Old 08-24-2008, 11:29 AM   #1
martyb
Default VEC 2 communication error
Trying to hook up my laptop to the VEC2 for a data log. In the VEC2 software, I click the verify button, and get the message "communication error". After about 2 hours of trying to figure it out, I am looking for help.
Any ideas???
martyb
martyb is offline   Reply With Quote
Old 08-24-2008, 11:58 AM   #2
Steve 00RT/10
Steve 00RT/10's Avatar
Default Re: VEC 2 communication error
Any ideas???
martyb
Make sure the VEC is set to the right port on the computer. You can find that in the VEC program settings and computer device manager I think.
If you are using a serial to USB port cable. You could try a different one. I had this issue last year with my new laptop which didn't have a serial port. The Radio Shack cable I bought, and exchanged......would not work. My EASE software would not work either. Both programs had worked with the old computer. I called EASE about it and they said they had seen this before with various cables....Radio shack being one of them. I bought one from EASE and no more issues with either program.
Steve
Old 08-24-2008, 12:01 PM   #3
martyb
Thanks for the tip Steve, I will try a different cable and see if that works.
marty
Old 08-24-2008, 01:20 PM   #4
calling joseph dell, calling joseph dell.......
510 Stroker, Greg Good heads, DLM Paxton, Rebuilt and Tuned by DLM. Still need more boost......
Old 08-24-2008, 08:35 PM   #5
SYNFULL
SYNFULL's Avatar
I tried but could never get the connection to work with Vista. What os are you using. Also I have had the vec 2 say "communication error" in the verify box and then work when I click on info, and then read or write.
99 ACR Silver/Steel Grey Stripes- Roe SC 8lb, Roe Heads, W/M, Bellanger, Random Tech, Iforged Wheels.
SYNFULL is offline   Reply With Quote
OBD II Error.... Help ? RobZilla RT/10 and GTS Discussions 10 01-21-2008 10:21 PM
VEC2 communication problem. puma RT/10 and GTS Discussions 2 07-06-2007 11:29 AM
SQL ERROR: Database error only visible to forum administrators Vipermann1 Sneaky Pete's Place 10 04-26-2005 08:43 AM
Communication Devices for Helmets Question 8 0f 200 RT/10 and GTS Discussions 9 12-18-2001 12:30 AM
