Old 08-18-2008, 11:50 AM   #1
Lexciting
Question Gen1 Battery Died and Viper in lockdown mode
Situation:
I had a radio installed in my viper this Sat and the battery drained during installation. I purchased another battery (Sears DieHard Gold) and installed. The lights started flashing with the alarm set display flashing. Hit the fob Unlock and no cigar, lights still flashing. Finally, they stopped and when I hit the fob again, no chirp confirmation so I change the batteries with fresh ones. Try again, still no chirp confirmation. Turn the key and hear the fuel pump (as usual) prime, so I turn it over. The car starts then shuts off after a sec. I believe it is the alarm in lockdown mode. I check the fuse box and all fuses seem ok, outside of the #10 slot being empty.
I searched hard on the VCA and found the thread about the OFF-ACC-OFF-ACC procedure, but that isn't working for me. Car still shuts off. So my questions:
1) Does anyone know if slot #10 on a Gen1 fuse box suppose to be empty? I am hoping the radio tech took it out. Is this the alarm fuse slot that is suppose to be 25 instead of the 20 fuse? I have a service manual and can't seem to find the #10 slot description. Is that an alarm fuse or just a spare fuse holder? Strange that it was empty, whereas every fuse slot around it was occupied by a fuse.
2) Brand new battery in both car and alarm fob, the car starts for a sec and shuts off with alarm set flashing for a sec, and the fob does nothing in terms of unalarming the system. Is my assumption of alarm lockdown, feasible?
Thanks in advance for those that chime in to help
Lee
Lexciting is offline   Reply With Quote
Old 08-18-2008, 12:00 PM   #2
Steve-Indy
IN/KY VCA Member
Default Re: Gen1 Battery Died and Viper in lockdown mode
Feel free to call me.
P.S. MY 1994 Service Manual shows fuseblock slot #10 as "empty".
Old 09-12-2008, 11:57 PM   #3
Lexciting
Steve-Indy - All fuses are OK (pulled each and checked). new battery in FOB but still no response from car. Car still starts (1 sec) shutdown.
Old 09-13-2008, 08:55 AM   #4
Viper Wizard
Viper Wizard's Avatar
Exclamation Re: Gen1 Battery Died and Viper in lockdown mode
Follow section 8Q in your service manual! That should help?
CHUCK TATOR
1975-USAF/SAC/KC-135/FB-111
NRA Life Member
Viper Tech Since 1993
Viper Owner 94/RT#902
TATOR'S DODGE SINCE 1914!
Old 09-13-2008, 11:38 AM   #5
Steve-Indy
IN/KY VCA Member
Call me or sewnd your number to me if you still need help: Zvipers@aol.com
car in lockdown mode blackdog-911 RT/10 and GTS Discussions 3 03-09-2008 02:39 PM
Gen1 Battery Cutoff Switch in Trunk? TexasPettey RT/10 and GTS Discussions 3 09-28-2007 07:52 AM
HELP!! My battery died, key fob doesnt work and my alarm is set...... rraulston RT/10 and GTS Discussions 3 07-23-2007 08:45 PM
Battery died - can't remove lug nuts viperct2001 RT/10 and GTS Discussions 20 05-20-2006 10:14 AM
My Optima battery died JPL RT/10 and GTS Discussions 11 02-26-2005 11:38 AM
