Old 11-08-2008, 08:52 PM   #1
Jack B
Jack B's Avatar
Default The Super VEC2
I may have been hibernating, but, I'm just wondering how many are aware of the hidden layer of commands in the VEC. I saw a post a little while back about the inability of the VEC in controlling larger injectors. The post did not relate to proportioning, however, related to the TIP-IN response and that the VEC could not control that aspect. If anyone is familiar with HPTuners, they have a series of tables that control the tip-in or as they refer to power enrichment under acceleration.
I talked to Sean and he indicated that tip-in could be controlled with a different version of the Vec software. I obtained the new software and there was a tip-in parameter, but, the interesting part was there were many/many new parameters that could be accessed.
I just wonder how many of you knew about the hidden layer of programming and how many have actually utilized this advanced software.
Jack B
10.2 @140 (1.7 sec 60')
1.45 (best 60')
Old 11-08-2008, 10:07 PM   #2
Joseph Dell
Georgia VCA Member
Default Re: The Super VEC2
Jack -
I am constantly fighting with tip-in. Please PM me whatever info you have. there are about a dozen cars out here i'd love to get working with a fixed tip-in!
Also, I was never able to get large injectors (96 lb) to idle or run worth a darn w/ the VEC. with an AEM, no problem. If there is a secret, i'd like to learn it as I have a need for this right now on a friend's car.
Thanks!!!
Old 11-09-2008, 09:46 AM   #3
BOTTLEFED
ID VCA Member
BOTTLEFED's Avatar
wow, this is very interesting
I know that I've had trouble with not being able to get a safe, rich AFR in the first 500rpms of WOT. Is this what you are talking about?
97GTS B&W: Roe S/C 6.5#, VEC3, custom W/M, Borla headers and catless exhaust, smooth tubes and K&Ns, JM stg3 heads, 1.7 Arrow RR, 3.55 gears, Fidanza, B&M sst, 635hp/642tq
Old 11-09-2008, 07:49 PM   #4
Jack B
Jack B's Avatar
That is part of it. Most of the other engine management systems have the tip-in feature. With the enhanced vec software you sync it with either vacuum or throttle position. I have not tried it yet, some of the parameters and drop-downs need further explanation.
Jack B
1.45 (best 60')
Old 11-10-2008, 08:01 AM   #5
ViperTony
ViperTony's Avatar
So, where did you get the software?
'01 RT/10, Belanger Headers, Cats, Catback,TD RRs, SCT Tune. Greg Good goodies coming soon!
NY/CT Club Secretary
Old 11-10-2008, 09:28 PM   #6
Jack B
Jack B's Avatar
From Sean
The software is merely a new INI file. When you open with the new INI file you will see an additional set of "Model Presets". When you choose "General Data Set" in stead of one of the Viper presets, several new parameters show up. When you go to the fuel options it has a "Acceleration Fuel Enrichment" set of parameters.
I thought more of the forum would have seen this already. This is my winter project. An analog input is needed to drive the enrichment. Although it would be easy to use the map signal, I think the throttle would be a better choice due to better resolution.
Jack B
1.45 (best 60')
Old 11-11-2008, 10:30 AM   #7
BOTTLEFED
ID VCA Member
BOTTLEFED's Avatar
Cool, let us know how it works out
Old 11-12-2008, 07:00 PM   #8
Joseph Dell
Georgia VCA Member
grrrrrrrrrr... 3+ years of tuning VEC's and I've wanted this feature. This is the primary reason that the VEC isn't an ideal match for TT cars... the Tip-In! But now we can do it?
Please past the INI file here (it is a text file). I'd love to see it!!
Old 11-14-2008, 09:07 AM   #9
GTSnake
GTSnake's Avatar
Hmm, I'm interested in this now. But can this correct my lean condition at 2k rpm?
'97 GTS
1304 RWHP CPE TT system
updated life insurance...
Old 11-14-2008, 05:31 PM   #10
Joseph Dell
Georgia VCA Member
Yes!!! This is the parameter in the AEM that does the same thing.
Jack - where are you?!!?!
Old 11-14-2008, 05:47 PM   #11
2001 GTS
Sounds like this will take care of some of the driveability issues! Looking forward to seeing what you can do Joseph.
Old 11-15-2008, 06:53 PM   #12
Jack B
Jack B's Avatar
Joe:
I sent you the file - did you get it? If you did not, I have the wrong email address. We just need to get the two tip-in parameters set. You can do it without any additional input by using the MAP existing signal. I think the throttle position would be better, but, if the MAP works, why bother bringing in another analog.
Jack B
1.45 (best 60')
VEC2 is Very Hot DrumrBoy RT/10 and GTS Discussions 9 01-09-2007 07:24 AM
VEC2 ??? grayman SRT10 and SRT10 Coupe Discussions 8 11-18-2005 04:04 PM
vec2 4207henri RT/10 and GTS Discussions 1 04-25-2005 06:27 PM
anybody have a used VEC2? 4207henri RT/10 and GTS Discussions 0 03-27-2005 12:37 PM
SUPER KING POSER GOES SUPER KILLER KING POSER BLUESNAKE367 RT/10 and GTS Discussions 6 02-25-2005 04:33 PM
