Old 10-31-2008, 10:58 AM   #1
2001 GTS
Default ALL MOTOR BUILD!!(Pics)
Finally starting to come together. Started the tear down back in March '08 and now have all the parts ready to drop in!
Basics:
JE Pistons - 11.5:1 Compression
242/246 Solid Roller Cam with .650" total lift
Greg Good ported GEN2 heads - Final flow - 321 Intake, 240ish exhuast
Fidanza Flywheel with replacement stock Luk clutch
70MM Throttle Bodies
B&B 1-3/4 Headers
No cats - 3" catback
Other parts:
1000hp Unitrax half shafts
Fuel Rails by AB
65lb Injectors
Aeromotive fuel pressure regulator
RSI dual walbro fuel pump drop in hanger
Cometic head gaskets
ATI Damper
T&D Rockers
VEC3
G-Force built T-56
19" CCW SP550s
We kept the stock 488ci displacement as well as working with the stock Gen2 heads. The goal is to make 600-650rwhp without having to bore or stroke the motor or use aftermarket heads.
Special Thanks to (I'm sure this list will grow before it is all over with):
KT Engine Development - Concord, NC
Greg Good Cylinder Heads
AB - Fuel rails and wires
Simms - Injectors
Mike(99 RT/10) - VEC, Flywheel, Tires
SVS - T&D Rockers
RSI - Billet Fuel Pump Hanger
Will keep you guys updated when its back together and tuned....
Old 10-31-2008, 11:09 AM   #2
Simms
Simms's Avatar
Default Re: ALL MOTOR BUILD!!(Pics)
Good looking stuff. Man does Greg's handy work look nice!
96 GTS - M2 Twin Turbo
Built and tuned by Macedo Motorsports
Simms is offline   Reply With Quote
Old 10-31-2008, 01:16 PM   #3
Viper Fever
Very impressive I think you will be pleased with the results.
Viper Fever:
97 GTS Red with White Stripes
66 Cobra Red with White Stripes,460 550hp,5sp.
96 GTS Blue /White bone stock
95 RT10 yellow/tan bone stock
Viper Fever is offline   Reply With Quote
Old 10-31-2008, 01:19 PM   #4
Mopar Boy
VCA member
Mopar Boy's Avatar
Me likey!!
Very nice!!
Robert
What goes vroom....crunch? Me running over Chad's slow red Viper!
Mopar Boy is offline   Reply With Quote
Old 10-31-2008, 04:15 PM   #5
ALsRT10
Looks great, what kind of engine managment system will you be going with? Also how did you determine you would need 65 lb injectors?
ALsRT10 is offline   Reply With Quote
Old 10-31-2008, 05:14 PM   #6
2001 GTS
Thanks Guys!
Engine management is a VEC3 with a Roe injector driver box. The "65lb" number just came from what Simms had for sale. I knew I needed 45lb+, and the vec can adjust for the different size injectors.
Old 10-31-2008, 09:37 PM   #7
99 R/T 10
99 R/T 10's Avatar
I am looking forward to seeing the power you'll lay down
97 B/W RT/10 TIME TO SELL HER-$42,000
99 Viper (Tubes&filters, TNT exhaust, T&D's ROE+ NOS=899hp/1300TRQ) safe tune
2008 Smurf Blue SRT Convert -FOR SALE! $68,000
Old 10-31-2008, 09:41 PM   #8
gb66gth
TX VCA Member
gb66gth's Avatar
Now that's how to build a motor!
gb66gth is offline   Reply With Quote
Old 10-31-2008, 09:52 PM   #9
vipeuup
That is awesome.
vipeuup is offline   Reply With Quote
Old 11-01-2008, 03:13 AM   #10
keep us posted and gregs work looks great
Old 11-01-2008, 10:09 AM   #11
hardtop
Nice N/A setup.
hardtop is offline   Reply With Quote
Old 11-01-2008, 02:49 PM   #12
VENOMAHOLIC
VENOMAHOLIC's Avatar
I also am a big fan of NA horsepower. Hope all goes smooth and you are on the road asap!
Black 2000 RT/10
Pewter 1999 C5 Coupe
VENOMAHOLIC is offline   Reply With Quote
Old 11-02-2008, 03:40 PM   #13
ab
Site Supporter
ab's Avatar
Might as well add your new rails to this thread.. PM me your address.
Here's your hand made rails finished today. Sorry for the delay.
WWW.QUALITYWIRES.COM FOR YOUR VIPER!
Old 11-02-2008, 03:54 PM   #14
99 R/T 10
99 R/T 10's Avatar
Man! Those are some big fat fingers right there............................................
