Old 08-24-2008, 08:23 AM   #1
Mopar Boy
VCA member
Mopar Boy's Avatar
Default Half Shaft Installation
When installing my new halfshaft (to replace the broken one) what is the correct torque specs for the bolts on the straps?
Also, can the strap and bolts be even used a second time?
Thanks!
Robert
2002 ACR, Yellow/Black, 3.73, Autoform LeManz Wing, Custom 20" HRE Rims With Pirreli P-Zero Rosso's, Vip-Air Intake, Borla Exhaust
Mopar Boy is offline   Reply With Quote
Old 08-24-2008, 12:37 PM   #2
Camfab
Camfab's Avatar
Default Re: Half Shaft Installation
Not to sound rude, but I think your second question was already covered in your last post about this subject. The correct torque is 15 ft/lbs. Technically you could re-use your bolts with some new loctite, but why would you? You've already subjected the shaft to failure and the straps and bolts were part of that system. Sounds like a factory service manual should be your next purchase.
Old 08-24-2008, 01:31 PM   #3
Mopar Boy
VCA member
Mopar Boy's Avatar
Camfab,
You are 100% correct on both accounts! Some of my questions were covered in the last posting. Just wanted a clarification as a mechanic friend (who apparently is not as knowledgable as previously believed) is still hell bent on saying the straps and bolts are fine as they are not deformed. Just wanted clarification. I was not trying to confuse you by asking again!
As for the service manual, just got a complete 3 book set set off Ebay about an hour ago...
Thanks!
Robert
Half-Shaft Question? snampro RT/10 and GTS Discussions 5 03-23-2007 12:16 AM
Half shaft replacement? johnk SRT10 and SRT10 Coupe Discussions 3 03-04-2007 02:32 PM
who has the best half shaft J Carter RT/10 and GTS Discussions 3 05-13-2004 02:56 PM
Half Shaft Question Jeff Lemke RT/10 and GTS Discussions 3 03-27-2004 07:13 AM
Half Shaft Question PETSN8K RT/10 and GTS Discussions 1 08-23-2003 11:04 AM
