Old 09-20-2008, 03:45 PM   #1
martyb
Default o2 sensors Gen 1
Trying to figure out a part/full throttle miss on my Roe gen 1. replaced plugs/wires, no change. car runs fine for the first 8-10 minutes, and then developes a miss and full throttle, half throttle or less car still runs fine. I don't want to start throwing money at parts guessing if they are the culprit or not. no CEL or codes thrown. my next thought is O2 sensors. any way of removing and testing them, or should i just buy new ones? was also thinking tps, map, iac.
boy i wish there was a good viper tech in chicagoland!!!
martyb
martyb is offline   Reply With Quote
Old 09-20-2008, 04:00 PM   #2
grcforce327
Default Re: o2 sensors Gen 1
Full throttle=open loop!!!
Old 09-20-2008, 04:04 PM   #3
martyb
grcforce327,
does it at anything more than 1/2 throttle.
Old 09-20-2008, 05:05 PM   #4
grcforce327
Originally Posted by martyb View Post
grcforce327,
Marty,your first post said full throttle!You can hookup a data scan tool to see if it is happening in open or closed loop.Scan tool will also show the fuel adaptives and if the O2's are functioning properly.You have a Roe,so my guess is you also have a Vec correct??? If so,the issue could also be in the tune.If you were near me,I would be happy to dive in and help try to figure it out!
Guy C.
Old 09-20-2008, 05:56 PM   #5
martyb
Thanks gforce, yes I have a VEC2. PBJ did the tune, which was spot on, so I doubt that would be the issue. I think I need to find someone with a scan tool, not sure if the local autozone has a scan tool or just a code reader. I appreciate your offer to dive in and help!! I am sure its something simple, I just don't want to start replacing parts if they don't need to be replaced!!
Old 09-20-2008, 07:20 PM   #6
grcforce327
Joe is awesome.but there still could be an issue with the vec !You can drive all the way down here and we'll hook it up and try to pinpoint the issue!
Old 09-21-2008, 09:01 AM   #7
martyb
If I could find a damn cable that works, I would be able to datalog since I have the vec software. I think that may be the best bet. Seems there are some issues with a serial to usb cable convertor.
Old 09-21-2008, 09:14 AM   #8
Tom, F&L GoR
Tom, F&L GoR's Avatar
I can give you a hint from personal experience. My Gen 1 was having problems (mostly stock engine) and I borrowed a scan tool. The O2 sensors were each giving faulty signals for several seconds at a time but the check engine light never came on. Turns out that the Gen 1 CEL isn't programmed to stay on unless the fault exists for 8 seconds minimum. (I may have that wrong, but it was many seconds!) Since my O2 signals returned to acceptable within that time, it didn't trigger the light. I replaced both and of course, that fixed everything.
Tom,
Old 09-21-2008, 09:48 AM   #9
IEATVETS
Illinois VCA Member
IEATVETS's Avatar
Chicago is loaded with "Viper Techs" Marty! Contact Tom at Fields dodge or Jon at Roanoke Motors or Scotty Sutker(tooofast) or SVS etc.
Good luck.
2000 GTS Steel grey/Silver stripes
1 of 126
Old 09-21-2008, 09:59 AM   #10
martyb
Thanks IEATVETS.
martyb
Old 09-28-2008, 11:57 AM   #11
martyb
2 new O2 sensors installed, car is still missing when warmed up. I can tell it is very rich(burns your eyes, popping on decel). Thinking of trying to replace the MAP sensor. Would a faulty MAP, TPS, cam or crank sensor cause a rich condition?
martyb
Old 09-28-2008, 11:58 AM   #12
martyb
by the way, 1/2 throttle is still fine, only under more than 1/2 throttle does is miss.
Old 09-28-2008, 06:18 PM   #13
Tom, F&L GoR
Popping back is normal depending on your exhaust system.
I don't think it would run at all if cam or crank position sensor were bad.
I'd spend for TPS first.
And another thought. My Dakota had a wire break inside the harness. It was one of the O2 sensor wires, so while the OBD-II and other diagnostics pointed to replacing the O2 sensor, it really wasn't the sensor itself.
Tom,
Old 09-28-2008, 07:01 PM   #14
99 R/T 10
99 R/T 10's Avatar
I had the same issue(athough on my Gen II) when at high loads at 5000 RPM or greater. Turned out to be the sparkplug wires. They were arcing at the ignition block. Check to make sure they are tight and have the contact grease on them. What wires did you use? ab's wires? (home)
Old 09-28-2008, 07:07 PM   #15
martyb
99R/T10
Had the MSD wires from Sean, just replaced them with new wires from Tator, along with new plugs and O2 sensors. One thing I forgot to mention, the Walbro 255 pump that pbj installed is really singing once the car warms up. I can really hear it when the car is running, even at idle. Don't know if that would have anything to do with it or not. I hate buying parts chasing the issue, but that may be the route that I go.
O2 sensors going out Dawg2Snake SRT10 and SRT10 Coupe Discussions 17 07-25-2007 10:44 AM
96 RT/10 02 sensors SNKEBIT RT/10 and GTS Discussions 2 08-28-2006 10:53 PM
'01 GTS, '96 PCM and O2 sensors KenH RT/10 and GTS Discussions 3 08-08-2005 11:12 AM
02 sensors? Russ M RT/10 and GTS Discussions 4 04-06-2003 05:35 PM
Sensors Archive Management 0 12-31-1969 06:00 PM