Old 11-02-2008, 05:02 PM   #15
Jim Wilson
VCA Member AZ
Jim Wilson's Avatar
Hey Adam, if I didn't know better, I'd say you took those photos with a certain someones D300!!!
Jim Wilson is offline   Reply With Quote
Old 11-02-2008, 05:05 PM   #16
ab
Site Supporter
ab's Avatar
Actually I didn't. I took it with a crappy Kodak camera I am stuck with. The D300 and all the goodies are packed up and ready to go! If I took them with the D300, the pictures would have been a million times better!
Here's a picture with the D300 that was reduced down. This was taken about a month or so back.
Old 11-02-2008, 05:20 PM   #17
Jim Wilson
VCA Member AZ
Jim Wilson's Avatar
I guess I didn't know better. My apologies!
Old 11-02-2008, 09:40 PM   #18
DC Performance
DC Performance's Avatar
Let me know if you need help tuning that engine when its finished. We can help.
Dan
Dan Cragin
President, DC Performance Inc
310-841-6996
DC Performance.com
Old 11-03-2008, 07:47 AM   #19
2001 GTS
Thanks Dan! Might have to take you up on that.
PM Sent Adam....those rails look HOT!
Old 11-03-2008, 07:01 PM   #20
281cammer
Carolinas VCA Member
281cammer's Avatar
Looks weak to me!!!!
281cammer is offline   Reply With Quote
Old 11-03-2008, 09:18 PM   #21
jay01m
If you can pull off 650HP, I will be extremely impressed. Most motors can't get anywhere close to 650 with any durability unless you go bore/stroke, boost or spray. There are very few high performance N/A motors out there with more than 500HP, let alone 650. Nice build!
jay01m is offline   Reply With Quote
Old 11-03-2008, 09:55 PM   #22
Jerome Sparich
That cross hatch in the cylinders looks suspect.
Do you have any better/closer pics of it?
Jerome Sparich is offline   Reply With Quote
Old 11-04-2008, 07:00 AM   #23
2001 GTS
They're out there
The only pics I took up close of the motor are the ones posted. What do you think is suspect?
Old 11-04-2008, 07:03 AM   #24
Jerome Sparich
Originally Posted by 2001 GTS View Post
They're out there
The angle of the cross hatch looks like hell. Atleast it does in that pic. It may just be the pic, but I am not too sure it is.
Looks like the hone was moving upward and downward much too fast. That is unless the ring manufacturer calls for such a spec?
Old 11-13-2008, 08:34 AM   #25
2001 GTS
Got the CCWs in...and wow these wheels look good. Will get a lot better pics when I get them on the car.
But for now they are locked up in the car hauler....
Also...my VEC2 is for sale in the classifieds.
Old 11-14-2008, 07:41 PM   #26
2001 GTS
WOW...the VEC2 sold in less than 5hrs. It's off to a new home in WA...thanks James!
Old 12-04-2008, 06:10 PM   #27
2001 GTS
Got some more parts in while I'm waiting for the car to get back together. I will hopefully get some pics of the motor fully assembled before it get dropped in.
Thanks George from MGW for getting this to me:
Thanks Carl (Catwood) for the track parts; Porsche style deflectors, rear toe brackets, and tow hooks:
And here are the big brakes from R&J continuing the red/black theme:
And finally some better shots of the CCWS!!!
Old 12-04-2008, 07:12 PM   #28
OKViper
OKViper's Avatar
I'm jealous of your build - looks awesome...
OKViper is offline   Reply With Quote
Old 12-04-2008, 07:49 PM   #29
bluesrt
bluesrt's Avatar
that is smashing looking!!!!!!
bluesrt is offline   Reply With Quote
Old 12-04-2008, 08:40 PM   #30
crazyspeed
600 rwhp would be awesome...esp at 488 cid
crazyspeed is offline   Reply With Quote
2008 Vmag Motor - Pics WANTED SRT10 and SRT10 Coupe Discussions 0 07-03-2007 11:11 AM
DC Please build a street version or anyone please build a kit for me!!!!!!! Phil SRT10 and SRT10 Coupe Discussions 76 08-07-2006 02:49 AM
Roe Racing - Engine Build *Pics Galore* viprvenm RT/10 and GTS Discussions 16 12-31-2005 08:30 PM
finally complete: xcreampuffx motor build. fast? RT/10 and GTS Discussions 0 08-03-2004 03:38 PM
Pics of Gen1 motor needed Go Fast For Life RT/10 and GTS Discussions 2 04-23-2004 12:11 PM
