Old 09-28-2008, 07:18 PM   #16
99 R/T 10
99 R/T 10's Avatar
Default Re: o2 sensors Gen 1
Just so you know, the wires that were arcing on me were the MSDs, relatively new too(8 month old). Just saying...........
Old 09-28-2008, 07:48 PM   #17
Tom, F&L GoR
Tom, F&L GoR's Avatar
The Gen 1 is non-return, so the pump cannot be suffering from hot fuel returned from the engine. If it is making a different noise, perhaps it is either failing to provide pressure when run for a while, or pushing too hard against a plugged filter. A quick, cheap thing might be to replace the fuel filter.
Tom,
Old 09-29-2008, 06:01 PM   #18
martyb
All right, my issue is fuel pressure. I am going to try Tom's suggestion and replace the filter, but I am guessing its the pump. PBJ just put in a Walbro 255 less than a year ago, and I have driven the car about 1800 miles since the install. Are these pumps that weak??
martyb is offline   Reply With Quote
Old 09-29-2008, 07:33 PM   #19
Tom, F&L GoR
Relieve the pressure up at the manifold before you get under the car to change the filter.
In fact, do anything you can to protect your eyes when underneath- there is no good way not to get wet with fuel.
Read up on how the fuel filter ends disconnect from the fuel line.
Tom,
Old 09-29-2008, 07:56 PM   #20
martyb
Thanks Tom, yeah, its a fun job for sure!! I am hoping the filter will fix the problem, but I am not holding my breath. If its the pump, I am wondering if it is still under any warranty, hmmmm
Old 09-30-2008, 01:54 PM   #21
martyb
All right, before I start the tank removal, just wondering if my low fuel pressure could be the MSD BAP? Any way to test it? I would hate to remove the tank and replace the pump, only to find out it was not needed.
Also, any tips on tank removal?
martyb
O2 sensors going out Dawg2Snake SRT10 and SRT10 Coupe Discussions 17 07-25-2007 10:44 AM
96 RT/10 02 sensors SNKEBIT RT/10 and GTS Discussions 2 08-28-2006 10:53 PM
'01 GTS, '96 PCM and O2 sensors KenH RT/10 and GTS Discussions 3 08-08-2005 11:12 AM
02 sensors? Russ M RT/10 and GTS Discussions 4 04-06-2003 05:35 PM
Sensors Archive Management 0 12-31-1969 06:00 PM
