003 09:49 AM
short throw shifter tzoid RT/10 and GTS Discussions 3 03-30-2002 11:36 PM
Who makes the best short throw shifter, Has anyone broke the new B&M shifter SNKBYT RT/10 and GTS Discussions 2 03-19-2002 07:51 PM
