Old 12-04-2008, 08:41 PM   #31
crazyspeed
Default Re: ALL MOTOR BUILD!!(Pics)
Originally Posted by Jerome Sparich View Post
The angle of the cross hatch looks like hell. Atleast it does in that pic. It may just be the pic, but I am not too sure it is.
Looks like the hone was moving upward and downward much too fast. That is unless the ring manufacturer calls for such a spec?
Or much to slow????
crazyspeed is offline   Reply With Quote
Old 12-05-2008, 02:57 PM   #32
Jerome Sparich
Originally Posted by crazyspeed View Post
Or much to slow????
Correct, much too slow. I can not believe I even made that mistake when I do this for a living.
Damn meds
Jerome Sparich is offline   Reply With Quote
Old 12-11-2008, 05:02 PM   #33
2001 GTS
After further review, there is nothing wrong with the cross hatching
But BIG THANKS TO MIKE (99 RT/10)!!!
The rocker stands I bought were for a GEN3 and Mike came through and sent me his GEN2 stands to keep this build going!!!
Old 12-12-2008, 11:08 PM   #34
J DAWG
This is the way to perform a DIY build. Take your time, get some really good parts and enjoy the process. I would say the 600 mark will be achieved easily and I cant wait to see/hear the car. Very nice setup.
J
2008 SRT Orange Roadster
Gone-01' Sapphire RT/10 Creampuff 10.19 at135 (620rwhp 690rwtq)
12/21/04 - 3/11/05 R.I.P. Jackson
J DAWG is offline   Reply With Quote
Old 12-13-2008, 07:48 PM   #35
Disturbed
Suspended
I see a easy 600rwhp in that setup. I'm glade you took my advice and went with the higher CR...you will be happy with it. My motor is REAL happy with that cr.
For the most part, you have the N/A Build I wish I could have done at the time. The only thing I would do different I would add/change would be to make it a 510cid...or use a SRT crank and make it a 522cid stroker. You could use a slightly larger cam and make about 650rwhp.
Get that thing done and well meet up and get some vid of us doing some 50-150mph roll-ons in mexico.
Disturbed is offline   Reply With Quote
Old 12-14-2008, 03:11 AM   #36
Camfab
Camfab's Avatar
Your going to love that N/A power! If I go through my motor again, I will go with 11:5/1 as well. Vipers love compression.
Old 12-14-2008, 09:02 AM   #37
vp97
Collinsville TX Viper owner
Nice list of parts! The stock intake will kill your combo, unless it is heavily ported.
vp97 is offline   Reply With Quote
Old 12-14-2008, 11:38 PM   #38
Camfab
Camfab's Avatar
I run a bone stock manifold with stock throttle bodies, airbox and filters and make 585 RWHP.
Old 12-15-2008, 05:55 AM   #39
vp97
I also run a bone stock intake and tbs. My combo is good for 603whp and 610wtq. With such a large cam, he will need rpm and a bunch more air to make his goal of 650.
Old 12-15-2008, 11:28 AM   #40
2001 GTS
Greg Good did all he could with the stock intake, but there is another intake in the works for 2009.
Old 12-15-2008, 03:46 PM   #41
vp97
Thats good news! I just completed a gen2 stroker with Good heads on it,very similar to your package. With stock tbs and port matched intake, it did 626hp/622tq. It was was starving for air past 5500rpm. I do have a set of 70mm tbs to put on it and then back to the dyno it goes. With your aftermarket manifold, I think it will be well over 650hp but at a much higher rpm. Should be a mean SOB when you get all worked out!
Old 12-15-2008, 08:27 PM   #42
Disturbed
Suspended
All of you N/A guys with over 560rwhp....
...ALL OF YOU CAN RUN HIGH 10'S ALL DAY LONG ON PUMP GAS AND STREET TIRES...
01 GTS is going to have more power than me. I've run 11.01@128mph w/ 1.9 60ft time. I think my ACR has some 10.80's in it. I think when Steve is done...he will have atleast 650rwhp N/A. I bet with some slicks and a few more tricks...he'll be in the 9's.
GO GTS GO
Old 12-15-2008, 10:47 PM   #43
Camfab
Camfab's Avatar
GO GTS GO
I've been trying to make the 10 sec club, but I get booted after a couple of runs each time. With track days few and far between it's been tough. Hopefully I'll have another chance soon, I just need some new tires. 11.29@129mph 1.8 60 ft. with a really heavy cross wind and an 85 degree air temp.
Old 12-16-2008, 06:55 AM   #44
2001 GTS
Thats the plan!!
Old 12-17-2008, 02:00 AM   #45
Greg Good Cylinder Heads
What some turd heads!
Greg Good Cylinder Heads is offline   Reply With Quote
Old 12-18-2008, 10:30 AM   #46
banton
N/A cars are
And don't even get me started on GG heads......
J/K can't wait to see what the results of this build are, 2001 GTS!
Signed,
N/A GTS 594rwhp/585rwtq
banton is offline   Reply With Quote
Old 12-18-2008, 07:55 PM   #47
banton
Quick 2-part question maybe someone can help provide some info on....I, like several others are still using the stock intake manifold. At what point (what is an indicator) that one would benefit from having it port-match, etc? Secondly, is the power gain mainly at peak or would it provide increased performance throughout the power band?
