So i just got some drilled and slotted rotors along with some ebc redstuff pads. I was reading my DODGE repair manual that i picked up and it says i need a special tool tool to push the rear piston back in... is this really required? or is there another way i can do it.
also just another quick question, i was driving my 96 gts last night and i noticed the transmission making sort of a whine at certain rpms, is that normal? |
You dont need a special tool, but it makes the job a whole lot easier and quicker. You can pick one up at your local auto parts store for less than $20. The tool is universal. It looks like a little metal box with nubs on it that help to turn the piston back into the caliper. It's very handy.
1997 GTS. Red/Black Stripes, Paxton Blower, Corsa Cat-Back, Unitrax Shafts. ![]() "Obstacles are what you see when you take your eyes of the goal." - 1992 Nascar Champion Alan Kulwicki |
I used needle nose pliers to do the job. I am cheap(as most will attest to
), but they work just as good.
99 Viper (Tubes&filters, Full TNT exhaust, T&D's and other goodies) Macedo Tuned!!!! See y'all at VOI 10!!!!!!!!!!!!!!!! |
#4 | |
I have one in my garage right now since I did my brakes last weekend Disc Brake Caliper tool OEM 27111 You need to rotate the piston and push it in at the same time. This tool does both at the same time and is simple to use.
Jim 2002 GTS ACR Graphite Gray w/silver stripes |
#5 | |
NAPAONLINE®
1996 Blue/White GTS- Smooth Tubes, K&N's and PS2's |
2001 is a different story as it is ABS and has 'notches' instead of holes in the pistons. I used a C-clamp and a custom fabricated socket I made together. 1 side screwed itself in almost, while the other side was a major PITA. I couldn't get the pistons to move until I removed the Ebrake lever from the caliper.
Ted
It may not be obvious, but since I've seen the internal damage it causes, I will say it out loud here.
The pistons must rotate. The pistons are riding on threaded rods. You must push and rotate to get them deeper into the bore. You cannot just push with a c-clamp. Evidence: ![]() These are actually from folks unscrewing the brake lever arm, but the point is that there is "stuff" behind the piston - it is not like the front calipers.
Tom, Fuels & Lubes Geek of the Realm Last edited by Tom, F&L GoR; 09-25-2008 at 07:30 PM. Reason: I'm old and forgot something... I think |
Perhaps my post wasn't easy to understand.
The pistons have to turn to go into the calipers. They do not move without turning while going into the calipers. I had to use both socket (to turn piston) and C-clamp (to push the piston in) to get the caliper pistons to turn and compress. Ted
awsome thanks everybody.
what about the tranny question.
1996 GTS-smooth tubes w/ s&b filters, mgw goodies. comming soon: paxton? |
Give your tranny a shot of penicillin and you'll be fine.
![]() Actually, you might want to consider a fluid change on your transmission, and possibly switching to the newer fluid. Here is some good reading on that. Save a sample of the drain fluid in a clean bottle for further analysis if wanted. Under the Car and have a last minute question Also, does it do it in every gear? At the same RPM? Coasting or acceleration? |
i just bought the car a lil over a month ago from bj motors and he said he changed all the fluids. it seems to only do it when accelerating, and not in a specific gear, at higher rpms. its not really loud or anything i can just hear it and i was wondering if it was normal or not.
#12 | |
Chuck 98 RT/10 BabelMotorsports.net SAFEMotorsports.com |
#13 | |
Leeland 98 Silver GTS (no stripes) HRE 547's |
VCA Member Site Supporter
Answer: I think i would be looking at the rear end.If you have a broken tooth it may only make noise on accel or under load.While coasting you have now load on the ring and pinion and the noise goes away.Does it make a difference what gear you are in?does it make noise in fourth gear?If the noise is there in all gears its most likely not the trans.If the noise goes away in fourth gear than you may need to be looking at transmission problems.
Here is a link to 4 pages of searches for you to diagnose. I know from owning a 96 early years the noise was a common problem under idle. Hope this links help you find your problems. If not let me know and we can try and diagnose with some help. Here is the link. Bernie http://forums.viperclub.org/search.php?searchid=402766 |
| Brake pad replacement | goldcup | Tire , Wheel, Brake and Suspension | 8 | 01-25-2008 04:17 PM |
| Brake rotor replacement options? | snampro | RT/10 and GTS Discussions | 8 | 12-31-2005 10:21 AM |
| Brake Replacement | DodgeViper01 | RT/10 and GTS Discussions | 50 | 06-16-2004 05:50 PM |
| Brake Pad Replacement Instructions? | bwhitmore | RT/10 and GTS Discussions | 9 | 10-28-2003 12:03 PM |
| Replacement Emergency Brake Handle | MJBComp | RT/10 and GTS Discussions | 0 | 11-29-2001 11:33 PM |
