Old 09-28-2008, 06:56 PM   #1
gen2lover
gen2lover's Avatar
Default oil pressure gen 2 stock
is 50 normal for a stock gen 2 rt-10? it stays about 50 all the time regardless of weather or driving etc...
Old 09-29-2008, 07:47 AM   #2
Default Re: oil pressure gen 2 stock
My '01 runs 60 psi on Mobil 1 10W-30 at speed. Idles around 45 psi hot. I've read these gauges are not that accurate.
Old 09-29-2008, 04:10 PM   #3
bvk
mine is 40-50 most of the time, drops to 30ish at idle when hot.
bvk is offline   Reply With Quote
Old 09-29-2008, 04:46 PM   #4
GreyKnight
60 all the time. I checked in about 98 degree weather.
GreyKnight is offline   Reply With Quote
Old 09-29-2008, 06:06 PM   #5
chimazo
Virginia Maryland VCA Member
chimazo's Avatar
Mine also stays pretty much the same regardless of the temp or RPM, leading me to believe (as someone already mentioned) that it's not very accurate.
'96 Caprice 9C1
'08 Hummer H3
Old 09-29-2008, 09:35 PM   #6
RedSrt007
Mines about 35 idle, 40-50 warm, and 50-60 cold
RedSrt007 is offline   Reply With Quote
Old 09-29-2008, 09:45 PM   #7
triblk6spd
Mine runs around 70 most of the time. dropping slightly at idle and raising slightly when revving. Should I be worried. How would oil pressure get be too high? I run Royal Purple 10-30.
triblk6spd is offline   Reply With Quote
Old 09-30-2008, 09:07 PM   #8
Originally Posted by GreyKnight View Post
60 all the time.
With the key off too? Damn man, get a new gauge!!
Old 09-30-2008, 09:13 PM   #9
Yes I would be worried. However fellow Texan, as your proximity to me is close I'd be happy to examine your car for free of charge. Please leave it at the Wendy's with the key under the mat. We'll be watching from across the way, and will fax a report when finished with the car.
Really though, some engines have an internal bypass valve back to the pan to prevent over pressure to the journals. Maybe someone can clarify if the Viper Gen2 engine has this feature. Heck, my dune buggy with 50's technology has 2 bypass valves. One at the pump and one at the front main (engine is backards...).
Old 10-01-2008, 12:07 AM   #10
gen2lover
gen2lover's Avatar
so is 40 all the time bad? near 45 when hot? does oil amount affect pressure? low or right on (full)?
Old 10-01-2008, 07:54 AM   #11
40 does seem average compared to some, but what concerns me is why you would say 45 hot and 40 all the time. You usually have a lower number when hot, and how do you have 40 all the time and 45 when hot, when it's 40 all the time???
Your question about oil pressure... First an explanation of what pressure is. It is the resistance to flow.
Things like this typically affect pressure:
-> Pipe size, or in the case of an engine, oil passages. Bigger pipe or passage, less resistance to flow and lower pressure.
-> Flow rate, or gallons per minute, as more flow in the same pipe size generates more resistance and more pressure.
-> Fluid viscosity is a player, but more than likely the difference between thick or thin oil does not affect pressure until it reaches the ultimate reduction in pipe size, the bearing journals. Yes, that's where the passages get tight, where most of your pressure is built, and where thicker oil gives you a higher pressure.
It is important to note about the pump itself. Most if not all oil pumps are positive displacement. Meaning for every revolution or cycle they take a predetermined amount of fluid and move it through the pipe. Period. Well, with the exception that there are slight mechanical clearances that can have internal leakage. This positive displacement phenomena is also why many of them have a relief valve in them so that if the oil passages get blocked or if the oil is too thick to pump, it just dumps back into the pan.
A little more on pumps, in regards to fluid viscosity. In simple terms, the thicker oils pump at the same rate as thinner oils. Thicker oils just take more power to run the pump (robbed from the engine...) as this is a positive displacement pump and both oils will flow at the same rate at a given pump or engine rpm.
A note on thicker oils and the warm fuzzy feeling of more pressure as read on the gauge. Remember that part about the majority of the pressure drop is at the bearing journals? And that thicker oils will give you better pressure trying to get by those tight clearances? That is not all good, especially if the Viper engine has any internal relief or bypass valves (I do not know this fact or not). Reason why this "good" pressure with thick oils can be bad is that yeah, you got great pressure, but little flow past the bearings. Bearings are now running with great pressure but less lubrication. The oil has to go somewhere though, and if the engine has internal relief features built in then that is where it goes. Otherwise, the pump and V10 engine powering it must work it's ass off pumping that thick stuff wasting your hp.
I think you asked about oil level, didn't you? Without another technical speech, which I could dive in again, the oil level only affects pressure if the pump starves for oil and flow stops or becomes intermittent. Flow of course being one of the constituents of pressure. Lower flow, lower pressure. And yes, lowering your pressure by lowering flow due to pump starvation is B-A-D! I doubt you have that problem, and depending on the movement dampening bult in to the gauge, the gauge would bob up and down all the time. Yours is stuck on 40 right?
Old 10-01-2008, 08:24 AM   #12
ViperJon
ViperJon's Avatar
Were you at a Holiday Inn last night, Dave?
Damn impressive.....
97 Blue and White GTS
98 Red and Black GTS
ViperJon is online now   Reply With Quote
Old 10-01-2008, 09:03 AM   #13
After 27 years in chemical engineering & maintenance, I can't help myself.
Old 10-01-2008, 12:42 PM   #14
bvk
yes thankyou, very informative.
STOCK AIR PRESSURE SENSORS Racer Robbie SRT10 and SRT10 Coupe Discussions 30 07-12-2006 11:11 AM
Tire Pressure for Stock Runflats as well as BFG DR's INFURNA SRT10 and SRT10 Coupe Discussions 6 02-13-2006 07:18 PM
Stock flex-pipe needed, preferably with the stock cats attached Steamroller RT/10 and GTS Discussions 7 03-08-2005 08:02 AM
Stock Tire pressure for Road Racing Kai SRT10 SRT10 and SRT10 Coupe Discussions 0 03-12-2004 03:15 PM
What is he stock fuel pressure suppose to be at? Help! ab RT/10 and GTS Discussions 11 01-20-2004 02:04 PM
