#16 | |
I just had all the seals replaced with viton seals. I hope it isn't that. Also new gaskets. It only lasts for like 2 seconds and then it's gone. Is it possible that it's the water/meth? I think I read that it does prime when you turn the key on. I guess that's a question for Sean Roe.
99 ACR Silver/Steel Grey Stripes- Roe SC 8lb, Roe Heads, W/M, Bellanger, Random Tech, Iforged Wheels. |
#18 | |
Any type of smell to the smoke?
96 GTS - Roe S/C: 753rwhp, 794 rwtq Built and tuned by Macedo Motorsports |
I believe that one will find that Mobil 1 gives a whitish smoke vs. the blueish smoke of non-synthetics.
#20 |
head gasket.
#21 |
Have you lost any radiator fluid?
99 Viper (Tubes&filters, Full TNT exhaust, T&D's and other goodies) Macedo Tuned!!!! See y'all at VOI 10!!!!!!!!!!!!!!!! |
#22 |
No, I just checked both spots. I put a white t-shirt over the pipes when I started it this morning. There was nothing on the shirt when I took removed it. Don't know exactly what that means?
#23 |
SoCal Enthusiast
Is it an early 2000?
#24 | |
Don't think you're investigating black smoke right now. The t-shirt is too porous/wrong color to catch anything else. That's why I suggested cardboard. Like maybe the brown corrugated kind. You might have to have someone hold it for you while the car is started, or tape it to something to hold it. And if the white smoke only lasts a few seconds, you'll need to be moving quick to see if anything splattered on it like water vapor etc. The hot exhaust gas will dry it if it gets wet very quickly. Might best be a 2 man job. The mention of smell was also a good one. Burning oil and water vapors ain't the same when it comes to a sniff test. Once again, might need someone standing back there when the car is started to catch a quickie whiff. |
| white smoke coming out.....? | pocketAA | RT/10 and GTS Discussions | 11 | 11-14-2006 08:03 PM |
| Is White color smoke from the exaust a problem in a New FE GTS? | SF Final 286 | RT/10 and GTS Discussions | 16 | 04-04-2003 08:17 PM |
| Exhaust smoke on startup??? | onerareviper | Performance Modifications | 3 | 07-17-2002 01:13 PM |
| WHITE SMOKE COMING FROM BACK OF MY 2001 ACR | Fast Freddy | RT/10 and GTS Discussions | 12 | 12-09-2001 10:15 AM |
| Help! A question about white smoke from new exhaust system? | Viper99 | RT/10 and GTS Discussions | 10 | 08-09-2001 03:02 PM |
