Old 08-21-2008, 07:10 PM   #1
Mopar Boy
VCA member
Mopar Boy's Avatar
Default Power Stearing Cap Popped Off !!!
So I was leaving home, gassed it down the driveway a bit and by the time I got to the stop sign on my road, I see smoke from my left hood vent!
I pull over, look under the hood, and my cap is wedged down the bottom of the engine compartment!
First, why did it pop off. Second, I need to top off my fluid now. What do I need to use? Regular Mopar stuff? Or is it Viper specific blend?
Thanks!
Robert
2002 ACR, Yellow/Black, 3.73, Autoform LeManz Wing, Custom 20" HRE Rims With Pirreli P-Zero Rosso's, Vip-Air Intake, Borla Exhaust
Mopar Boy is offline   Reply With Quote
Old 08-21-2008, 07:20 PM   #2
2000_Black_RT10
Ontario VCA Member
2000_Black_RT10's Avatar
Default Re: Power Stearing Cap Popped Off !!!
Common problem.. someone here will chime in with an alternative / aftermarket solution.. One time I looked at mine and it was just sitting there unthreaded.. I just cranked it really tight for the time being, but if I were to go on the track or whatever I'd definitely implement something to fix it in place.
2000_Black_RT10 is offline   Reply With Quote
Old 08-21-2008, 07:21 PM   #3
V10SpeedLuvr
GA VCA President
V10SpeedLuvr's Avatar
It popped off because the entire power steering system on Vipers is a complete JOKE. And not a funny joke. Many Vipers have caught fire due to the caps coming loose and the fluid leaking onto the headers. Many others have been stranded because the p/s pulley and/or bracket (both made of material weaker than wet paper) have busted. You need to order:
Power Steering to replace your cheap p/s bracket and pulley
And...
Roe Racing Power Steering Vent Tube - 92-02 - Safety - Roe Racing to make sure your cap doesn't come loose again.
I have all 3 upgrades on my car
Chad
V10SpeedLuvr is online now   Reply With Quote
Old 08-21-2008, 07:26 PM   #4
fastlane8
Banned
Use the search feature!!!
Check the date on this post!!!
I friendly reminder...CHECK YOUR POWER STEERING CAP OFTEN
fastlane8 is offline   Reply With Quote
Old 08-21-2008, 07:30 PM   #5
2000_Black_RT10
Ontario VCA Member
.. and another post
Power steering leak?
Old 08-21-2008, 07:31 PM   #6
viperdude118
Florida VCA Member
viperdude118's Avatar
Check the date on these posts!!!
Wow, an enthusiast with only 6 posts, telling a paid VCA member to use the search feature? Doesn't seem right to me.
The suggestions that Chad made are good ones, at minimum go with the Roe vent tube, it'll keep the cap from coming loose.
viperdude118 is offline   Reply With Quote
Old 08-21-2008, 07:36 PM   #7
fastlane8
Banned
Guess you don't have to be a member to use common sense!
Old 08-21-2008, 07:46 PM   #8
Mopar Boy
VCA member
Mopar Boy's Avatar
I did not know this was a common thing or I would have!
Judging from the looks of it, a VERY common thing.
So what actually (as in technically) allows the cap to pop/loosen itself?
Also, what fluid needs to be used to top it off again?
Robert
Old 08-21-2008, 08:34 PM   #9
Bravo
Reg mopar ps fluid per the parts guy at dodge.
Bravo is offline   Reply With Quote
Old 08-21-2008, 08:56 PM   #10
Viper Wizard
Viper Wizard's Avatar
Question Re: Power Stearing Cap Popped Off !!!
If I may ask everyone,
Do you check your oil?
Do you check your coolant?
Do you check your brake fluid?
Do you check your clutch fluid?
If you checked your power steering fluid as often as you SHOULD your other fluids, the results would be a TIGHT P/S cap! After checking the level in the P/S, tighten the cap as hard as you can make it by HAND and you'll find that the cap will stay on. The P/S pump used on GENI & II's came from a Jeep out of the eighty's with a plastic reservior and a plastic cap that used to live in a engine compartment with LOTS of room and a six cylinder. Now you move the same P/S pump into a engine compartment with VERY little room and a ten cylinder, with the heat differences from the two compartments is huge, the plastic parts expands a great deal allowing the cap to come loose when it cools back down and then with the motor/drivetrain vibrations, the cap may jiggle off.... NOT good!!
So spend no money and check your P/S!
CHUCK TATOR
1975-USAF/SAC/KC-135/FB-111
NRA Life Member
Viper Tech Since 1993
Viper Owner 94/RT#902
TATOR'S DODGE SINCE 1914!
Viper Wizard is online now   Reply With Quote
Old 08-21-2008, 09:01 PM   #11
fastlane8
Banned
Yet more common sense in the world of car maintenance!
Old 08-21-2008, 09:08 PM   #12
2000_Black_RT10
Ontario VCA Member
Listen to the Wizard!
Last time I checked, returned to take a picture and the problem was right in front of me..
http://www.wincom.net/mnllehti/power_steering_cap_culprit.jpg
Old 08-21-2008, 09:18 PM   #13
Viper Wizard
Exclamation Re: Power Stearing Cap Popped Off !!!
Originally Posted by 2000_Black_RT10 View Post
Holly Sheet, add some sound to it and I'd be on the other side of the room!!
CHUCK TATOR
NRA Life Member
Old 08-23-2008, 12:47 AM   #14
DJ'sviper
I took my car to the track and the tech spec removed the cap and it looked like he tightened it down. A kid at the track late that night wanted to see the engine. I half reluctantly showed him and saw I had no cap. I was glad I showed him. Could not find it. $35.00 for the cap from the dealer. Now I don't care about the techs feelings I check myself that it is tight and eveytime I use the car. John B said that a lot of times it gets lodged somewhere. If it ends up on the exhaust you will have a fire.
DJ'sviper is offline   Reply With Quote
Old 08-23-2008, 02:14 AM   #15
viper spray
I safety wired mine on , it is easy to do.
Drill a tiny hole on the outside of the cap , near the edge , past the seal and wire it to stay tight , aircraft/racer style..........
viper spray is offline   Reply With Quote
Blower belt popped off Ted Bigham RT/10 and GTS Discussions 10 08-06-2005 11:47 AM
What's on this stearing wheel? JPL RT/10 and GTS Discussions 10 02-25-2005 03:56 PM
GTS popped out of reverse?? Go Hogs Go! RT/10 and GTS Discussions 4 08-19-2002 10:31 AM
Yikes! ACR popped out of first this morning...should I be worried?? toddt RT/10 and GTS Discussions 8 05-11-2002 04:01 PM
