I get a blast of this everytime the car has been sitting at least overnight. I am hoping it is just the water/meth that is spraying some moisture in the intake on statup. Anyone have this with the w/m setup or should I be more concerned?
Thanks Gary
99 ACR Silver/Steel Grey Stripes- Roe SC 8lb, Roe Heads, W/M, Bellanger, Random Tech, Iforged Wheels. |
Add more water and don't pack so tight....
2000 GTS, Roe 5lbs, VEC3, JMB Performance intakes, Tator Titanium CMC Cannister Coils and Injection Tap Caps, Yeti Plate, Corsa Cat Back, Innovate LC-1 WB |
Damn dude you made that up in about 2 min.
Could be a slow head gasket leak when the motor cools and contracts pulling the water in. Would probably have it looked at before there is a bigger issue.
Woodhouse Viper Service Mgr. 800-889-1893 work 402-677-2935 cell |
There we go getting all serious again.
Mike Sitton 2004 Viper SRT-10 Mamba (#18/200) Corsa Track Exhaust, K&N Cold Air Intake, SCT Flash Tune from Roe |
What should I have said maybe it's just left over Bon* water?
Good one...but we do appreciate the insight you give us when it comes to our snakes! Just giving you a hard time.
Ya I know
If it is a slow leak, can it be stopped by re-torquing all the head bolts to the maximum?
99 Viper (Tubes&filters, Full TNT exhaust, T&D's and other goodies) Macedo Tuned!!!! See y'all at VOI 10!!!!!!!!!!!!!!!! |
NO!!!!!!
Sorry
A couple of checks...
Is it one pipe or both? A head gasket leak or valve seal leak would show up on just the problem side. Unless you have 2 problem sides. The water/meth issue would be common to both sides unless you inject into each manifold runner separately. Start the car with a piece of cardboard right near the exhaust outlet. Burned oil is smoke and will not spot the cardboard. Water/coolant/meth is a vaporized liquid and should spot the cardboard. |
Dave- I will check that out and see if it is both pipes also.
generally it's the valve seals leaking when you see white smoke on startup and then goes away after the engine warms. It's the head gasket if its the opposite, white smoke after the engine warms up, not on startup.
1999 Viper ACR - Silver/Blue Stripes (1 of 30 Built) Roe Supercharged, T&D Rockers, PBJ Intake, Borla Exhaust 618 rwhp, 651 ft/lbs torque |
Wouldn't valve seals leak oil? (blue) and not coolant (white)
#15 | |
Really though, I've alway considered oil smoke to be white. Can't say I've ever seen coolant smoke. At least knowing it was coolant. |
| white smoke coming out.....? | pocketAA | RT/10 and GTS Discussions | 11 | 11-14-2006 08:03 PM |
| Is White color smoke from the exaust a problem in a New FE GTS? | SF Final 286 | RT/10 and GTS Discussions | 16 | 04-04-2003 08:17 PM |
| Exhaust smoke on startup??? | onerareviper | Performance Modifications | 3 | 07-17-2002 01:13 PM |
| WHITE SMOKE COMING FROM BACK OF MY 2001 ACR | Fast Freddy | RT/10 and GTS Discussions | 12 | 12-09-2001 10:15 AM |
| Help! A question about white smoke from new exhaust system? | Viper99 | RT/10 and GTS Discussions | 10 | 08-09-2001 03:02 PM |
