Old 09-24-2008, 11:26 AM   #1
EMnuke123
Default brake pad replacement?
So i just got some drilled and slotted rotors along with some ebc redstuff pads. I was reading my DODGE repair manual that i picked up and it says i need a special tool tool to push the rear piston back in... is this really required? or is there another way i can do it.
also just another quick question, i was driving my 96 gts last night and i noticed the transmission making sort of a whine at certain rpms, is that normal?
EMnuke123 is offline   Reply With Quote
Old 09-24-2008, 11:44 AM   #2
Sweet Ride
AZ VCA Member
Sweet Ride's Avatar
Default Re: brake pad replacement?
You dont need a special tool, but it makes the job a whole lot easier and quicker. You can pick one up at your local auto parts store for less than $20. The tool is universal. It looks like a little metal box with nubs on it that help to turn the piston back into the caliper. It's very handy.
1997 GTS. Red/Black Stripes, Paxton Blower, Corsa Cat-Back, Unitrax Shafts.
"Obstacles are what you see when you take your eyes of the goal." - 1992 Nascar Champion Alan Kulwicki
Sweet Ride is offline   Reply With Quote
Old 09-24-2008, 12:29 PM   #3
99 R/T 10
99 R/T 10's Avatar
I used needle nose pliers to do the job. I am cheap(as most will attest to ), but they work just as good.
Old 09-24-2008, 10:08 PM   #4
AZTVR
AZTVR's Avatar
Go to Autozone. At least mine locally has the proper tool in their Loan-a-Tool Program. Basically, you pay for the tool and then they refund your money when you bring it back. No hassle. Just make sure that everything is in the box before you leave the store so no questions arise when you bring it back.
I have one in my garage right now since I did my brakes last weekend
Disc Brake Caliper tool OEM 27111
You need to rotate the piston and push it in at the same time. This tool does both at the same time and is simple to use.
Jim
2002 GTS ACR Graphite Gray w/silver stripes
Old 09-25-2008, 12:39 AM   #5
Ratical2
No California VCA Member
Ratical2's Avatar
I got mine at Napa for $12.
NAPAONLINE®
Old 09-25-2008, 02:00 AM   #6
RTTTTed
Western Canada VCA Member
RTTTTed's Avatar
2001 is a different story as it is ABS and has 'notches' instead of holes in the pistons. I used a C-clamp and a custom fabricated socket I made together. 1 side screwed itself in almost, while the other side was a major PITA. I couldn't get the pistons to move until I removed the Ebrake lever from the caliper.
Ted
Old 09-25-2008, 07:24 PM   #7
Tom, F&L GoR
Tom, F&L GoR's Avatar
It may not be obvious, but since I've seen the internal damage it causes, I will say it out loud here.
The pistons must rotate. The pistons are riding on threaded rods. You must push and rotate to get them deeper into the bore. You cannot just push with a c-clamp.
Evidence:
These are actually from folks unscrewing the brake lever arm, but the point is that there is "stuff" behind the piston - it is not like the front calipers.
Tom,
Last edited by Tom, F&L GoR; 09-25-2008 at 07:30 PM. Reason: I'm old and forgot something... I think
Old 09-25-2008, 10:43 PM   #8
RTTTTed
RTTTTed's Avatar
Perhaps my post wasn't easy to understand.
The pistons have to turn to go into the calipers. They do not move without turning while going into the calipers. I had to use both socket (to turn piston) and C-clamp (to push the piston in) to get the caliper pistons to turn and compress.
Ted
Old 09-26-2008, 04:07 PM   #9
EMnuke123
awsome thanks everybody.
what about the tranny question.
1996 GTS-smooth tubes w/ s&b filters, mgw goodies. comming soon: paxton?
Old 09-29-2008, 07:33 AM   #10
Give your tranny a shot of penicillin and you'll be fine.
Actually, you might want to consider a fluid change on your transmission, and possibly switching to the newer fluid. Here is some good reading on that. Save a sample of the drain fluid in a clean bottle for further analysis if wanted.
Under the Car and have a last minute question
Also, does it do it in every gear? At the same RPM? Coasting or acceleration?
Old 09-29-2008, 08:13 PM   #11
EMnuke123
i just bought the car a lil over a month ago from bj motors and he said he changed all the fluids. it seems to only do it when accelerating, and not in a specific gear, at higher rpms. its not really loud or anything i can just hear it and i was wondering if it was normal or not.
Old 09-30-2008, 11:17 AM   #12
Chuck 98 RT/10
Spiffy Florida VCA Member
Chuck 98 RT/10's Avatar
Vipers are noisy cars. Hard to say if yours is normal or not. Change the fluids - tranny and rear. I've known techs to put in the incorrect fluid.
Chuck 98 RT/10
BabelMotorsports.net
SAFEMotorsports.com
Old 09-30-2008, 02:39 PM   #13
LPDesRoche
NC VCA Member
LPDesRoche's Avatar
If you bought the car from Bernie, I am willing to bet it is a normal noise. Everything that I have seen come out of his place is top notch. The T-56 tranny can have a bit of gear whine at times so that may be what you are hearing. The viper spec version of the transmission uses a gear set with a different cut making them stronger , but a tad louder than the GM version.
Leeland
98 Silver GTS (no stripes)
HRE 547's
LPDesRoche is offline   Reply With Quote
Old 10-01-2008, 08:41 PM   #14
BJ MOTORS
BJ MOTORS's Avatar
Answer: I think i would be looking at the rear end.If you have a broken tooth it may only make noise on accel or under load.While coasting you have now load on the ring and pinion and the noise goes away.Does it make a difference what gear you are in?does it make noise in fourth gear?If the noise is there in all gears its most likely not the trans.If the noise goes away in fourth gear than you may need to be looking at transmission problems.
Here is a link to 4 pages of searches for you to diagnose. I know from owning a 96 early years the noise was a common problem under idle. Hope this links help you find your problems. If not let me know and we can try and diagnose with some help. Here is the link.
Bernie
http://forums.viperclub.org/search.php?searchid=402766
Bernie Katz
1-804-784-7208
www.bjmotors.biz
Dodge Vipers & Exotics
BJ MOTORS is offline   Reply With Quote
Brake pad replacement goldcup Tire , Wheel, Brake and Suspension 8 01-25-2008 04:17 PM
Brake rotor replacement options? snampro RT/10 and GTS Discussions 8 12-31-2005 10:21 AM
Brake Replacement DodgeViper01 RT/10 and GTS Discussions 50 06-16-2004 05:50 PM
Brake Pad Replacement Instructions? bwhitmore RT/10 and GTS Discussions 9 10-28-2003 12:03 PM
Replacement Emergency Brake Handle MJBComp RT/10 and GTS Discussions 0 11-29-2001 11:33 PM