Thanks in advance!
Old 12-18-2008, 08:27 PM   #48
hardtop
If you have ported heads the ported intake will pick up power everywhere.
hardtop is offline   Reply With Quote
Old 12-18-2008, 09:14 PM   #49
banton
I think you mis-understood my question or more likely, I didn't express myself clearly.
I know the impact of the ported heads, I have those already. My question is regarding porting/modifying the stock intake manifold.
Thanks.
Old 12-18-2008, 10:12 PM   #50
hardtop
I've had cars pick up 12-15 rwhp in the midrange with a ported intake, but it need a good set of heads to do it.
Old 12-18-2008, 10:27 PM   #51
DC Performance
DC Performance's Avatar
That looks like a great build. I have found in the past that a few simple things can help get the peak numbers you want. First off, verify your compression ratio. These engines love compression with a big cam. I have had engines pickup 50 rwhp with a point change. You can get a cylinder and combustion chamber volume check tool on line for about $100. Cranking compression should be at least 180 psi (even with that cam). Just changing to a thinner gasket can get you 1/2 point.
Centerline the cam for peak power, you may loose torque down low but will gain power from 5000-6200.
Use a 5 into 1 merge header. 1 5/8ths to 1 3/4 step headers with 29 inch primary tubes and a Burns merge make best peak power. CDI, Archer, SVS and American Racing have made headers like this.
Do not go with too big of an injector, with low vacuum and a big nozzle the engine will be hard to tune down low and will run too rich when cold. This tends to wash the oil out of the rings and cause higher oil consumption.
There are some changes you can make for windage losses as well, this can add some hp.
Just my 2 cents. Hope to see you make those numbers with a NA build.
Dan Cragin
President, DC Performance Inc
310-841-6996
DC Performance.com
Old 12-19-2008, 12:55 AM   #52
Your intake is stock? I thought it was at least port matched.
I've had solid 10-12 hp gains (peak #) reported back to me on the back2back tests done in the past.
Ever upgrade the fuel system?
Greg
Thanks in advance!
Old 12-19-2008, 01:02 AM   #53
Hey Dan, how are you doing out there?
Steve is one of those guys that makes an awesome customer. Why? Main reason is he listens. The compression is about as high as he should go on pump gasoline, he let me talk him into a bigger cam, the qunch is very tight etc.
I really like N/A horsepower. I hope it does well.
Greg
Old 12-19-2008, 07:57 AM   #54
banton
Greg
Hey Greg,
Nope, intake is still untouched. Fuel is still stock too.
Plan on taking care of both in 2009, which should push me over the 600rwhp mark
Old 12-19-2008, 09:11 AM   #55
Andrew2KRT10
Andrew2KRT10's Avatar
Nice fingerprint close-up
Andrew A. Cinque
2000 Steel Gray RT/10
2003 Ram 1500 HEMI
Andrew2KRT10 is offline   Reply With Quote
Old 12-19-2008, 09:33 AM   #56
2001 GTS
Greg
Haha...I'm flattered Greg.
But Greg was the biggest help of anybody on what the final specs needed to be and what I needed for it all to work together to shoot for big numbers in the end.
And Dan:
The cam was advanced 2 degrees IIRC.
The 65lb injectors will be scaled down with the Vec3, hope I don't have any problems there.
Steve
Old 12-19-2008, 02:41 PM   #57
fe4snake
fe4snake's Avatar
It looks like a very nice build!
GG did my heads too, I kept the stock pistons and the car dynoed @ 575rwhp. on a 93 deg. day.
My CR is 10.66, and GG did port match the intake manifold.
The stock TB are also ported by DLM, I did keep my stock injectors as per by DLM.
I agree with Dan about the tuning down low with the large injectors. I had the some problem
with my tunning due to my large cam, even with the stock injectors. I still get some idle hang when
engine is cold and when engine is coasting. Need to visit DLM again to correct the problem.
I hope you reach those numbers. Good luck to you.
fe4snake is offline   Reply With Quote
Old 12-22-2008, 01:24 PM   #58
2001 GTS
Nice numbers! I guess my biggest concern will be the tuning, but Joseph Dell said he would help with that.
Old 12-29-2008, 11:41 AM   #59
2001 GTS
Can anyone tell me of I am going to have problems with the 65lb injectors? They are low impedance.
Old 02-14-2009, 06:44 PM   #60
2001 GTS
Almost there!
Here are some crappy pics from my blackberry:
Up close of the billet valve covers that a friend is making:
2008 Vmag Motor - Pics WANTED SRT10 and SRT10 Coupe Discussions 0 07-03-2007 11:11 AM
DC Please build a street version or anyone please build a kit for me!!!!!!! Phil SRT10 and SRT10 Coupe Discussions 76 08-07-2006 02:49 AM
Roe Racing - Engine Build *Pics Galore* viprvenm RT/10 and GTS Discussions 16 12-31-2005 08:30 PM
finally complete: xcreampuffx motor build. fast? RT/10 and GTS Discussions 0 08-03-2004 03:38 PM
Pics of Gen1 motor needed Go Fast For Life RT/10 and GTS Discussions 2 04-23-2004 12:11 PM
